Frame mounted fuel pump - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old Today, 11:16 AM Thread Starter
clev's Avatar
My Photos: (16)
I want to replace the fuel pump with an OEM, but am having no luck finding one. Not even the local dealer has one. I won’t even consider a junk yard. Diesel O Rings has a Bosch, but I know nothing about those pumps. My OEM has lasted 21 years and 147k miles. Any suggestion on where to get an OEM pump, or a recommendation for an aftermarket?
2012 F-350 SD Crew Cab, SRW, LWB, 4 X 4, FX4 Offroad, Bilsteins and Bilstein Steering Stableizer, AirLift Air Bags with onboard compressor, BedLocker electric bed cover, Hellwig 1 1/4 inch rear anti-sway bar, 2017 G37 Turbo, ATS Stage I towing transmission kit, White Platinum w/Adobe, Navigation, Moon Roof, 5th Wheel Prep, Step Tail Gate, front 2 inch receiver, completely insulated, Pioneer speakers, King Ranch Package
'99 E-350 HiTop Companion Van Conversion, 7.3 SD Diesel, 5-tune DP Tuner, Triple AutoMeter C2 A-pillar gauge pod, dash mount AutoMeter C2 fuel pressure gauge, twin K&N's, 203* mod, Deraler tubed trannie pan, B&M trannie cooler, AirLift air bags, Bilsteins, 4" DiamondEye turbo back exhaust, Air Dog fuel filtration system, Hutch mod, header wrapped and high temperature painted Bellowed Up-Pipes.
clev is online now
post #2 of 4 (permalink) Old Today, 03:19 PM
I have had pretty good luck finding some “NOS” parts for my van on eBay.
Is eBay item 223602302138 the pump?
2000 E350, I ordered it from the factory, new. Dual A/C, XLT Super Duty trim, 3.55 limited slip, trailer tow class IV package, dual alternators,
speed control/tilt wheel, HD4R100 installed @203k miles, B&M cast pan,
Dahl 100 fuel filter, deleted stock fuel bowl drain valve (leaker),
replaced turbo pedestal w/ non-EBPV, deleted AIH. Bilstein shocks. Jensen VX7021 Navigation receiver, Garmin 65W dash cam
tcnofh1 is offline
post #3 of 4 (permalink) Old Today, 04:35 PM
klhansen's Avatar
My Photos: (180)
I'm thinking that the OEM Ford pump is likely made by Bosch.
I believe that other guys have had good service from Bosch pumps. Diesel O Rings has good products and would stand by them.
The pump you need is the one that tcnofh1 posted if you want to go OEM (Motorcraft).
This is another option: https://parts.autonationfordwhitebea...OC1kaWVzZWw%3D
(the picture is incorrect).
), AIS,
regulated return,
klhansen is offline
post #4 of 4 (permalink) Old Today, 05:19 PM Thread Starter
clev's Avatar
My Photos: (16)
I ordered a Busch from Diesel O Rings.
clev is online now
  Diesel Forum - TheDieselStop.com > Ford Diesels > E-Series Vans
Currently Active Users Viewing This Thread: 3 (1 members and 2 guests)
DonWarkentin
