6.7L dpf delete pros and cons - Page 13 - Diesel Forum - TheDieselStop.com
6.7L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty truck with 6.7L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.7L Power Stroke engine.
 35Likes
post #181 of 192 (permalink) Old 06-06-2016, 11:13 AM
Originally Posted by chingaling View Post
When doing a change-over to conventional exhaust, does one have to do a def delete, if so,how ?
Newbie
What year and motor?
I have a 2011 6.7. I did a complete delete. If you remove DPF you will need a tuner. From before deletes to after, complete different acting truck. So much power its insane. You can find complete kits on Ebay. I went with a Mini Maxx tuner, Sinister EGR delete kit, S&B cold air intake and FLo Pro 5" Stainless exhaust. Cost me $1600.00. Did it in my driveway over a weekends time. Highly recommend.
Swfhawgkiller is offline
post #182 of 192 (permalink) Old 08-28-2016, 12:54 AM
I'm not looking for more power or anything else. I'm perfectly happy with the way my truck runs and pulls. My 2012 only has 56K miles on it and my dealer says the DPF is cracked and it is out of warranty and will cost $2,800 to replace it!!!! I am just looking for a permanent fix because I can't afford to spend $2,800 every 56K miles.
2012 F350 XLT CC RWD Dually.
'97 F250HD CC 4WD PSD & E4OD. Synthetic ATF. Two 30,000 GVW trans coolers, 4.10, Draw-Tite front receiver. 83psi unshimmed, 10k ohm resistor, Raider shell, 2 meter amateur radio
Michael Digangi is offline
post #183 of 192 (permalink) Old 08-28-2016, 12:26 PM
For that kind of money you can fix it one time and never have to worry about it again.
As for not wanting more power, that's easy. Keep you foot out of it and it'll drive like a couch. "Too much power is just about right."
Give us a call, we'll tell you all about it.
Dougism -
"I want the government out of my business, out of my bedroom and out from underneath my truck."
"Our government has only two jobs; Protect our Borders and Protect our Money. They are doing neither."
Doug Lewis
Ford Performance Specialists
351 Six Flags Pkwy SE
Mableton, GA 30126
770-949-7191
Not Racist, Not Violent
Just no longer Silent!
Question with Boldness.
2008 F-450 King Ranch w/4.30 gears
SCT Custom Tuning by FPS, Deleted, 16mpg
2001 F-250 Platinum Edition - Gone, but not forgotten
CIA, Garrett GTP38R, 4" Exhaust, SCT Custom Tuning by FPS
shoguy89 is offline
post #184 of 192 (permalink) Old 11-14-2016, 10:53 AM
The Green Lie
Originally Posted by boyeraz View Post
We are such a visual society if it looks like a good idea we buy into it. Crap we elect people not based on qualifications but looks.
Yes the Air looks cleaner, but is it better for the Environment?
Everyone talks about cleaner Air and Low Carbon foot print.
If you take into account the extra fuel, Air, Def Fluid used, plus the CO2 produced, is the carbon foot print larger.
Just like Ethanol yes you can lower emissions but at what cost? How much energy does it take to produce Ethanol?
It all depends on what your using the truck for? Hauling Delete the DPF ASAP, everyday driving keep it.
Delete the DPF you will love the towing ability.
You are so right, boyeraz! These hybrids that are touted to be so "earth-friendly" are no more fuel efficient than a diesel equivalent, and you have toxic batteries to manufacture and dispose of... This society of sheep believes whatever is popular. And carbon footprint... SERIOUSLY. If you want facts, look up what ONE volcanic eruption produces compared to the estimated carbon emissions of all of human history. It is very enlightening. Facts, people!
JAKEC2C likes this.
Rooky is offline
post #185 of 192 (permalink) Old 01-18-2017, 01:49 PM
appreciate it...im new to diesel trucks...i am looking for hard facts about deleting the def .. ie gas mileage does it go up ? does removeing it.... ware out the engine faster.. i mean with the DEF does it help anything other then emissions? i pull a 42 toyhauler a few times a year .. what can i do on a budget to help with hp and mileage. really anything would help.. thanks
tmcffmn is offline
post #186 of 192 (permalink) Old 01-20-2017, 07:55 PM
You're mileage will go up. How much is the question. I have read not as much as deleting the 6.4's. I saw about 2mpg when I did my 6.4 . I know my truck below runs about 15.5mpg down the highway at 70mph. It was around 16-16.5 before I added the larger tires. When the truck goes through a cycle my mileage falls about 1 mpg. I almost gain it back when another regen starts. My truck goes into regen about every 350 miles. I'm guessing I'm losing about 10% of my mileage. Lighter trucks which get better mileage and don't regen as often likely lose less. I'm currently debating deleting. The DEF goes no where near the engine. I can't see how deleting would ever hurt the engine. I pull a 40ft 5th wheel. I gain about 1 mpg driving 65-68 versus 72-75. Makes a huge difference. My combined is a little over 25K. 8-9 at 72-75 depending on wind and terrain. 9-10 slowing down just a bit.
