'2011 spring codes 6.7L - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 01-26-2012, 06:00 PM Thread Starter
Can anyone help me figure out what I have for front springs? I know based on the truck configuration some trucks automatically get a certain spring,I wanna know for possibly putting a plow on.would this be considered a HD front end?
Here is what the tag says:
5AE
5C34
5310-AEC
Thanks in advance
2005 F350 Reg Cab 4X4 SRW XLT 6.0 SOLD 1/31/08
2008 F250 SUPERCAB 4X4 SWB SOLD 10/23/2011
2011 F250 CREWCAB 4X4 6.7/AUTO XLT SOLD 9/2/14
2014 F350 Lariat crewcab 6.7 4x4
dmags is offline
post #2 of 14 (permalink) Old 01-27-2012, 12:39 AM
The sticker on your door jamb lists the front axle Gross Vehicle Weight Rating....mine is 5900lbs and I have the plow package springs.
bltp203 is offline
post #3 of 14 (permalink) Old 01-27-2012, 04:14 AM Thread Starter
Thanks i will check this a.m ....So I'm good to go if it says 5900 or more
I'm sure it will never snow again if I get one
dmags is offline
post #4 of 14 (permalink) Old 01-27-2012, 06:14 AM
Dick Cutting's Avatar
My Photos: (28)
Looking at the 2011 Order Guide it shows that you could possibly have the heavier springs depending on what the truck has for a couple other features.
If your truck has 17" or 18" tires then the Axle ratios were either 3.31 or 3.55.
However, in the order guide it showed if your truck was to have the 3.55 ratio with the 17 or 18" tires then the truck required one of the following options listed below.
Requires one of the following options; Heavy Service Front Suspension Package (67H), Heavy Service Package for Pickup Box Delete (63R), Snow Plow Prep Package (473) or Camper Package (471)
The Options info from the 2011 SD order guide
SNOW PLOW PREP PACKAGE (473)
Availability:
• Optional on all 4x4 Pickups
Not available with:
• Heavy-Service Front Suspension Package (67H)
Requires:
• 4x4
Includes:
• Computer selected springs for snowplow application.
• Extra Heavy-Duty Alternator (67D) w/Power Stroke® diesel engine
(Heavy-Duty Alternator with gas engine)
Options Available:
• Dual Alternator (67A) (Diesel only)
NOTE: Restrictions apply; see Supplemental Reference or Body-
Builders Layout Book for details
CAMPER PACKAGE (471)
Availability:
• Optional on all Pickups
Not available with:
• 20" Wheels and Tires, Pickup Box Delete (66D), 3.31 Axle Ratio
(on 4x4 with 17" or 18" tires) or Heavy-Service Front Suspension
Package (67H)
Includes:
• Extra heavy-service front springs (4x2) (2 up upgrade above the
spring computer selected as a consequence of options chosen. Not
incl. if maximum springs have been computer selected as standard
equipment)
• Heavy-service front springs (4x4) (1 up upgrade above the spring
computer selected as a consequence of options chosen. Not incl. if
equipment)
• Rear stabilizer bar (SRW only)
• Slide-in camper certification
• Rear auxiliary springs (F-250 only)
NOTE: Salesperson's Source Book or Ford RV Trailer Towing
Guide should be consulted for specific Trailer Towing or
camper limits and corresponding req. equipment, axle
ratios and model availability
HEAVY-SERVICE FRONT SUSPENSION PACKAGE (67H)
Availability:
• Optional on all pickups
Usage:
• Recommended only on vehicles which will permanently utilize
aftermarket equipment such as Heavy-Duty winches, brush guards
or other apparatus which loads the front axle to the specified Gross
Axle Weight Rating (GAWR)
Not available with:
• Snow Plow Package (473), Camper Package (471) or Heavy-
Includes:
• Heavy-service front springs (1 up upgrade above the spring
equipment)
NOTE 1: May result in deterioration of ride quality.
NOTE 2: Vehicle ride height will increase w/the addition of this
package.
TheDieselStop.Com Moderator & Former Photo Editor
Had a May '02 F350 7.3L SC Lariat 4x4 Auto. Sold In 5/2016 it had 321.1K+ miles
Had a June '97 F350 7.3L Reg Cab XLT 4x4 Auto SRW, OEM Radio w/CD. Sold In 5/2016 it had 208.1K+ miles
Dick Cutting is offline
post #5 of 14 (permalink) Old 01-27-2012, 06:36 AM Thread Starter
I checked before i left work and nope looks like i'm smoking sausage! 5000 lb front axle 17 " wheels 331axle bummer I guess the good news is i wont be beating the snot out of my front end. thanks
dmags is offline
post #6 of 14 (permalink) Old 01-27-2012, 01:27 PM
I had a set of 5,200# in my front end. I swapped them out for the 6000# springs, for the same reason- so I could plow. The only things that are added/changed to plow prep vehicles are heavier springs, and either the "extra heavy duty Altenator, or dual altenators. The axles and everything else is identicle. Easy swap. Order them from Tascaparts.com cost +10% $83.04 a piece. This TSB lists the spring codes and part numbers. If you order them from Tasca just don't enter your VIN on the order page, or they will assume you ordered the wrong part.
