Side Battery - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By bbasso
post #1 of 8 (permalink) Old 12-13-2015, 09:44 PM Thread Starter
cjmcqueen1164's Avatar
Side Battery
how do i remove the battery on the passenger's side frame rail? Thanks
cjmcqueen1164 is offline
post #2 of 8 (permalink) Old 12-13-2015, 10:09 PM
I use a jack and position it under the battery case. Loosen the case and lower it down with the jack because the battery is fairly heavy. It will drop straight down after you've loosened it. Mine has a cable that prevents it from falling on the ground or on you or whatever is underneath. You can unhook that holding cable by jacking it up slightly and getting slack to allow you to unhook it from the frame. Then, once on the ground, you can unhook the cables from the posts. There is enough slack in the battery cables to allow that.
America....love it or leave it
02 E350 PSD Cargo with windows/power/CC/3.55 LS/Prodigy/Reese WD & Dual Cam/....from Cochise
Van Color:Gray--Bumper Color:Gray--Wheel Color:Gray--Hubcaps:metallic--Tire Color:black--Grill Color:gray plastic
I pull a 1987 Wells Cargo Express Wagon (20 ft)
Yardbrew is offline
post #3 of 8 (permalink) Old 12-13-2015, 11:11 PM
Yup, that's correct!
Current:
2001 E350 EB HT PSD w/ a bunch of stuff.
Had three other E350s...
bbasso is offline
post #4 of 8 (permalink) Old 12-14-2015, 03:16 PM Thread Starter
thanks guy's for the help! I see i will need lots of WD40?
post #5 of 8 (permalink) Old 12-14-2015, 05:46 PM
I prefer PB Blaster...
cjmcqueen1164 likes this.
Current:
bbasso is offline
post #6 of 8 (permalink) Old 12-18-2015, 12:30 PM
Alaskapsdvan's Avatar
My Photos: (35)
And people wonder why I moved the side battery to the rear of the van on the inside.
Box is bolted down and there is a Heavy cable for the positive side from rear to front, and a good ground for the battery.
There is also a relay in the back so that I can power the back up lights that I have put on and in the van.
2000 E350 7.3PSD, Hellwig Stablizer bar, 1.5"spacers from old Correct track OR,140 Lightforce with covers, 5x7 LED's From Truck-lite, extras in the bumper. 4"Aero Turbin and 4" all the way back. 1705 program, Scangauge II,265/75/16E, My Photos
"FAILURE IS NOT AN OPTION"
It riles them to believe
that you perceive
the web they weave
And keep on thinking free
Alaskapsdvan is offline
post #7 of 8 (permalink) Old 12-27-2015, 05:15 PM
Sounds like an excellent idea. You should post pics. I hope your using a sealed battery to avoid acid fumes rusting out something.
1999 E350 7.3psd , XLT , 15 pass/ext , purchased 6/6/05 w/255k on odo, 8/05 added BTM/straight pipe,5/06 BTS,1"shimmed front coil springs,Michelin XPS 235/85 16 R.,FredGroeske2"rear wheel spacers,1-1/2" rear sway bar,AIC,3 A-pillar guages, Tekonsha envoy,coolant filter,4 pos dp-tuner,In-tank mod & harpooned,dahl-100 prepumpfilter,Scan-guage,Bilstein shocks.
bork is offline
post #8 of 8 (permalink) Old 12-27-2015, 06:56 PM
My Photos: (35)
I have some of the photos posted in the gallery.
It is in a battery box bolted to the floor and then strapped into the box.
As for the type of battery, same as the front and standard acid battery.
But wait the VW Bug of the 60-70 had the same type under the rear seat, and then there was the rental car of 2006 that I had in May of 07 that had it in the trunk.
that you perceive
the web they weave
  Diesel Forum - TheDieselStop.com > Ford Diesels > E-Series Vans
