Recommendations for Alternator Upgrade? - Page 2 - Diesel Forum - TheDieselStop.com
 1Likes
post #16 of 27 (permalink) Old 12-15-2017, 04:21 PM
I switched to a Nations alternator about a year and a half ago ,I'm running the Tad 190 alternator after running thru 3 parts store alternators . I tried one new and two rebuilts and nothing lasted longer than 6 months.
2002 Excursion limited 4x4 v-code springs,Bilstein shocks,Red Head steering box,Sct X-3 with DP-Tunes,Glow shift Gauges, Hellwig rear sway bar,Firestone air bags on the rear,Silverline Stainless 4" exhaust (SOLD)
2003 Dodge Ram 2500 Qc 4x4
[email protected] filter,Silverline 4" exhaust,Autometer gauges,Smarty,Raptor 150
2001 Ford Excursion Limited 4x4 Firestone airbags ,190 amp alternator ,mbrp 4" exhaust( My old Silverline sounded better) Dp Tuner F5 chip,Glowshift gauges ,Kenwood double din /nav radio,Ford AIS intake
BlueOx1 is offline
post #17 of 27 (permalink) Old 12-17-2017, 06:44 PM
alternator failing so replaced it today
The battery light came on so today I replace the alternator. Excursion has 181000 miles not too bad for a 16 year old truck. I got the Auto Zone new replacement 110A since the old one was 110A and served me well.
2001 Ford Excursion 7.3-Sold : 1/19/2019
barlowcw is offline
post #18 of 27 (permalink) Old 12-17-2017, 07:03 PM Thread Starter
My batteries were old so I purchased 2 new ones and the Alternator (10 years old) seems to be working fine now.
On a related note (and the subject of one of my separate posts) my positive battery terminal end (drivers side) is so corroded that it needs an immediate repair. Today I got DTC's for a bunch of crap related to the PCM which indicates that I've got some kind of battery problem and the bad connection seems like a good place to start.
Hate to replace the entire cable but am struggling to find a good replacement terminal connector to attach to the cable. (I've read that replacing the entire cable is a bit if a PITA in addition to being an expensive cable).
dillon134 is offline
post #19 of 27 (permalink) Old 12-17-2017, 07:23 PM
79jasper's Avatar
I would do the whole cable. Either buy one, have one made, or make your own.
Sent from my SM-G892A using Tapatalk
79jasper is offline
post #20 of 27 (permalink) Old 12-20-2017, 07:26 PM Thread Starter
Roger that. I may build the entire cable on my own with MIL Grade Hardware. Friggin hate the stock cable.
post #21 of 27 (permalink) Old 12-21-2017, 08:15 AM
79jasper's Avatar
Some like switching to the stud post. But whichever will work. Just go big on the cable. Lol
79jasper is offline
post #22 of 27 (permalink) Old 12-31-2017, 07:40 AM
I used FICM Repair. Bought the Leece Neville 230 Amp Alternator with overdrive pully and the wiring up grade. I had 3 dead FICM's due to voltage problem. I will have this on both my 6.0's.
Brad06 is offline
post #23 of 27 (permalink) Old 01-01-2018, 09:21 PM Thread Starter
Good idea. I suspect that I'll be needing a FICM as well. Think I'll go with the Atlas 40 tune.
post #24 of 27 (permalink) Old 01-05-2018, 08:13 AM
Have the Atlas 40 tune, like it.
Brad06 is offline
post #25 of 27 (permalink) Old 01-05-2018, 09:46 AM Thread Starter
Thanks for the vote of confidence. Do you have ARP HG's? My motor is stock with original HG's and I'm afraid to have too much of a tune.
post #26 of 27 (permalink) Old 01-12-2018, 08:14 AM
All stock except fot the alternator, FICM and egr cooler. I'm looking at the Edge CTS2 with variable tuning. Just don't intend to hammer it all the time. Will bullet proof when the time comes.
Brad06 is offline
post #27 of 27 (permalink) Old 01-14-2018, 10:37 AM Thread Starter
Thanks for your reply. I'm going to limp through the winter and do the FICM install when it warms up. Wish I'd done it last fall because my truck won't run right until the EOT is > 150 degrees.
  Diesel Forum - TheDieselStop.com > Ford Diesels > Power Stroke Excursions