The ones you want are the set that end in ACC, those are the 6000# springs
PART NUMBER PART NAME
5C3Z-5310-CA Front Spring (ACC)
5C3Z-5310-DA Front Spring (ADC)
5C3Z-5310-EA Front Spring (AEC)
5C3Z-5310-FA Front Spring (AFC)
F-Super Duty Monobeam Coil Spring Rates (F250/350 4x4)
Front GAWR Rating Current Vehicle Spring Coil P/N 5C34-5310- Intall F250/F350 2-UP
4000 AHC AFC
4400 AGC AEC
4800 AFC ADC
5200 AEC ACC
5600 ADC ACC
6000 ACC No Replacement Part Available
11-4-19***4X4 ONLY - BANGING/CLUNKING NOISE WHEN DRIVING - CONTACT WITH JOUNCE BUMPER - COLD TEMPERATURES
BigGreenNozzle is offline
post #7 of 14 (permalink) Old 01-27-2012, 01:42 PM
Also- read the TSB and what it's about, probably wouldn't be hard to convince them that you "need" the springs because your "getting a banging, clunking noise in cold weather" it's the right time of year for it- the fix would be to install the 2-up springs in your truck. If you have the AEC- springs already, then the ACC springs would be the ones they'd install for you according to the TSB. good luck.
post #8 of 14 (permalink) Old 01-27-2012, 02:26 PM
what is the spring difference in the snow plow prep vs the heavy duty suspension.
2015 f450 platinum
outlw is offline
post #9 of 14 (permalink) Old 01-27-2012, 03:31 PM Thread Starter
my truck has goofy spec's I have the optional HD alternator so I guess all I need to do is change the springs and I would in affect have the plow pkg? why the truck has that and not a plow pack is weird Isn't this a cheap option? they wacked me 75.00 for the alternator
dmags is offline
post #10 of 14 (permalink) Old 01-27-2012, 05:13 PM
You'd have to find a truck with the heavy duty suspension and get the code off of the front springs- there are only a few different ones. Probably the same as plow prep
post #11 of 14 (permalink) Old 11-11-2013, 02:27 PM
SUPERTuFF1's Avatar
Has anyone else confirmed that the springs for the snow plow package are 5C3Z*5310*CA? My parts department references them as part of package 473 (Snow Plow Package) on a 13. I want to upgrade on my '12. Just a little gun shy since they messed up my other order! Thanks.
'12 F-350 LRT CC LB SRW FX4
6.7L-Torqueshift-3.55-X-Liner-Otherwise Stock
'03 F-350 LRT CC LB SRW FX4--SOLD!!
6.0L-Torqueshift-3.73;Eng.Born 6/20/03;141K miles
Husky Floor Liners/ Rhino Bed Liner/ Husky 5th Wheel Hitch/ EGR In-Channel window visors/ X-Springs with Bilstein Shocks/ Airlift System: SuperDuty airbags and Load Controller II/ 18 inch Ford SVT rims on BFG 285/70/18s
SUPERTuFF1 is offline
post #12 of 14 (permalink) Old 11-12-2013, 05:16 AM
Spring codes
If you don't trust your parts guy. Call Tasca they know their stuff-
But the chart is the chart.
Follow the table below to select the correct spring to install based on the vehicles front GAWR rating. Follow the instructions in Workshop Manual, Section 204-01A.
4000 AHC AFC
4400 AGC AEC
4800 AFC ADC
5200 AEC ACC
5600 ADC ACC
The ACC springs are the plow springs. Another option- go to a dealer and find a truck with the plow prep and read the tag on the springs in that one. The tag is easy to see and read.
post #13 of 14 (permalink) Old 07-07-2014, 06:06 PM
I went to the parts counter two weeks after I bought my 13 F350. Ordered the F450 #7000 coils. No regrets rides much better all around for me and it raised the nose 1".
2013 F350 CC Lariat 4x4 6.7L
2003 F250 SC Lariat FX4 6L sold
AK6LPSD is offline
post #14 of 14 (permalink) Old 07-07-2014, 06:59 PM
Feedback Score: 2 reviews
Good to know.. When I had my 07 F250, it had the 5,200 spring an no plow prep package. Back then, the plow prep package with Ford was Roof markers, different fan clutch and stiffer springs.
I changed out the fan clutch and had the 6,000s put on. I honestly couldn't tell a difference in ride quality without the plow on so I believe exactly what you said about not noticing a difference between the 6 and 7k springs.
15 6.7 F350 CCSB 4x4 3.55s Platinum Bronze Fire
Husky mats, all LED interior, Nushield for MFT, Bakflip F1 with Bakbox 2.
blwnsmoke is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
