Oil change and installation of EZ Drain valve - Page 2 - Diesel Forum - TheDieselStop.com
 16Likes
post #16 of 26 (permalink) Old 02-28-2017, 04:02 PM Thread Starter
Originally Posted by shaark92 View Post
Given my bad experience with the 7.3 pans ... I think a plastic one would be better anyway ... TIC. :P
I laughed hard, though, when you mentioned the flow rate. The first time I did this, I had no idea. I had the VERY same catch pan you flashed into your video ...
I testify ... what you say is TRUTH! Oil was EVERYWHERE! I now have an old school open top galvanized pan ... 15 quart capacity (which the dealership overfilled last time) Now I'm an RLI oil guy.
oil analysis pending.
Renewable Lubricants | Home
I get the 5w-40 HDMO low ash
Dang, that was an Oh Crap moment. But take heart, it's comments like yours that made sure I made that point. I hate even a few drips and can only image about 10 quarts going over the rim. That plastic one that I'm using is a 5 gallon capacity with curved-in top edge so it does nicely.
shaark92 likes this.
CURRENT: 17 F350 Platinum Ultimate
FORMER: 11 SD 6.7L CC SWB White Platinum Lariat Ultimate
2" Auto Spring leveling kit (required caster correction)
315/60/20 Toyo MT's
Line-X Bedliner/Door Seal Mod
DDM Tuning HI/Low HID's (H13, 55W, Color 5,000K)
Titan 50 gallon tank
EpicCowlick is offline
post #17 of 26 (permalink) Old 02-28-2017, 06:11 PM
shaark92's Avatar
My Photos: (9)
Oh ... I meant to add ... since having changed my fuel filters this past week ... I noticed you still had the factory filter ... 3rd line on the eng-compartment canister.
Al
2011 F350 SuperCab XLT DUALLY 4x4 6.7 AT ... C&M flatbed, air springs with cab controller, H&S tuner, DPF delete "Hulled", EGR block
Tows a 24' Cattle Trailer, 28' Flat Bed Dove Tail.
SOLD: 2000 F350 XLT SRW 4x4 7.3 ZF6 ... AFE Intake, MBRP 4" exhaust, DP Tuner, ceramic coated exhaust manifolds/up pipes.
shaark92 is offline
post #18 of 26 (permalink) Old 02-28-2017, 06:24 PM
meteor56's Avatar
I had the EZ valve on my 7.3, and the Fumoto is on the 6.4. The Fumoto came with a clip that locks the handle in place, keeping it from accidentally opening. Yeah, I know that it could still be ripped out. Both valves can be fitted with a 90-degree drain if you don't have much in the way of clearance. Also I put Teflon tape on the threads.
It makes things much easier and cleaner for doing periodic oil samples.
My stock filter setup is gone; mine is now located behind the bumper on the driver side. I punch a hole in the bottom and let it drain (there's a lot of oil in the hoses).
larrgh and shaark92 like this.
meteor56 is offline
post #19 of 26 (permalink) Old 02-28-2017, 07:06 PM
yup...still appears to be a bit of OCD on the valve and fast vs slow drain.....guess a titan fuel tank hanging 6" lower than stock tank is out of the question also...
If there was a problem with these valves, EZ-Drain or Fumoto, the forums would be full of bad comments and how they broke or opened randomly or failed or......
But, you know what? I haven't seen any complaints on any forum I visit about the drain valves failing or being knocked off.
shaark92 and Phillippeterson like this.
Larry
larrgh is online now
post #20 of 26 (permalink) Old 03-01-2017, 06:28 AM
DAP
DAP's Avatar
And its much easier to get an oil sample for testing.
2011 F-350 DRW Lariat Ultimate 4 X 4 FX4 Royal Red ordered 5/21 Picked up at dealer 7/9/2010-2007 Newmar 38' Fifth Wheel
Sold:Only 48000 miles-'99 PSD Lariat SRW 4X4 Banks PowerPack-DP Tuner-Wood Dash Kit-Air suspension-PaceEdwards Roll Top-US Gear Exhaust Brake-Gear Vendors Gear splitter-Isspro Gauges-Transgo shift kit tranny -Mag Hy Tech transmission pan and Diff. cover-HX kit-PaceEdwards roll top cover-Reese 14000 lb. Fifth wheel hitch-Alcoa Rims with new Michlin tires
DAP is offline
post #21 of 26 (permalink) Old 03-01-2017, 10:54 AM
Texkenusmc's Avatar
Epic Cowlick find a five gallon bucket with a screw on lid it makes dumping oil easy. If you know anyone with a pool who orders their chemicals in bulk they will have some. I have plenty of them.
