help identifying a part - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 04-23-2019, 06:29 PM Thread Starter
Hey guys I'm a new member to the forum. I have a 2004 Excursion 6.0 Powerstroke. I replaced the passenger side battery and was wondering what attaches to the two screw clips located on the right side of the battery (when looking from the front of the truck). From all the pictures I've seen on the internet, it looks like the coolant tank attaches there on gas models. Thanks in advance for your help. I look forward to being a member of the EX community.
Tarheelz4life is offline
post #2 of 7 (permalink) Old 04-24-2019, 12:21 AM
Steve83's Avatar
It's more expensive to make a battery tray for every vehicle than to make one that fits many. So Ford just orders one from that supplier, and ships it to all the assembly lines.
If it bothers you, remove the U-nuts. They might be handy to have a spares later on, and removing them will protect them from battery acid leaks.
Steve83 is offline
post #3 of 7 (permalink) Old 04-26-2019, 11:03 PM Thread Starter
Thanks Steve. I appreciate your help.
post #4 of 7 (permalink) Old 04-27-2019, 11:54 AM
These are for attaching a heat shield that will protect your battery from the heat of the engine and make it last longer.
DonWarkentin is offline
post #5 of 7 (permalink) Old 04-27-2019, 11:50 PM
klhansen's Avatar
My Photos: (180)
If it were a 7.3L that would be where the coolant reservoir attaches. There are two bolts into the passenger side battery tray and another up on the radiator support. Maybe those on your battery tray are just holdovers from the earlier trucks with the 7.3L.
), AIS,
regulated return,
klhansen is offline
post #6 of 7 (permalink) Old 04-28-2019, 06:30 AM
ford_doctor's Avatar
Yes, the coolant degas bottle was attached there on 5.4L and 6.8L gas engine applications... and as mentioned, that is where the degas bottle for 7.3L applications was bolted in.
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #7 of 7 (permalink) Old 04-30-2019, 10:01 AM Thread Starter
Don,
Any chance you would have a picture of the heat shield you speak of? Iíve seen the cheap cloth/foam ones but nothing that would attach there on the passenger side.
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
Similar Threads
International Truck Tool Collection varying models. greebr2003 General Diesel 4 03-22-2012 10:52 AM
Help identifying name or part number or name of fuel hose/line. txgp17 '99 & up 7.3L Power Stroke Engine and Drivetrain 3 08-12-2011 08:24 PM
Quick Air Filter Question, Part Numbers? JIM342STRKR 6.4L Power Stroke Engine and Drivetrain 8 08-20-2010 10:14 PM
How many of you with NO mods have had problems? traildog 6.0L Power Stroke Engine and Drivetrain 118 05-27-2010 07:45 PM
Racor fuel filter/water separator availability, part IN BF811 digimojo 6.9L IDI Diesels (Not Power Strokes) 4 05-06-2007 10:03 AM
