What goes here? - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By dlnoss
post #1 of 9 (permalink) Old 06-22-2019, 09:18 AM Thread Starter
What goes here?
Just got this back from the shop. It looks like some hose or something is missing.
dlnoss is offline
post #2 of 9 (permalink) Old 06-22-2019, 09:59 AM Thread Starter
I found a hose that had apparently been tucked out of the way while the turbo was being replaced.
dlnoss is offline
post #3 of 9 (permalink) Old 06-22-2019, 12:47 PM
It is part of the secondary cooling system. It cools the air coming through the CAC (inter cooler) along with other items.
I would take it back to the shop that replaced the turbo and have them fill the secondary cooling system with coolant at no cost.
Here are diagrams of the primary and secondary cooling systems.
Name:	Primary Cooling.JPG
Name:	Secondary Cooling.JPG
Larry
larrgh is online now
post #4 of 9 (permalink) Old 06-22-2019, 05:28 PM Thread Starter
Does only air go through it? It certainly doesnít look like a liquid hose. Is filling the secondary system something that should have been, and may have been, done with the turbo replacement? Sorry for my diesel ignorance. Iím going to be leaving on a long pull before the dealer opens back up on Monday.
dlnoss is offline
post #5 of 9 (permalink) Old 06-22-2019, 05:57 PM
I might be wrong...first appearance it appeared the photo was the inter cooler......but might be wrong....maybe Ford Diesel Doctor will read and reply.
Any moer photos?
Larry
post #6 of 9 (permalink) Old 06-22-2019, 09:44 PM Thread Starter
The hose went to a rectangular plastic box close to the firewall and has a twist type release on it.
dlnoss is offline
post #7 of 9 (permalink) Old 06-23-2019, 06:40 AM
HeavyAssault's Avatar
My Photos: (6)
Crank Case Vent??
2015 F-350 CCLB PSD 4X4 3.55 ELD
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
post #8 of 9 (permalink) Old 06-23-2019, 07:08 AM
ford_doctor's Avatar
It is the crankcase vent. With it disconnected the check engine light should be on... you are sucking in un-filtered air into the engine... which is also un-metered air that will cause performance issues, EGR faults and exhaust aftertreatment concerns if left off long enough.
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is online now
post #9 of 9 (permalink) Old 06-23-2019, 08:01 AM Thread Starter
Thanks! I didn't have a check engine light or any codes. I drove it about 20 miles before discovering and reattaching.
HeavyAssault likes this.
dlnoss is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Power Stroke Engine and Drivetrain
