Background on the truck:
2016 crew cab 6.7, auto, 4 x 4, 3.55 rear end.
Getting to work (Highway/city) on the mileage gauge, I am seeing an average of about 14 mpg. On the highway average I usually don’t see more than 16 mpg.
On the forums I’m seeing people saying that they’re getting 20mpg + on the highway. What gives?
Do I need a reflash of the ECM or what am I doing wrong?
I am in the Houston area as well and "in town" I usually average about 17.9, but it can drop to 15.x depending on traffic. I have managed 23.2 on the open road, but there are lots of variables that can affect MPG. My guess is that you are not doing anything wrong nor is anything wrong with the truck. If you are driving in town most of the time, then I would opine that your regens are happening more often and those definitely impact MPG.
I have a 2016 crew cab long box with 32,000 miles on it. My truck has 3:31 gears and 18 inch tires. I get about 17 1/2 miles per gallon at a little over 70 mph on the freeways. I get about 14-15 on city and country driving . I get 11 miles per gallon pulling a 31 foot 5th wheel and 12 to 13 pulling the four horse trailer. My 2016 gets 1 to 2 miles per gallon less than the 2011 I had.
My 2011 CC Dually with 3:73 gears gets a best of 17 and a half mpg on the highway at 70 mph and 14-15 in town. My old 97 7.3 got 20.7 mpg with 4:11 gears at 55 mpg, about 17 at 65 mph. I'm not complaining, but I too wonder how some of these trucks are supposedly getting 18-20 mpg driving 80 mph while I'm using the cruise control and staying under 2000 rpm. The power this thing makes offsets the mediocre mileage but I don't understand why we're not all averaging about the same mileage.
My late father-in-law used to say, “There’ve been more lies told about sex and fuel mileage than anything else”. ? I’m certainly not accusing anyone here of being less than forthcoming with the truth. I just thought it was funny.
Anyway, I wouldn’t really expect our trucks to be anywhere close in fuel mileage. Driving style & habits account for most of the variation as well as things like tire pressure, load, terrain, modifications & other factors. Cruise control is not the friend of fuel mileage. The only thing it will do is hold a constant set speed. Your mileage would be better if you held constant pressure on the throttle, allowed the truck to slow down going uphill & regain the speed going back downhill (traffic permitting).
Just as a point of reference, my 4 door 4X4 dually with 3.73 gears gets 15 - 16 mpg solo (using the driver info display). I consider 15 mpg to be adaquate & 17 mpg to be really good. Towing the 16,400 pound 5th wheel in my sig, I can depend on 9 mpg & Im really happier if I just don’t look at the mpg when towing. ☺ I’ve often wondered if 4.10 or 4.30 gears would yield better mileage towing this heavy 5er. The truck tows great & I’ve had no problems.
To make a long story unbearable, I don’t think there is anything wrong with your truck. Just drive it & enjoy the ride!
I have gotten just over 19 mpg in daily driving for mine (2011). But it's not my daily driver anymore. I'm getting around 17 mpg. I can't say anything for "city" driving, as I don't really do any. I just take my overall average.
I would say you are maybe a little on the low side, but nothing to get overly exited (or upset) about. As was said above, there's just too many variables to say whether there's anything wrong with your truck, or it's just your driving style.
My odometer is 50miles under the 36k mark. I took my truck in this morning for a leaky battery before the warranty was up.
I asked them to check for codes while it was there. I did though have an emissions warning light about six months ago, drained the fuel separator and it went away after two key cycles and never came back.
I picked up my truck yesterday, and got a new battery under warranty. While it was there they checked and found no codes. They also did what they call a multi point diesel inspection and everything was fine.
The dealer also told me to make sure my Regen was completely before turning the truck off. That it would try tokeep doing it every time the truck was started, until it was complete and this would affect mileage greatly.
How do you know when it has finished? My truck will have the red/orange pop up saying that it has been initiated but turns off after about a minute. Supposedly it takes 30 minutes? Five days a week I never drive over 30 to 40 minutes at a time.
One thing not mentioned in this thread is the fuel. I have seen a significant difference in fuel economy with the quality of the fuel you run. This is true with diesel and gasoline. That said I get around 12 -13 with mine with my average use which sees a combination of stop and go, a little highway and towing. Empty truck with no trailer and strictly highway driving will get right at 20.
THIS!!! As I said, I really don't think you're that far off on your mileage. And for terrain like you drive (same for me), cruise control is absolutely your friend. It will hold the speed much better than a human foot could do. I would tend to agree in a hill area, but not on relatively flat roads.
Just an update on the mileage.
I just recently bought a set of Cooper Tires in 295/70/18. These are taller and wider than the stock Michelin‘s that were on there. But I’m consistently (2nd tank) getting about 2 miles to the gallon more. Go figure?
I assume since I have the 3.55 rear gear that it is raising the gear ratio and causing better mileage?
I have gone from 14 to 16 mpg on the computer and it should be reading opposite with the larger tires fooling the speedo.
As soon as I am on empty on this tank, I will take hand calculations.
According to my GPS there’s only a 1 mile an hour difference, being faster than the speedo.
On a 8,500 pound (4 ton) truck, adding the weight of the larger tires is not going to affect the mileage as much, it any, as it would on a 3,000 pound car/truck. It might in fact increase mileage.
It would be interesting to know the difference in weight of the two sizes. I bet the weight is less than 125 pounds total for all 4. I would think even less, maybe 75 pounds. So, how much weight is being added compared to the total truck weight? hummmm....less than 1%?
Without correcting the odometer for the tire size change the mileage wouldn't change due to gear ratio. The truck still thinks it's travelling the same distance with both sets of tires according to the odometer.
Going with larger tires would make the computer think it is going a mile shorter than it actually did.
So in theory it should show less mpg than it accutally has.
I think rolling resistance is a big factor. I had a set of Les Scwab's once that felt like I was driving in wet cement . But Michelins are usually good MPG tires so I dunno?
I reset my trip odometer when the truck goes into regen. Completes in about 16 miles. Almost like clockwork my truck will go into a regen at around 400 miles. When it's getting close in miles I will take a longer route to allow the regen to complete. I have used Motorcraft PM22 with every fill-up.
What about oil? I understand my '16 F-350 came factory fill with the 10W30 that the manuel suggests for most usages. Dealer changed oil, went with the 15-40. Mileage dropped it seemed. Have since gone back to the 10W30.
Aside note- new CAT compact track loader runs 10W30 in a synthetic oil. Reckon the old days of 15W40 for all diesels may be fading into the past.
My personal opinion (worth the weight of popcorn) is that at 36k, you're just starting to get broken in.
As others have said driving conditions, gear ratio, fuel quality (cetane regs are a joke), additive effectiveness (I use OptiLube xpd and boost religiously), tire pressure, tire brand/size differentials, regen frequency, etc etc ALL factor into what you should "expect" as far as MPG goes.
I average about 19.5-20 going to work (coming down from the hills about 3000 feet) and 17-18 going home.
I have kept every single fuel receipt since I picked it up from the dealer, and the receipt math is what I'm quoting not the dashboard display - which can differ as much as 3mpg per tank.
Enjoy it, drive it more, and you'll eventually settle into your normal fuel usage. I don't think I saw near 20 until about 50k.
Related Threads
The Diesel Stop
2.6M posts
210.8K members
Since 1999
