Vibration-Bounce at 40mph 65-75mph - Diesel Forum - TheDieselStop.com
 1Likes
post #1 of 21 (permalink) Old 03-06-2015, 12:40 PM Thread Starter
2013 Super Duty long bed 4x4 have continued vibration seems like wheels and tires have had dealer replace tires and change wheels and replaced shocks. Now they are saying some do it worse than mine and basically refuse to do anything further. Have friends with 2011 and 2014. The 2011 is King Ranch and has no vibration 20" rims and tires factory. The 2014 has similar vibration bounce but stops faster than mine as mine continues for quite a bit longer. See numerous threads regarding frame harmonics but no solution to fix. Like truck other than this annoying bounce. Worse in rear seat than front. Any new info on Ford actually helping to solve this problem?
River Runner is offline
post #2 of 21 (permalink) Old 03-06-2015, 02:10 PM
Thom12's Avatar
4 1/2 years since I first started the post about the rear end bounce @40-45 mph and sorry to say, no solution has been offered by Ford.
Thom
Panama City, Fl area
2011
F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 5th wheel prep, factory 5'er and gooseneck hitches, 331 E-locker, factory bedliner. Duraflap mud flaps. Viair onboard air compressor. Firestone airshocks. Weathertech window vent shades.
1996
F-250 super cap XLT 7.3 PSD 200,000 miles.
1953
F-100 Deluxe cab, 50th anaversery in midst of frame up restoration.
Thom12 is offline
post #3 of 21 (permalink) Old 03-06-2015, 03:33 PM
lincster's Avatar
My Photos: (29)
I've had 4 super duties from 2002 to current.
All have done this when unloaded.
Hook on a heavy trailer and it goes away.
Go figure, use the truck for what they are designed for and they ride nice. LOL
HeavyAssault likes this.
2019 F350 4X4 Dually, FX4, Crew Cab, Ultimate Lariat Package, Agate Black, Black Leather towing a 2006 LE3905 Weekend Warrior
2002 F250 CC, 4X4 - Sold
2004 F350 CC, FX4, loaded - Sold
2006 F350 CC, DRW, FX4 - Sold
2012 F350 CC, DRW, FX4 - Sold
lincster is offline
post #4 of 21 (permalink) Old 03-06-2015, 06:41 PM
Your 65-75 bounce, is this happening on concrete freeways? If it does, the issue is the road. The expansion joints are what's doing it. As the concrete ages they raise at the joint. Between that, the distance between them, and the wheelbase of the truck, causes it to bounce. I get the bounce and I just have to find a smoother lane to drive in. It's also worse when cold out. It also stops when I go across an overpass then starts again once I've passed it.
2013 Ford F-350 CC LB 6.7 Lariat 4wd
mlation02 is offline
post #5 of 21 (permalink) Old 03-07-2015, 12:59 AM
loft306's Avatar
i have that at 75-85 on WOT its annoying but goes away above and below it i figure its just wheel balance or another rotating thing like drive shafts or something out of balance... it used to freak me out.
I also get the 65-70 mph rock and roll from the concrete joints in the road in my 2015 ext cab long box didnt get that in the sort wheel base reg cab/long box. and its worse in the neighbors crewcab.
i'm still trying to sort the 43MPH Thunk but my 08 had that too when empty i'm leaning to the leaf springs jouncing or just weird harmonics, on the 08 i thought maybe it was the ls rear end but i have a elocker on this so its wide open at 45
I don't know if this has been tried yet or not my friend has a F350 cab chassis with a service body that they just couldn't get the tire balance rite on it was rite at 45-60 it was off 65-80 or visa versa, it was a nightmare till he went to a local automotive tech school that has a road force balancer and hasn't had the issue since. no vibration at any speed. i laughed at him, thought he was nuts till i road in it once b4 it was fixed.
just my .02 cents
~ Mike
2015 Magnetic F350 XLT SC, LB, SRW. 6.7. 3.55el. 4X4 Gooseneck. Ordered: 10/15/14 ||StickerIssued 10/28/14||BuildDate 11/3||ProducedDate 11/5/14||RailShipped 11/7||ArrivedDealer 11/17/14||SoldDate 11/24/2014||FirstPlow 11/24
2004 Featherlite STL 14,000#, 24' Gray, popup bevertail, slide in ramps bought 6/2015
2008 BLACK F350 XLT RC SRW 4x4, 6.4, Auto,3.73ls, ManualTransferCase,PTC-Heater. She is Sweet...
DORA recieved:9/14/07 ||ProducedDate:11/21/07 ||ShipDate:11/24/07 ||SoldDate:11/30/07 || Traded 11/24/2014
1983 CutlassCiera | 1979.5 K5 blazer | 1997 jeep TJ
loft306 is offline
post #6 of 21 (permalink) Old 03-07-2015, 11:21 AM Thread Starter
According to most threads the balancing does not help. In my 2003 I never had any of problems of these mentioned and after reading some the Rancho shocks were mentioned. My 03 had Rancho shocks and my friend with 2014 that does not bounce as bad as mine has Rancho shocks. Putting a pair on the Rear today to test. Will post results after full testing.
post #7 of 21 (permalink) Old 03-07-2015, 11:50 AM
My '06, '08 & '11 didn't/don't have it. The '08 did have the driveline shudder at low speed with a trailer. My guess is they are engineered so exactly that it shows up if there is a small variation from design specs.