2016 F350 KING RANCH DRW, 4X4, RUBY RED/CARIBOU, 3.73'S, LOADED, TUNED, ARE FLAT BED COVER, SPRAY IN LINER, 2.5" RANCHO FRONT LIFT, 3" REAR LIFT, RANCHO 9000 XL'S, 255/80/17 BFG MUD TERRAINS, EBC BRAKES, RADIO LOCKPICK, FRONT LIGHT BAR AND REAR FLUSH MOUNT LED'S.
COBRAJET is offline
post #187 of 192 (permalink) Old 01-30-2017, 09:32 PM
shaark92's Avatar
My Photos: (9)
Just picked-up my 2011 from Bosque Flat Diesel near Stephenville. Matt installed the H&S tuner. EGR block and DPF delete. Although, he didn't remove the shell of the DPF and install the straight pipe. he opened the shell of the DPF and "roto routered," welded it back up and reinstalled ... so now I've got a 6' section of BIG pipe. Gave it a low rumble, too. Not loud, but noticeably different.
I gotta study the ops of the H&S unit a little bit. The pyro didn't respond as I expected. In fact, Pyro 1 with "factory source" actually indicated inverse ... throttle closed, the displayed EGT would get to 1800 degrees. With a load on it, it'd drop to 350ish ... clearly that's incorrect.
I haven't "tried it out" yet, but I can tell it's much more responsive. The 20 mile drive home, which included driving through Stephenville ... the computer displayed 19 mpg!!!! I'm anxious to do an old school calculation; though precision is difficult because refilling to full with the flat bed filler neck is a challenge.
Has anyone tried to plumb the DEF tank to hold fuel? Using that 6 gallons would be handy.
Al
2011 F350 SuperCab XLT DUALLY 4x4 6.7 AT ... C&M flatbed, air springs with cab controller, H&S tuner, DPF delete "Hulled", EGR block
Tows a 24' Cattle Trailer, 28' Flat Bed Dove Tail.
SOLD: 2000 F350 XLT SRW 4x4 7.3 ZF6 ... AFE Intake, MBRP 4" exhaust, DP Tuner, ceramic coated exhaust manifolds/up pipes.
shaark92 is offline
post #188 of 192 (permalink) Old 02-03-2017, 12:08 PM
shaark92's Avatar
My Photos: (9)
Update ... returned to Matt earlier this week and he installed another thermocouple to a Bully Dog transducer which connected to the H&S screen. Easy.
Pyro 1 now reads correctly.
Took it on an empty (4 SUV tires for Mom) 180 mile trek yesterday ... 17.1 mpg displayed ... 20-30 mph wind pushed half of that distance and I wasn't smelling roses along the way. "...long way to go and short time to get there."
I am happy. Thanks Matt/co at Bosque Flat Diesel.
Al
shaark92 is offline
post #189 of 192 (permalink) Old 03-29-2017, 03:14 PM
Originally Posted by ford_doctor View Post
Personally, I like to breathe clean air. Don't you?
We all probably prefer clean air. However, the emissions from the regen are worse than the regular diesel emissions. They are trying to get rid of the DEF in California.
marvinburton is offline
post #190 of 192 (permalink) Old 04-12-2017, 12:46 AM
That's why everyone should delete....cleaner air and less waste. Make your engine last longer and use less fuel! Do you have any idea how much pollution and energy it takes to make fuel, another engine or emissions parts, or a whole new vehicle for that matter? If you want GREEN, DELETE, DELETE, DELETE!
Cajun Martini likes this.
JAKEC2C is offline
post #191 of 192 (permalink) Old 05-16-2017, 10:52 PM
I'd love for you or anyone else explain to me how a diesel engine that will run 20 miles on 1 gallon of fuel is more harmful to the air that we breathe than a ''government smog control equipped'' diesel engine that will only run 12 miles on 1 gallon of fuel ?
360 6.7 is offline
post #192 of 192 (permalink) Old 09-21-2017, 05:24 PM
CobraDriver's Avatar
Sorry, but this is wrong.
Originally Posted by SkiSmuggs View Post
It wasn't your question, but there is a PCM update to prevent the trucks from shutting down due to an EGT sensor failure. Update the PCM and it won't shut down again for that problem.
I had the PCM update done some time ago and my truck was shut down recently due to EGT sensor failure.
I wasn't going to do a delete, but I am now...
2012 F350, 4X4, SC, LB, 6.7, Lariat, 3.55, 5th wheel, PTO, Lariat Int. Pack., etc.
CobraDriver is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Upgrades and Aftermarket - Engine
