Question for those that have used F350 springs on the rear - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 05-12-2005, 02:24 PM Thread Starter
I just changed the front springs to u codes. Much nicer ride. I am now considering changing the rear springs as well. I have noticed that most folks change to a b code F350 spring. For those of you that did change the rear springs, did you have to change the block in the back as well. My truck is not lifted and now I have the u codes up front. I would prefer NOT to change the blocks if necessary but it would be nice to have the stiffer springs for when I tow my camper.
Thanks,
greg
GregW is offline
post #2 of 4 (permalink) Old 05-13-2005, 09:41 AM
Re: Question for those that have used F350 springs on the rear
Same thing that I want to do except I have V code front springs and A code rear springs.
John [img]/ubbthreads/images/graemlins/cool.gif[/img]
2000 Excursion Limited PSD 4X4 Dark Satin Green/Medium Parchmant Born 7/00 In-Service 10/00 All Factory Options except Transfer Skid Plate
JADFPE is offline
post #3 of 4 (permalink) Old 05-16-2005, 02:38 PM
Can anyone confirm that V-code from springs and A-code rear springs will allow the Excursion to sit level or slightly higher in the rear?
If not, what size blocks should be added?
Thanks,
Chris Turrisi
05 Excursion Ltd 6.0 - PSD Door Badges, BFG T/A KO 285/75-R16 Tires, C-Bet'r Mirrors, Catch-All Mats, ISSPRO EGT/Boost A-Pillar Mntd Guages, The Diesel Site Coolant Filter, Underhood Insulation & Weather Strips, Factory Mud Flaps, 22" Wipers, Valentine 1, Over Mirror Mntd ISSPRO Oil Temp, Oil Press, Volts, Diff/Tranny Temp Gauges, Custom Carling Switch Panel, KC back-up lights, Super-Springs, Custom 12v Power Outlets, Door Courtesy Lights, Vinyl Tubed Door Seals, Dynamat Extreme Everywhere, LED's in Door Handles, Amber Turn Signal Tail Lamps, PML diff & tranny covers, Fluiddampr, AFE Stage II Intake, LED TMI Tail Lamp & Rear Amber Turn Signal Bulbs, Cab Lights, Rancho Steering Stabilizer, RS9000 Shocks, V-Code Front & S-Code Rear Springs, 4.30 Gears, Edge Attitude, MBRP 4" Exhaust.
cturrisi is offline
post #4 of 4 (permalink) Old 05-16-2005, 07:11 PM
Yes, it will work. I have the x-codes in the front and 350 springs and blocks in the back of my 01. Just ordered the same set-up for my 03 that I just picked up. The front went from 37.5 to 40.5 inches. The rear went from 39.5 to 41.5 inches.These measurements included the addition of 285 tires vs. 265's.Just got done measuring the two of them side by side this is why I know! [img]/ubbthreads/images/graemlins/wink.gif[/img]
01 X Limited 7.3 4X4
03 X Ultimate Limited 7.3 4X4
jjtproperty1 is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
