Page 1 of 2 | 1 | 2 |
LinkBack | Thread Tools | Display Modes |
Hi, need help hard starting gets worse when it's colder out
i have a 94 e-350 i assume i hate using that word lol but as it starting to get colder out its harder to start and when it starts smokes bad and smokes intermently until it comes off the cold cycle in the summer its not really bad its a non turbo so i think its the international motor .......... whats the best glow plugs to put in it ? and any tips thank you for reading ..
Sponsored Links | |||
Advertisement |
anyone
Ohm your glow plugs at the valve cover connections. Do a voltage drop on glow plug relay.
Advertisement |
Originally Posted by Maryland dieselnick
View Post
Sure, disconnect harness at valve covers. Foreword and back pin is glow plugs. Set meter to read ohms. One lead to glow plug pin, the oth to ground. Look for .2-2.0 ohms.
Activate relay by jumping in the activator small wire. Read voltage on big posts- in and out
View Post
View Post
Nick in his first post he says that it is a 94 non turbo diesel which should mean that the engine is a IDI and not a Powerstroke. The glow plugs will be visible along with the injectors on the top of the engine.
Use on Motorcraft ZD-9 glow plugs on a 7.3 IDI engine.
Originally Posted by bugman
View Post
My Photos: (9)
This guy a has a lot of good tips on your engine...other than that post in the IDI forum......Ford diesel 6.9 7.3 IDI
good luck
good luck
95 E350 PSD HD Cargo , BB shim , E4OD , B&M Trans pan , 2 HD coolers , Cat sleeps with the fishes , MAG teck 3:55 D60FF, EBPV Delete , DP 60 Tow , Autometer 3 Guage pod
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 , MSD IGN , Custom C-6 Trans , Dual Exh.
99 F250 XLT 7.3 DIT ,4R100 , CCSB , Rwd 3.73 , 10.5 limited slip , 5th Wheel & Class 4 hitch ....windows / Stuff / Factory Towing Mirrors / helper springs
View Post
Originally Posted by blageurt
View Post
good luck
good luck
WEL I DID THE GLOW PLUGS SOLVED THAT ISSUE SCANNED THE VAN AND NO CODES UGGGGGGGGGG STILL HAVE THIS IN OUT ON THE TRANNY BETWEEN 35-45 MPH ANY IDEAS ????????????????
View Post
good luck
good luck
My 6.9 idi blew white smoke until warm and under light acceleration. Put some fuel cleaner in it and clean the lines mine ended up being a clogged return line. I just rebuilt the injectors and put all new return lines on. Cant tell if it really fixed my problem though being as i just blew the turbo. Got a spare 7.3 idi going in this weekend.
Originally Posted by jmadigan
View Post
Have you tried a simple fix such as this:
Current:
2001 E350 EB HT PSD w/ a bunch of stuff.
Had three other E350s...
Advertisement |
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Posting Rules | |
