Fuel Filter Change Interval - Diesel Forum - TheDieselStop.com
 4Likes
  • 1 Post By lincster
  • 2 Post By converted
  • 1 Post By COBRAJET
post #1 of 15 (permalink) Old 12-08-2016, 09:30 AM Thread Starter
What is the current thought on frequency of changing fuel filters? I am the original owner of a 2011 F350. Currently about 85,000 miles. Thanks.
Cajun Martini is offline
post #2 of 15 (permalink) Old 12-08-2016, 09:37 AM
jmadigan's Avatar
Ive seen every 20,000 miles or when the alert comes up
2001 PSD 7.3
4x4
ZF6 swapped
Crew cab
TS6 with custom tunes from Jody at DP-Tuner
HPX oil crossover
6637 MOD
CCV MOD
4" Turbo back exhaust side exit
EBPV gutted pedestal and Valve delete
jmadigan is offline
post #3 of 15 (permalink) Old 12-08-2016, 10:37 AM
Manual says every 22,500 miles or when information center tells you . That is under normal usage. I do mine at those intervals. The truck has only shown the "change fuel filter soon " once in 100,000 miles with my 2011. I haven't had to change it yet on my 2016. Hope that helps.
CascadeF250 is offline
post #4 of 15 (permalink) Old 12-08-2016, 03:10 PM
FordWilly's Avatar
As critical as they both are, especially with the fuel/water issue being so important, I change mine about every 12,000. I wait for my dealer to include them on my email maintenance specials and take advantage of the deal.
2011 Lariat Long Bed Crew Cab Dually 4X4
FordWilly is offline
post #5 of 15 (permalink) Old 12-08-2016, 09:47 PM
Depends on your usage. I change mine every 15k miles. 20k is acceptable for normal use.
karlduke is offline
post #6 of 15 (permalink) Old 12-09-2016, 01:42 PM
Driver's Manual should be the first place to look for such information.However, I have seen many people saying driver's manual doesn't say anything about it at all.General practice among owners is to change in every 20,000-30,000 miles.
Surprisingly, I read somewhere once,that Toyota doesn't recommend changing them at all.Not sure why.
Better you can call the Customer Service and ask directly.
ThomasRayman is offline
post #7 of 15 (permalink) Old 12-09-2016, 01:44 PM
lincster's Avatar
My Photos: (29)
I do mine every other oil change.
That is 10k miles for me.
Filters and oil are cheap compared to some of the repair costs.
shaark92 likes this.
2019 F350 4X4 Dually, FX4, Crew Cab, Ultimate Lariat Package, Agate Black, Black Leather towing a 2006 LE3905 Weekend Warrior
2002 F250 CC, 4X4 - Sold
2004 F350 CC, FX4, loaded - Sold
2006 F350 CC, DRW, FX4 - Sold
2012 F350 CC, DRW, FX4 - Sold
lincster is offline
post #8 of 15 (permalink) Old 12-10-2016, 01:18 PM
I will add that whatever the mileage is-once a year is on my list-I don't care if the truck's only been driven 7500 miles-still changing it late in the fall!
Mark
PSD 4x4 Custom Tow Vehicle-the 550
PSD 4x4 SUV-the X
PSD 4x4 F350 Duellie
PSD 4X4 F250 Crew-2017!
32' Open Triaxle Dovetail
22' Gooseneck Dump
Carriage Carri-Lite
PSD E450 Chassis Cab
PSD E550 Cube Van
SuperDutyFiver is offline
post #9 of 15 (permalink) Old 12-11-2016, 08:30 AM
2015_PSD's Avatar
I change mine every 15K as well.
2015 Tuxedo Black F-250 Platinum (FX4)
Currently running Chevron Delo 400 LE 15W-40 (CJ-4) oil and CQ Blue 84151 (Clarcor) oil filter
All Stock except for a few accessories:
- Rhino Spray-In Bedliner
- Ford Splashguard/Mudflaps
- Husky Rear Wheelwell Liners
- Bull Ring retractable tie downs
- Leer 700 Bed Cap
- Mag-Hytec Rear Axle Cover
- Mag-Hytec Front Axle Cover
- OEM Rear Sway Bar
- All interior & exterior LEDs including bed
2015_PSD is offline
post #10 of 15 (permalink) Old 12-11-2016, 05:48 PM
Every 10k miles. I marry mine up with 5k oil changes...easy to do and no worries.