Texkenusmc is offline
post #22 of 26 (permalink) Old 05-17-2017, 01:42 PM
wpetko's Avatar
My Photos: (17)
Originally Posted by EpicCowlick View Post
Yeah, it's just a gadget. The thing I hate the most is emptying the 13 quarts from the drain pan into the oil jugs for recycling. It's always a balancing act pouring the old oil into a funnel while trying not to tip over the jug or overfill it. I'll store up a few milk jugs and just fill those with the hose from the valve. Should be drip free and no messing with the full drain pan. That's a plus?
Try this trick. I have an old 5 gallon gas can that fits under my truck. I drain the oil into it using the 3/8" tubing attached to my Fumoto Valve. I do have to use a catch pan under the oil filter. 'No way around that.
Also, try removing the oil fill cap on top of the engine, place the hose of your shop vac over the tube & turn on the shop vac. No. You aren't vacuuming any oil out of the engine. 'Just putting a little negative pressure (vacuum) on the engine internals. Now go under the truck, remove the drain plug & oil filter. No oil should drain at all, but have a catch pan in place just in case. When you remove or turn off the shop vac the oil will drain normally, but you won't get any on your hands or make a mess. I have even removed the drain plug & installed a Fumoto Valve for myself & for others between oil changes & never spilled a drop using this method.
larrgh likes this.
2013 F-350 Lariat 6.7 L PSD Crew Cab Dually, FX4, white platinum metalic tri-coat with black interior, N-Fab step bars, factory spray-in bedliner and 5th wheel hitch, trailer tow package, integrated brake controller, upfitter switches, Sync with My Ford Touch, memory group, remote start, reverse sensing with rear view camera, nav, satillite radio, Weather Tech floor mats, limited slip diff, moon roof, climate controlled seats, engine block heater and tailgate step.
2014 Lifestyle (formerly Carriage) 5th wheel 38' long with 3 slides & all the goodies.
SOLD: 2005 F-350 Lariat, 6.0 PSD, Torqueshift auto trans, crew cab, SRW, short box, FX4, ESOF, limited slip dif., tow command, upfitter switches, 6 CD changer, Lariat Lux. package, camper package, engine block heater, triple A-pillar gauge set (Autometer) with pyrometer, trans temp & voltmeter, MBRP 4" cat back exhaust w/5" dual wall chrome tip, dark shadow gray/ med. flint interior.
wpetko is offline
post #23 of 26 (permalink) Old 05-17-2017, 03:29 PM
lincster's Avatar
My Photos: (29)
You guys are going to an awful lot of work.
I just use a 5 gallon bucket, take the plug out and catch the oil.
Filter, loosen slightly, jamb a screw driver through the bottom, let drain for 15 min, remove filter.
Not 1 drop of oil on my driveway.
CascadeF250 likes this.
2019 F350 4X4 Dually, FX4, Crew Cab, Ultimate Lariat Package, Agate Black, Black Leather towing a 2006 LE3905 Weekend Warrior
2002 F250 CC, 4X4 - Sold
2004 F350 CC, FX4, loaded - Sold
2006 F350 CC, DRW, FX4 - Sold
2012 F350 CC, DRW, FX4 - Sold
lincster is offline
post #24 of 26 (permalink) Old 05-20-2017, 05:09 AM
I had no issues with changing oil at every 3 or 4k miles for 125k on my 2011's plastic yellow drain plug.. liked it actually was very easy to do.. I have the EZ type valve now and don't like it... takes way to long and have to fool with the hose,etc. I have a large FloTool 58qt that works well.
2016 F350 Lariat Copperfire Bronze,Black Leather Crew Cab,Short Box SRW. Supplemental Heater,3.55 ELD, Remote Starter. Used for hauling 16ft x 8.5ft. Work Trailer , 8ft. Fisher Plow, Lance 820 truck camper for those days I can get away.
Captcaper is offline
post #25 of 26 (permalink) Old 05-24-2017, 11:18 AM Thread Starter
I did a second oil change and this time I used the slick little valve that I installed the first time around. I have to say it's pretty effortless. I used a 3/8 inch vinyl tube stuck right into an old yellow diesel fuel can, opened the valve and it was done in 15 mins. I left it there for another 5 just to see if anymore oil came and and no. I still used a little catch pan for the filter but like stated above, I don't see a way to do that easier. Best part is that I didn't have to pour the contents of that huge, heavy drain pan back into the empty oil jugs. First time I've done an oil change without some oil on my hands and at least a few splatters on the floor.
315/60/20 Toyo MT's
post #26 of 26 (permalink) Old 10-29-2017, 12:49 PM
As a boater, I've owned a 12v boat oil change pump setup for 15 years. On the boat, it's used to draw oil back up the dipstick tube (because you can't get underneath an engine down in the engine compartment). Anyway, the motor is bolted to the top lid of a 5 gallon bucket. It is reversible so that you can draw the oil out the engine, then pump it into your waste container. It makes it very easy to get the oil out of the drain pan after draining your car/truck oil. No more mess, no worrying about balancing pans and pouring into waste containers. Pricey, but everything "boat" is.
roadPilot is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
