Strange noise after shutdown. - Diesel Forum - TheDieselStop.com
post #1 of 191 (permalink) Old 04-13-2011, 01:24 PM Thread Starter
jermort's Avatar
Post Strange noise after shutdown.
Okay, the truck always made a few strange noises after shutdown, but this is new and annoying.
Here's the scenario: Truck is warm and no CEL. A few seconds after shutdown, I hear all the normal(?) noises and then after a few seconds of silence, a noise that sounds like a vacume pump running starts and continues for about 20 to 30 seconds. Cycling the key, but not starting the motor will cause the noise to happen again and again on each key on/off cycle.
The noise seems to be comming from the top front of the motor.
Could this be fuel pressure bleeding off? Is there a check valve that is maybe not doing it's job??
Stumped
jammer
PSD #4 - '95 loved it... '97 real POS...
2000 ... great truck, 200k miles...
Last????
2011 F250 KR Lariat CC
jermort is offline
post #2 of 191 (permalink) Old 04-13-2011, 01:35 PM
I dont know how it is on a 6.7 but on my 6.4 i would hear a pump sounds like a fish tank pump, turns out i had a vacum leak, the pump is located by the master brake cylinder, on the fuze box/power box dont know where it is on the 6.7
nailz53 is offline
post #3 of 191 (permalink) Old 04-13-2011, 01:39 PM Thread Starter
jermort's Avatar
I think the vacume pump on the 6.7s is driven by the accessory belt. This sounds similar, but is definately comming from the top front of the motor. Haven't been able to isolate the exact location, but is in the neighborhood of the HPOP or fuel filter.
jammer
Last????
jermort is offline
post #4 of 191 (permalink) Old 04-13-2011, 01:42 PM
dsroka80504's Avatar
It might also be the DEF pump, not sure where that is located, probably not in the engine bay, but noise could travel. The pump sucks all of the DEF out of the DEF line after shut off I believe.
2011 F350, CC, SB, Lariat Ultimate, Chrome Package, 4x4, FX4, White Platinum, 6.7L (SOLD)
2001 F-250 CC Lariat, LB, 4x4. 205K and Traded in
1996 F-250 XLT Regular Cab, 4x4, 187K. Bartered for construction work.
2010 Cougar 32RLB 5th Wheel - Traded in 1/22/11
2011 Road Warrior 30C Titanium Edition (SOLD)
dsroka80504 is offline
post #5 of 191 (permalink) Old 04-13-2011, 01:45 PM Thread Starter
jermort's Avatar
DEF pump is on the DEF tank, no DEF lines are under the hood, all are under the chassis mid truck.
jammer
Last????
jermort is offline
post #6 of 191 (permalink) Old 04-13-2011, 07:09 PM Thread Starter
jermort's Avatar
Here's the noise with the hood closed. With the hood open, noise is most definately from top front of motor.
jammer
Last????
jermort is offline
post #7 of 191 (permalink) Old 04-14-2011, 11:12 AM Thread Starter
jermort's Avatar
jammer
Although the video is from outside the truck, when I open the hood, the noise is from right on top of the motor at the front, more on the left side than the right.
jammer
Last????
jermort is offline
post #8 of 191 (permalink) Old 04-14-2011, 05:01 PM
If it concerns you, why not let a Ford Dealer tell you what it is?
RonD is offline
post #9 of 191 (permalink) Old 04-15-2011, 07:17 AM
JimTJr's Avatar
My Photos: (20)
jammer
Can't be by the HPOP,, as we don't have one of those on the 6.7....
I agree with Ron,, why in the world have you not taken it to the dealer? I certainly would,, as mine does NOT do that,, I do hear the turbo spooling down after shut down though! (Normal on all the turbo diesels....LOL)
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB.
New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline
post #10 of 191 (permalink) Old 04-15-2011, 09:56 AM Thread Starter
jermort's Avatar
My bad, meant the HPFP.
Okay, here's an update.
The motorboat definately starts immediatly following the EGR closing noise.
Crawled into the hood yesterday, put my ear as close as possible, still cannont hear where the damn noise is originating from. Felt around for vibrations, nothing. Seems like the intake plumbing is amplifying/transmitting the noise all over the left side of the motor. Hmmmmm
Going to the dealer on Mon. If only I trusted these guys........
jammer
Last????
jermort is offline
post #11 of 191 (permalink) Old 04-17-2011, 06:02 PM Thread Starter
jermort's Avatar
Okay, new information; when the noise starts, a tap of the brake pedal silences the noise! Vacuum issue? Booster issue? Getting close to a solution.
jammer
Last????
jermort is offline
post #12 of 191 (permalink) Old 04-17-2011, 06:17 PM
Vacuum boost brakes or hydro boost? ABS pump maybe.
'06 F250 Crewcab King Ranch 4X4 auto Black 6.0 stolen 12/31/14
by clifford bledsoe.
'09 Cameo 5thwheel home while working
'02 Eddie Expedition
'91 F250 SuperCab 4X4 Stock IDI 2 tone brown E4OD
'96 IH 7.3 4700LP field mechanic
'84 Bronco II 2.8 4 speed 4X4
'50 F-1 V8 Flathead 4-speed non syncro(bought new)
'76 Honda 250 Multi Sport(enduro)
'76 F250 4x4 standard 360 Highboy
mont91 is offline
post #13 of 191 (permalink) Old 04-17-2011, 09:22 PM Thread Starter
jermort's Avatar
Definately a vacuum issue. Once I discovered the association with the brake booster (vacuum boost on 250s), I can stop the noise by unplugging any of the vacuum lines that I can find.
jammer
Last????
jermort is offline
post #14 of 191 (permalink) Old 04-18-2011, 09:25 AM Thread Starter
jermort's Avatar
Anyone out there have a diagram of the vacuum system for F250's?
I'm thinking there is a check valve on the vacuum line right at the vacuum pump. That would make sense and would keep the pumped down vacuum from bleeding off.
Seems that that check valve (if it exists) is having a conversation with the whole system. That conversation manifests itself as my 'motorboat noise' and is initiated by the EGR closing event which causes a 'burp' in the entire system.
Ahh, the joys of a new series of truck!
I really wish I could have a conversation with a Ford engineer that worked on the vacuum system on these trucks!
jammer
Last????
jermort is offline
post #15 of 191 (permalink) Old 04-18-2011, 01:56 PM
FordService's Avatar
jammer
I can definitely see why youd want to pinpoint where a noise like that is coming from. If you would like my assistance with the concern, send me a PM, and I will re-open and escalate a case for you!
Cory
FORD SERVICE
p: 800.392.FORD
t:
f:
FordService is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