Nickelplated5s is offline
post #8 of 21 (permalink) Old 09-28-2016, 04:41 PM
Unhappy 2011F-250 45-50 hop 70+ wobble
I have an annoying hop between 45-50 mph and a vibration about 70-75 mph. New tires that was forced balanced, new bilstein shocks and steering stabilizer. still hop / vibration. Any ideas or solutions?
Tseaboch is offline
post #9 of 21 (permalink) Old 10-06-2016, 10:45 AM
Thom12's Avatar
Yes, actually there is a new "FIX" from Ford, I haven't tried it yet but some folks are reporting positive results. Read this NEW VIBRATION OR HOPPING TSB - Ford Truck Enthusiasts Forums
Thom
2011
1996
1953
Thom12 is offline
post #10 of 21 (permalink) Old 06-30-2019, 03:13 PM
My truck is a 2011 F250. 76k miles.
Bouncy at 42-45 mph. Carrying no load, just a run to hardware store. By myself. Annoying, yes!
Recently driving on new blacktop road, speed in ~40-47 mph range with 4 souls on board, no bouncing!. Biggest complainer was MiL. This time no complaints. So, is extra weight in back seat a force balance multiplier?
I did try couple of 50 lb sand bags in the bed, over the axle, and it seems to help some. But maybe I should have tried 4 bags instead? Didn’t do it.
Just keep bouncing.....
CajunMick is offline
post #11 of 21 (permalink) Old 08-02-2019, 01:17 AM
I have a 14 CC dually and mine does the same bounce and most noticed in the 40ish range. I have noticed when I have the family and 3 adults in the back seat the bounce is nearly eliminated. I was trying to come up with some type of ballast to put in the cab behind the seat or in the storage bins.
Tom
02 CC XLT Dually 4x2, PSD w/6 spd, White w/Med Flint 40/20/40, TTT Mirrors, 4.10 L/S, PCM=AEB4, Receiver, Cab Steps, Homelink X Visor, Husky F&R Mud Flaps, AIS Ford Filter, WD Pyro & Boost in A-pillar, Line-X, Hutch Tank Mod, Pre-Pump Racor 645R30, 4" Banks Monster Exhaust, Mag-Hytec Diff Cover, Amsoil in Tranny & Diff.
Bye-bye 99 diesel-sucking automatic!!!
tomshep is online now
post #12 of 21 (permalink) Old 08-03-2019, 06:43 PM
Tom, what ever you do, if it solves the 42-47 mph bounce, let us all know about it. Might want to start new post so it will be up front.
Now is wondering if added weight of pax in rear seat if something about body to frame mounting hardware?
Was driving truck today with wife in it, but had a radial arm saw in back, plus another not too heavy weighed device. Nothing in the back seat area. Wife never said a word.
After we unloaded the stuff at son’s house, returning home, within first few miles, wife asked why truck bouncing! Told her it is the “nature of the beast”, per Ford engineers. She said they full of cr*p. No wonder why her mom won’t ride in this beast.
I just smiled.
post #13 of 21 (permalink) Old 08-03-2019, 06:57 PM
badbart's Avatar
My 2011 does it too. I have a toolbox mounted right behind the cab and it has about 300 pounds of tools in it, doesn't make any difference. What I did notice though is when I have my fifth wheel hitch mounted in the bed along with the toolbox I don't notice it as much. It weighs about 150 pounds.
It seems you need more weight toward the rear of the truck to make a difference. Ford did make a dampner for some early model trucks with this problem with mixed results. They were 2007-2008 IIRC. It was a technical service bulletin, not warranty. I believe they charged about $350 back then. It was a heavy steel weight, about 75-100 pounds that they mounted to the rear of the frame behind the rear axle. It had a thick rubber bushing to disperse harmonics.
2011 F350 4x4 XL Crew Cab Dually
2010 Keystone Fuzion 405 Toyhauler
badbart is offline
post #14 of 21 (permalink) Old 08-03-2019, 11:56 PM
I also have an aluminum box across the bed which ties the upper bed rails together near the cab. I probably have 200 lbs in mine and it doesn't make a difference that I can tell.
I looked into the frame dampener. It bolts on the driver's rear frame rail just in front of the bumper on the outside. The TSB carries all the way to at least 2014 because my truck falls under it. Problem is the unit is now $750 and not covered under ESP. If you are under 3/36 my dealer said they could have covered it.
Tom
post #15 of 21 (permalink) Old 08-04-2019, 04:32 AM
badbart's Avatar
An odd looking contraption isn't it?
PART NUMBER PART NAME
5C3Z-5D008-A Damper Service Kit
https://www.ebay.com/p/Ford-9C3Z5D00...per/1911152329
badbart is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
