Oil disappears 7.3l - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By Krep
post #1 of 5 (permalink) Old 07-30-2019, 07:33 PM Thread Starter
Oil disappears 7.3l
So have this goofy Ford that like to go through oil. Fix all the top.end leaks and no more river of oil buck it is leaking fro. Somewhere. Only time it smokes is morning startup other the that she runs like top and no oil on the ground. I can hear the turbo and lots of power. But gose through 5L of oil sometimes 5 km or 230 km. The only thing I can think of is its leaking past my injectors into they cylinder and blows out the pipe but again zero smoke after her morning smoke.
Any thoughts
Krep is offline
post #2 of 5 (permalink) Old 07-30-2019, 08:20 PM
Check the fuel filter if it is black it would be the injector O-RINGS. Oil is mixing with the fuel and being burned. I had the same symptoms, a set of injector O-rings solved it.
DENNY
DENNY is offline
post #3 of 5 (permalink) Old 07-31-2019, 01:09 PM
Injector "O" rings
XS_SUV
Graupp is offline
post #4 of 5 (permalink) Old 08-03-2019, 01:14 AM Thread Starter
Thanks ! Yup I would say I have a couple O Ring that need changing.
Took a little video
https://youtu.be/ezDf5hcpTsE
atic likes this.
Krep is offline
post #5 of 5 (permalink) Old 08-06-2019, 12:32 AM
atic's Avatar
Thanks for the video. I just did the glow plugs and was concerned with a small amount of smoke.
2002 Ford E350 7.3l PSD
2002 E-350 7.3L PSD "HazVan" 260K miles
Currently under transformation from a former FD Vehicle to an adventure van.
atic is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
