Fuel Filter - Diesel Forum - TheDieselStop.com
 6Likes
  • 2 Post By ArcticDriver
  • 2 Post By larrgh
  • 1 Post By larrgh
  • 1 Post By CanichFarms
post #1 of 11 (permalink) Old 10-14-2018, 01:13 AM Thread Starter
Fuel Filter
Is there a better fuel filter over the Motorcraft, or just get the stock Motorcraft? I have looked on Rockauto.com, and noticed several brands, also the stock one for 57., where Amazon wants 119.00.
Spyderhauler is offline
post #2 of 11 (permalink) Old 10-14-2018, 04:59 AM
ArcticDriver's Avatar
Motorcraft filters are reported as top quality filters, whether its air, oil or fuel.
SOLD:
ArcticDriver is offline
post #3 of 11 (permalink) Old 10-14-2018, 09:07 AM
I have used a Fram fuel filter with no problems nor form or fit problems. In appearance of both filters and o-ring, appear identical to the Motorcraft. Makes me wonder if Fram is making these for Ford.
Larry
larrgh is online now
post #4 of 11 (permalink) Old 10-14-2018, 12:39 PM
79jasper's Avatar
Not the first time i've heard similar info. Even 6.0 fuel filters...
With that said, I still buy motorcraft. Lol
Sent from my SAMSUNG-SM-G930A using Tapatalk
79jasper is offline
post #5 of 11 (permalink) Old 10-17-2018, 12:54 PM
gearhead1011's Avatar
My Photos: (10)
I always use the Motorcraft, not enough price difference to even try anything else. I wouldn't use any fram filter if you gave me a truckload of them. Their oil filters are notorious for collapsing and causing engine damage. If their oil filters are garbage then I don't have any use for anything they have.
2012 F250 XLT
6.7 CCSB 4X4 Sterling Grey, B&W Turnover Goosenech Hitch, Air Lift LoadLifter 5000, 50 gallon Transfer Flow replacement tank, Weather Tech mats
gearhead1011 is offline
post #6 of 11 (permalink) Old 10-17-2018, 01:13 PM
have you ever had a fram give problems?......i never have had any problems with them and have used many over the years....so...might be a rumor you are passing on?
Phillippeterson and jwbboat like this.
Larry
post #7 of 11 (permalink) Old 10-17-2018, 09:13 PM
My Photos: (10)
Not on a diesel but on a gas engine in my shop. Used a customer's fram oil filter that collapsed due to the cardboard ends. End result was a failed engine and an unhappy customer. Fram had actually examined that filter, acknowledged that it had collapsed and refused to make good on it. Had 2 customers since then that had lifters clicking and low oil pressure right after they changed oil and used a fram oil filter. On both of those the problem was fixed by just changing the oil filter. Drag racer I talked to at the track that changed the oil pump and tore down his new engine trying to get the oil pressure where it should be. Fixed that by replacing the fram oil filter with a different brand. He was a little surprised when he asked me "you know what it ended up being?" and I said a fram oil filter. Was on a forum a few years ago and there was a thread that must have been 15 pages long and the overwhelming majority of those were the same bad experiences with fram. So no, it's not a rumor I am passing on. It's a real thing that has actually got into my wallet.
2012 F250 XLT
post #8 of 11 (permalink) Old 11-20-2018, 08:11 PM
I have had issues with fram filter and heard tons of stories online and a few in person where from filters were the problem. Definitely not a rumor at all.
CanichFarms is offline
post #9 of 11 (permalink) Old 11-20-2018, 09:03 PM
Used Fram filters for years.......so have my dad...never a problem.
badbart likes this.
Larry
post #10 of 11 (permalink) Old 11-20-2018, 09:09 PM
Be thankful that you have been lucky. I bet there are tons of stories just like yours where others never had an issue with fram filters. All someone can do is take it all in and hope they make the right decision.
gearhead1011 likes this.
post #11 of 11 (permalink) Old 11-28-2018, 06:24 PM
Motorcraft or Racor!
'04 F350SC Lariat sb cx 6.0 auto 4x4
'01 Exc. Ltd fu 7.3 4x4
'00 FLHTCUI sinister
'96 WX3 bbb
TwiceStroked is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
