Fuel pressure gauge - Diesel Forum - TheDieselStop.com
post #1 of 43 (permalink) Old 06-02-2016, 09:33 AM Thread Starter
clev's Avatar
My Photos: (16)
Fuel pressure gauge
I have a 3 gauge Pod set up on the A-pillar and want to add a fpg. I'm not sure where I'll mount it, but my first problem is not knowing where to connect it/patch into the existing system. Can/will someone offer advice on connecting a Fuel a Pressure Gauge?
clev is offline
post #2 of 43 (permalink) Old 06-02-2016, 11:38 AM
I don't have a fpg, but I have two guages mounted on top of my dash on the removable cover. Here is a link to the picture. http://www.thedieselstop.com/forums/...4-post177.html
Current:
2001 E350 EB HT PSD w/ a bunch of stuff.
Had three other E350s...
bbasso is offline
post #3 of 43 (permalink) Old 06-02-2016, 04:54 PM
djbonsu's Avatar
I put my fuel gauge on my fuel bowl "outlet" port. You can also put it on the fuel bowl inlet port but that will only give you the pressure of the pump rather than what the heads/injectors will see.
here is a link to my port on the fuel bowl (assuming you didnt delete your fuel bowl)
http://www.thedieselstop.com/forums/...0/#post4125642
2000 E350 Cargo/Family Hauler PSD
- UJOR 4x4 6" Kit w/ Dana 60 Axles
- Tow mirrors
- ScanGauge II w/ X-Gauges
- Boost/Pyro/ Fuel Pressure Gauges
- Dp Tuner F5 80 econ, 80tow, High Idle
- Riffraff Diesel FRx & HPx
- Bellowed Up-Pipes
- EBPV, AIH & Resonator Delete
djbonsu is offline
post #4 of 43 (permalink) Old 06-02-2016, 05:10 PM Thread Starter
clev's Avatar
My Photos: (16)
dj, I followed your link and saw the fpg, but could not see your connection to the fuel bowl. Is there a port available on the bowl? Or must you 'T' in a connection?
clev is offline
post #5 of 43 (permalink) Old 06-02-2016, 05:24 PM
djbonsu's Avatar
There is no t connection. I just removed the plug and replaced it with a 90 deg npt to barb adapter. I forget the sizes at the moment but "ert01" had it detailed in his maintenance thread.
I attached a pic of the rear of the fuel bowl for your reference about the "fuel outlet" port I am referencing
- Tow mirrors
- Bellowed Up-Pipes
djbonsu is offline
post #6 of 43 (permalink) Old 06-02-2016, 05:34 PM Thread Starter
clev's Avatar
My Photos: (16)
Thanks, dj; I didn't know there was an existing place on the fuel bowl to attach a fpg. I'll take a look at details of the bowl and search ert's posts.
clev is offline
post #7 of 43 (permalink) Old 06-02-2016, 05:35 PM Thread Starter
clev's Avatar
My Photos: (16)
I almost forgot; how do the plugs come out? Unscrew??
clev is offline
post #8 of 43 (permalink) Old 06-02-2016, 05:36 PM Thread Starter
clev's Avatar
My Photos: (16)
Answered my own question; thanks.
clev is offline
post #9 of 43 (permalink) Old 06-03-2016, 12:09 AM Thread Starter
clev's Avatar
My Photos: (16)
bb, did you drill holes in the panel for wires? If not, where are they? You did a good job.
clev is offline
post #10 of 43 (permalink) Old 06-03-2016, 01:10 AM
StockKnocker's Avatar
Hi Clev,
I used this fuel bowl pressure port adapter from dieselOrings.com. I put mine post filter which is towards lower passenger side of bowl. That allows me to see true fuel pressure of fuel after it has run through filter. He also sells a 90 degree adapter, but IMO, the straight fitting is easiest to install from doghouse. Here it is:
1/8" NPT straight pressure port adapter.
Then you can either thread an electronic fuel gauge sending unit into the adapter or get a diesel rated Schraeder valve from same vendor so you could hook up mechanic's fuel gauge if you had problems. Another gauge mounting location I've seen is a simple hole drilled right near power port on dash (no pod required).
-Jason
2003 E-350 7.3 PSD EB, RR Frx & Hpx,Hutch/Stanadyne FM100 Pre-Filter, WW2, EBP delete pedestal/Hi flow outlet, Spectra Premium F41B Fuel Tank, 203* tstat, & coolant filter, Bellowed/wrapped up pipes, Walker BTM, AIH delete,AM EGT/TRANS/FP gauges, ThermalZero turbo blanket, KYB MonoMax shocks, TTC-2814 HD coils, Ford Ambulance Steering Stabilizer, Michelin 285-17ís Load Range E, Rear 10 leaf packs, CCV slightly modified, full sound mat, Curt Class V Rear Hitch and 2" Front Hitch, Tekonsha Primus, Nav., 2 AGM's, 2000 lb. roof rack, inverter, insulated, custom bulkhead, tool bins, 170k, my 18th
SOLD: 1997 F-350 7.3 PSD, 4X2, XLT, CC, LB, STD, 240K and counting
SOLD: 1996 F-350 7.3 PSD, 4X2, LB, AUTO, 175K and counting
StockKnocker is offline
post #11 of 43 (permalink) Old 06-03-2016, 08:44 AM Thread Starter
clev's Avatar
My Photos: (16)
Good morning, stock. Thanks for the info. What brand of fpg do you use?
clev is offline
post #12 of 43 (permalink) Old 06-03-2016, 09:22 AM
What tool fits in the plug for removal? Is it a metric allen wrench?
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
post #13 of 43 (permalink) Old 06-03-2016, 09:30 AM Thread Starter
clev's Avatar
My Photos: (16)
Good morning, Bork. It's definitely an Allen but I don't know the size yet.
clev is offline
post #14 of 43 (permalink) Old 06-03-2016, 07:28 PM
I just got an Autometer Z-Series FP gauge, expensive but one of the 3 most important gauges. Mine is not completely installed yet but I've been working a-lot lately to pay for this addiction!
Fuel bowl plugs are 3/16" hex Allen wrench. The adapter comes with Viton o-ring. Hope that helps.
-Jason
post #15 of 43 (permalink) Old 06-03-2016, 07:50 PM Thread Starter
clev's Avatar
My Photos: (16)
Thanks, stock. My 3-pillar gauges are AutoMeter C2, and yes, expensive. I believe the FPG is ~$225.
clev is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > E-Series Vans
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
cjmcqueen1164
