Hydroboost conversion - Diesel Forum - TheDieselStop.com
post #1 of 2 (permalink) Old 06-17-2019, 02:48 PM Thread Starter
Has anybody installed a hydroboost unit off a E 450 into a 2002 E350 with 7.3? I've had 2 pumps go out over the years at the most inopportune times (not like there is ever a good time to lose your brakes). In the modern world the brakes on our vans suck. If you convert to 4x4 or finish the interior (I e camper van/add weight) the brakes are even worse.
I know it's been done, hoping to find more info here.
2002 7.3 psd stretch window van, 140K Dp tuner F5 7 tunes, 4" turbo back, Wrapped exhaust, bellowed up pipes, Bilstein Hd's, RiffRaff RFX, HPX & CVC & AIH delete, 235/85/16 Michelins, Hid's, Auto-meter tranny temp, boost and pyro gauges, Mag-Hytec deep trans pan, towing mirrors, dynamat doors, Alpine 1000w blaster
I found building 5 mast sail boats inside a mini bottle wasn't challenging enough, so I bought a powerstroke van!
2016 F350 DRW CC long bed 6.7 stroker.
Lilnuts is offline
post #2 of 2 (permalink) Old 06-25-2019, 08:10 AM
(FMTRVT) recommended Hawk pads for braking, because I agree about poor stopping . Quote from Jack," The vans have a totally different brake manufacturer then the pickups. The sizing is relatively the same. The Hawk LTS pads are still what I would recommend."
The Hawks on the front did make a noticeable difference, and when rears are needed, I will see if they are available. I do wish Hawk would make the shoes for the in-hat parking brakes, so to have some kind of backup in case of main system failure while driving. Back in the day, around the Ft Lauderdale area, there used to be about three shops that could make up anything you want for shoes. Last I checked, they were all gone. I even was able to have my 1952 Plymouth brake-band over drive shaft e-brake re-lined, back when.
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
  Diesel Forum - TheDieselStop.com > Ford Diesels > E-Series Vans
