6.7L Engine Code - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 06-24-2015, 12:53 AM Thread Starter
6.7L Engine Code
2012 F250 has about 92500 miles. I have a code that's come up P2073 it says something like "engine correlation at idle". Truck runs fine but drives like it's down on power some. I can clear the code and it'll be fine for awhile but it comes back. Anyone else have this problem and know the fix for it. I'd really prefer not to have to take it to the dealer.
thewrap is offline
post #2 of 9 (permalink) Old 06-24-2015, 05:20 AM
OBDII Codes for the 2012
http://www.motorcraftservice.com/vdi...DOBDSM1202.pdf
Starting on page 87 is a flowchart that might help you find the problem.
Larry
larrgh is online now
post #3 of 9 (permalink) Old 06-24-2015, 09:39 AM
FordService's Avatar
Hi thewrap,
It sounds like you're going to go the DIY route, but keep in mind your dealer will always be happy to assist. If you decide to get them involved, let me know; I'll be able to research options to help once they've diagnosed your rig.
Crystal
FORD SERVICE
p: 800.392.FORD
t:
f:
FordService is offline
post #4 of 9 (permalink) Old 06-25-2015, 11:43 AM Thread Starter
Originally Posted by FordService View Post
Hi thewrap,
Crystal
The only reason I would do it that way is because the dealers here are extremely backed up. On diesel trucks we have 4-6 weeks wait for appointments like that.
That being said do you have any information on what has been or could be causing the code?
thewrap is offline
post #5 of 9 (permalink) Old 06-25-2015, 12:49 PM
ford_doctor's Avatar
P2073 - Manifold Absolute Pressure/Mass Air Flow - Throttle Position Correlation at Idle
The DTC sets when the final air mass adaption stored value at idle is more than 15% above or below the calibrated threshold. This can be tricky to diagnose and I personally have seen different things cause it therefore there is no one thing I can point to as a common issue.
Possible Causes include:
  • Leaks or restrictions in the intake air system and charge air cooler (CAC)<
  • Leaks or restrictions in the crankcase ventilation system
  • Damaged mass air flow (MAF)/intake air temperature (IAT) sensor
  • Biased MAF/IAT sensor
  • Damaged exhaust gas recirculation (EGR) valve
2016 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is online now
post #6 of 9 (permalink) Old 06-25-2015, 04:04 PM Thread Starter
Ok. I'm hoping it is just a sensor. If not more than likely I may have to take it to the dealer whenever they can clear the backlog.
thewrap is offline
post #7 of 9 (permalink) Old 06-26-2015, 08:55 AM
...That being said do you have any information on what has been or could be causing the code?
I completely understand, thewrap. I'm not a technician, so I'm not the best resource for diagnostic questions. You could always give the service manager at your dealership a call; I know they'd be glad to do what they can to help out.
Crystal
FORD SERVICE
p: 800.392.FORD
t:
f:
post #8 of 9 (permalink) Old 06-26-2015, 07:02 PM Thread Starter
I'm pretty sure I've found the problem. The MAF was scorched and melted pretty good from a previous incident. I'm hoping whenever I can get a replacement that fixes it. If I could get the pics to post from my phone I would to show what it looked like.
thewrap is offline
post #9 of 9 (permalink) Old 10-11-2018, 07:52 PM
Did you ever figure this out? just curious.
FireMechanic1 is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
