Draining water separator? - Diesel Forum - TheDieselStop.com
 14Likes
post #1 of 32 (permalink) Old 01-03-2016, 10:57 AM Thread Starter
Okay so i would like to drain the water separator on the truck. I changed the filters about a month ago and did everything the manual said and ended up getting air in the system after purging and had to take to dealer. So before I do this I wanna be clear on everything. Every one says this is easy and it looks straightforward but I had a few questions. Once I unscrew the plug till I see the oring I will let it drain for 25 seconds as the Manua says but after I drain it do I need to cycle key 6 times to purge? And also does it matter how much fuel is in the tank? If anyone can answer these and tell me exactly how to do this with no problems it would be highly appreciated! Just thought I'd ask now before its to late! Thanks
Scag2400 is offline
post #2 of 32 (permalink) Old 01-03-2016, 11:20 AM
no, you do not need to do the key cycle. If you feel that it will make you more confident you will not have a problem like last time, do the key cycle. It will not harm anything doing it.
HeavyAssault likes this.
Larry
larrgh is offline
post #3 of 32 (permalink) Old 01-03-2016, 12:08 PM Thread Starter
So I can drain it for 25 seconds and then when I start the truck everything will be fine?
Scag2400 is offline
post #4 of 32 (permalink) Old 01-03-2016, 12:22 PM
Sure, but I don't see any need to drain it that long. a good 10 seconds will let you know if you need to drain more. Drain it into a clear container and let it sit a few minutes to see if any water settles out.
ford_doctor and jwbboat like this.
Larry
larrgh is offline
post #5 of 32 (permalink) Old 01-03-2016, 12:54 PM
Feedback Score: 2 reviews
I use glass baby food jars, I drain it till it fills up about 3/4 of the way and then close it up. Cap it and let it sit on a shelf until everything settles. Have yet to get any water in there but there should not be any being I have the diesel site filter system.
15 6.7 F350 CCSB 4x4 3.55s Platinum Bronze Fire
Husky mats, all LED interior, Nushield for MFT, Bakflip F1 with Bakbox 2.
blwnsmoke is offline
post #6 of 32 (permalink) Old 01-03-2016, 01:17 PM
I used a small glass jam jar and it got close to full after about 15 seconds so will use a bigger and wide mouth jar next time. Fuel came out at drain, then at pet cock so ended up spilling some as twin streams were wider than my jar. I checked the jar after it sat over night and no water at all.
2015 F350 XLT CCSB PSD, Ruby Red, 5th Wheel Prep
2012 Cougar High Country 229RKS fifth wheel
SkiSmuggs is offline
post #7 of 32 (permalink) Old 01-03-2016, 02:19 PM Thread Starter
Okay. I am going to to pick up a clear jar to drain it into and I will drain it for about 10 seconds and check
Scag2400 is offline
post #8 of 32 (permalink) Old 01-03-2016, 02:21 PM Thread Starter
How do you like the diesel site filter? And how hard was install and changing filters? I wanna get one but still under warranty
Scag2400 is offline
post #9 of 32 (permalink) Old 01-03-2016, 07:14 PM
nipperdog's Avatar
I think that the Diesel Site Filter/Separator is way overpriced for what you get @ $699. I have been thinking of mounting a Racor Marine Diesel Filter/Separator. It has a Bowl and Petcock on the bottom, and can pass up to 30gph of Fuel. The only advantage to the DS unit is no line splicing necessary. The Racor runs about $125.00, and replacement filters are about the same as the DS.
2016 F250 6.7 4X4 Lariat Crew 3.55 Locker
Traded 2011 F250 6.7 4X4 Lariat crew 3.55 Locker
Traded 2008 F250 4X4 Lariat 6.4 Supercab
nipperdog is offline
post #10 of 32 (permalink) Old 01-06-2016, 02:40 PM
Sorry I disagree with it being overpriced. While it is expensive it is VERY easy to install and has 2 filters. I do not have the ability to splice into the fuel lines or the desire to do so. This is my first diesel ever and I installed the DieselSite filter system in less than 10 minutes. Because of its design I can also completely remove it just as quickly as I added it.
If you plan on keeping the truck long term the cost then becomes very minimal for the protection you get. I know it is not for everyone but the design is great and that does come at a cost.
2015 F-350 Platinum Bronze Fire 6.7 PSD loaded from Scott Pratt at Fowlerville Ford
2011 Rockwood 2704 Travel Trailer
Elkhounds is offline
post #11 of 32 (permalink) Old 01-09-2016, 12:46 PM
What Elkhounds said!
daily double is offline
post #12 of 32 (permalink) Old 12-15-2018, 01:56 PM
I left my drain cock out to long. Now I have no fuel coming into the separater.????
Steve123057 is offline
post #13 of 32 (permalink) Old 12-15-2018, 02:43 PM
How much fuel did you let drain? After closing the drain, have you tried cycling the key?
Larry
larrgh is offline
post #14 of 32 (permalink) Old 12-16-2018, 05:36 AM
I ran into town to get new orings. so the hootus was out about an hour.
post #15 of 32 (permalink) Old 12-16-2018, 09:25 AM
ford_doctor's Avatar
What o-rings are you replacing? The thing most people neglect is the drain plug which is frequently difficult to open and causes air leak problems. When servicing your fuel filters take the primary filter cap and place it on a bench. Remove the pug and inspect it: it should have two o-rings and one thick square cut seal on the tip. It that is not there, look inside the cap as it is most likely stuck inside. Carefully remove it with a pick and stick it back on the plug. Clean the cap and the plug and before reinserting it into the cap, lubricate all three seals liberally with CLEAN ENGINE OIL. put it in and exercise it a couple of times. Draining your separator will now be easy and not mess up the seals. Do this every time you service the filters.
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
