Serpentine belt idler and tension pulleys - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 03-10-2019, 08:58 PM Thread Starter
I just replaced a idler pulley to get rid of an engine vibration. I have a 2013 with 80k on it. Are these common replacement items?
BlueJay88 is offline
post #2 of 6 (permalink) Old 03-11-2019, 05:00 AM
They are not common as in needing replaced on a set schedule but they do include a bearing that can fail and the rubber insert that provides the tension does weaken over time.
Larry
larrgh is offline
post #3 of 6 (permalink) Old 09-14-2019, 01:32 PM
I realize this is an older post but i'm getting ready to replace my water pump so since I'm tearing everything off the front of the engine I'm going to replace the tensioner and idler pulleys. Are the two idler pulleys the same size/part #? I have a 2014 if that makes a difference.
TAAP is offline
post #4 of 6 (permalink) Old 09-14-2019, 06:39 PM
There is a fan hub you want to check also. It is an "idler" that the fan clutch screws onto.
Maybe these two photos will help you decide how many there are.
Larry
larrgh is offline
post #5 of 6 (permalink) Old 09-15-2019, 11:39 AM
Thank you! That's what I was looking for but didn't see one with the part numbers. This is all preventative, I put a lot of miles on the last 2 years and I just want to make sure I stay ahead of any potential problems.
TAAP is offline
post #6 of 6 (permalink) Old 09-15-2019, 04:36 PM
go to these Ford parts and look up the idlers. The basic part number/category is shown in the diagrams.
http://www.tascaparts.com/partlocato...?siteid=213668
http://parts.autonationfordwhitebearlake.com/
Larry
larrgh is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
Similar Threads
'08 F350 tensioner, idler pulleys and belt change 08harleyf350 6.4L Power Stroke Engine and Drivetrain 0 02-08-2017 12:19 PM
Idler pully & tension pully bearing part number Extreme '99 & up 7.3L Power Stroke Engine and Drivetrain 3 12-28-2007 08:48 AM
Serpentine Belt Replacement boatingncst8fan 6.0L Power Stroke Engine and Drivetrain 23 12-19-2005 01:59 PM
HELP...trying to remove Idler Pulley (under the tension pulley) PSDfreak Power Strokes 1994-1997 General 12 11-25-2005 09:19 PM
My 99 is eating serpentine belts, belt "rides" up AC pulley... Glenstr '99 & up 7.3L Power Stroke Engine and Drivetrain 16 03-30-2005 01:03 PM
