6.7L turbo leak - Diesel Forum - TheDieselStop.com
 2Likes
  • 1 Post By larrgh
  • 1 Post By larrgh
post #1 of 5 (permalink) Old 07-13-2019, 11:29 AM Thread Starter
6.7L turbo leak
Developed a leak recently. I can hear it under light boost can hear it even more when I'm towing. No check engine light and no real loss of power.. I took off the pipe from the intercooler to the center of the engine. that one seemed to loose. I popped the clip removed it cleaned it put it back together and pretty sure I got the clip properly reinstalled. But it made no difference. What pipe should I focus on. should I just replace the one that I've messed with so far because it seemed pretty loose at the plastic end at the engine.
55f600 is offline
post #2 of 5 (permalink) Old 07-13-2019, 06:41 PM
Check the composite material pipe. It is the one that usually develops a problem. This is called the cold side pipe. The hot site rarely ever gives a problem as the stock pipe is made out of metal.
HeavyAssault likes this.
Larry
larrgh is offline
post #3 of 5 (permalink) Old 07-15-2019, 11:05 AM Thread Starter
Thank you for the reply. Should I buy another factory one or is there a better aftermarket solution?
55f600 is offline
post #4 of 5 (permalink) Old 07-15-2019, 11:14 AM
If your CAC (cold air tube) is the problem, most everyone that has experienced the CAC (cold air tube) rupture has replaced it with an aftermarket kit. I replaced mine with a Rudy's prior to having issues. You can pay upwards of $400 to as low as $75 for the kits. To me, most of the higher priced kits you are often paying for the name on them such as H&S or Mishimoto. Check eBay, you can get the Rudy's kit or similar for $100 or less. If it says make an offer, make an offer and they might accept.
here is where I installed mine a few years ago now.
https://www.ford-trucks.com/forums/1...t-install.html
Larry
larrgh is offline
post #5 of 5 (permalink) Old 07-18-2019, 05:34 AM
HeavyAssault's Avatar
My Photos: (6)
That cold side tends to be the bad apple at this point for the 6.7L.
2015 F-350 CCLB PSD 4X4 3.55 ELD
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