Cale
shaark92 and CajunMick like this.
Cale
US Navy 1995-Present
2015 F-350 CCLB DRW, Lariat,
2nd Gen. 6.7L "Scorpion" Turbo Diesel,
440HP/860TQ, Torque Shift 6-speed,
Metallic w/Black Leather Interior,
14,000 LB GVWR,
4x4,
4.30 Gears,
Factory 5th Wheel/Gooseneck Prep Pkg.,
Spray In Bed-Liner,
Supplemental Cab Heater,
Camper Pkg.,
Upfitter Switches,
98 gallon Transfer Flow Bed Tank,
Timbrens,
10,150 lbs (CAT),
29,950 lbs with 2014 Voltage 3950 Toy Hauler (CAT).
converted is offline
post #11 of 15 (permalink) Old 12-12-2016, 10:46 AM
Stick with annual at least. I just changed mine out, low miles but long time. There was sediment on the frame mounted filter. The bulk of my fuel comes from an above ground tank with with it's on filter.
Nickel is offline
post #12 of 15 (permalink) Old 12-13-2016, 10:48 AM
I follow the truck manual guidelines. But sometimes change sooner than later.
Most important for me is to drain fuel from frame filter bowl, collect fuel in clear glass, inspect fuel for contamination. Do this frequently, every month. And buy fuel from stations I hoping trust.
I don't drive often (5 yrs and 62k miles so far). And visit Ford web or Sync site, record fuel check in my truck maintenance data. Keeps my record and Ford folks honest if they question any maintenance records of this vehicle.
Stopped at a out of state station, seen tanker truck getting ready to dump fuel in tanks. I asked if he dumping diesel, told me not yet, doing gasoline at the moment, but will wait on diesel dump till I fueled up. Clearly he knew why I asked. Thanks.
CajunMick is offline
post #13 of 15 (permalink) Old 12-15-2016, 10:02 PM
Painted Horse's Avatar
I change the oil when the Command center Oil life indicator shows. Which is about every 7500 miles. Fuel and Air filters ever other oil change. So about every 15,000 miles
15 F350 CC Lariat SRW LWB Ruby Red, Ultra Predator Wheels with Toyo 295/65R20, BAKflip Fibermax tonneau, Diesel Products LED lights in the rear bumper and 20" light bar in the front bumper, Firestone Airbags and Airllift Wireless compressor.
11 F350 CC Lariat SRW LWB Tuxedo Black Sold at 145,000 milesl
Painted Horse is offline
post #14 of 15 (permalink) Old 12-21-2016, 07:51 AM
like said above, with the water and fuel issues and Diesel pumps around me not moving much diesel, i drain the frame filter once a month, and change filters every 10k miles....cross my fingers..never thought i would say this, but i dont want to sell my 6.0
KDAWG97M3 is offline
post #15 of 15 (permalink) Old 12-21-2016, 09:58 PM
I have always changed my oil every 5K miles and the fuel filters at 15K. Mine get a pretty good work out in warm to hot weather grossing at 25.5K. I drain the bottom fuel filter at every oil change. There is usually nothing but fuel in there. I guess I get good fuel most of the time. I predominantly purchase at local QT's or truck stops while towing the RV. The filters can be had online for pretty good prices. I run WIX filters.
2016 F350 KING RANCH DRW, 4X4, RUBY RED/CARIBOU, 3.73'S, LOADED, TUNED, ARE FLAT BED COVER, SPRAY IN LINER, 2.5" RANCHO FRONT LIFT, 3" REAR LIFT, RANCHO 9000 XL'S, 255/80/17 BFG MUD TERRAINS, EBC BRAKES, RADIO LOCKPICK, FRONT LIGHT BAR AND REAR FLUSH MOUNT LED'S.
COBRAJET is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
