Coolant filtration - Diesel Forum - TheDieselStop.com
6.7L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty truck with 6.7L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.7L Power Stroke engine.
 14Likes
post #1 of 31 (permalink) Old 07-27-2017, 05:02 PM Thread Starter
clev's Avatar
My Photos: (16)
Coolant filtration
Has anyone used the Sinister Diesel kit for your truck? Care to comment on installation and use?
2012 F-350 SD Crew Cab, SRW, LWB, 4 X 4, FX4 Offroad, Bilsteins and Bilstein Steering Stableizer, AirLift Air Bags with onboard compressor, BedLocker electric bed cover, Hellwig 1 1/4 inch rear anti-sway bar, 2017 G37 Turbo, ATS Stage I towing transmission kit, White Platinum w/Adobe, Navigation, Moon Roof, 5th Wheel Prep, Step Tail Gate, front 2 inch receiver, completely insulated, Pioneer speakers, King Ranch Package
'99 E-350 HiTop Companion Van Conversion, 7.3 SD Diesel, 5-tune DP Tuner, Triple AutoMeter C2 A-pillar gauge pod, dash mount AutoMeter C2 fuel pressure gauge, twin K&N's, 203* mod, Deraler tubed trannie pan, B&M trannie cooler, AirLift air bags, Bilsteins, 4" DiamondEye turbo back exhaust, Air Dog fuel filtration system, Hutch mod, header wrapped and high temperature painted Bellowed Up-Pipes.
clev is offline
post #2 of 31 (permalink) Old 07-27-2017, 07:20 PM
Why do you need a coolant filtration system on the 6.7? The 6.7 uses the same coolant that gasoline engines in your explorer, escapee, chevy, dodge etc uses. The coolant is the DEXcool or equivalent. You do not see filtration systems on gasoline engines do you?
This for sure would be a waste of money in my mind.
Larry
larrgh is offline
post #3 of 31 (permalink) Old 07-27-2017, 07:56 PM Thread Starter
clev's Avatar
My Photos: (16)
Hi Larry; I guess that I read too much some times. I get Diesel Tech magazine, plus a few other subscriptions, and I was reading about coolant filtration today. According to what I read, the 7.3 and 6.0 definitely need filtration, but the 6.7, not so much; but should still be filtered. All of the major suppliers make a coolant filtration kit for the 6.7 for a nominal fee, and basically easy install, so yes, I was considering. That's why I posted here; for input. Let's see; that's 1 'no'.
clev is offline
post #4 of 31 (permalink) Old 07-27-2017, 08:03 PM
Ford also says in the maintenance schedule to change the coolant in both systems at 105,000 miles. Not sure the requirement of the 7.3, 6.0 or 6.4. I could see a filtration setup if you were going to run the coolant 250,000, 500,000 or more miles like the big rigs.
Larry
larrgh is offline
post #5 of 31 (permalink) Old 07-28-2017, 12:47 PM
Phillippeterson's Avatar
OMG people - get in your truck and drive it. All this extra filter, separators, CJ vs CK oils, truck stop fuel vs normal sized station fuels, cold air intakes, SeaFoam, DEF deletes, DPF deletes, and other additive crap discussions are senseless. There are hundreds of thousands of trucks on the road and the owners don't worry themselves silly on forums - probably don't even know forums exist. Their trucks run just fine forever by putting in diesel fuel from the nearest station and changing the oil once in a while.
FLAME ON!!!
scottm, larrgh, jwbboat and 1 others like this.
Phillippeterson is offline
post #6 of 31 (permalink) Old 07-28-2017, 12:54 PM Thread Starter
clev's Avatar
My Photos: (16)
Good grief, where do you people come from? If you're not interested in sharing ideas and discussing possible modifications, what are you doing here? I could find a lot better things to do than hang out a web site like a child molester at a kiddie bathroom.
HeavyAssault, jleedog and doumitch like this.
clev is offline
post #7 of 31 (permalink) Old 07-28-2017, 02:22 PM
Phil G.'s Avatar
ROTFL
2007 F350 SRW 6.0L Auto, 3.73LS, 172"WB 4x4. Viper Alarm/RS, WD pillar Guages,AutoEnginuity, 100gal polished alum fuel tank.
All Sold: 99.5, early03 , 2004 - all were 172" wb 4x4 lariat's.
My Worklog - *Updated 8/18 with Edge CTS2 install click here =>*:
Phil G. is offline
post #8 of 31 (permalink) Old 07-28-2017, 02:56 PM
I did offer an idea......the filtration is money in the seller's pocket and less money in your pocket....my idea is to use the cost of the filtration unit to pay for changing the coolant at 105,000 miles......and use some of the money to buy one of the vacuum fill kits to avoid air pockets.
Larry
larrgh is offline
post #9 of 31 (permalink) Old 07-28-2017, 03:33 PM Thread Starter
clev's Avatar
My Photos: (16)
Yes, Larry; you usually give me good advice/suggestions.
HeavyAssault likes this.
clev is offline
post #10 of 31 (permalink) Old 07-28-2017, 04:25 PM
jleedog's Avatar
FLAME ON!!!
Please explain why you are on this "silly forum" if this is the case
scottm and HeavyAssault like this.
2002 F250 Super Duty Crew Cab 7.3L Lariat 2WD 131,000mi; 4in turbo back custom exhaust, Garrett GTP38R turbo, Riffraff intercooler boots, Dorman Up-Pipes, Ford Severe Duty AIS, 31 row 6.0 transmission cooler, Scangauge II, ISSPRO EV2 Boost-EGT-Trans temp-Fuel pressure Gauges, DP T-5 Tuner (stock ,60HP tow, Decel, 60HP highway econo, 80HP city econo), Dieselsite coolant filtration, Max Air A/C mod, foglight mod, AIH delete, LED interior, back up camera, hid foglights.
I have AE if you are in San Diego area and need help. Send PM
jleedog is offline
post #11 of 31 (permalink) Old 07-30-2017, 06:42 AM
HeavyAssault's Avatar
My Photos: (6)
Since the '11 release of the 6.7L it has not been known or repeatably discussed to need a coolant filtration kit. For the cost of the coolant filter kit compared to flushing, how much coolant could you buy?
2015 F-350 CCLB PSD 4X4 3.55 ELD
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
post #12 of 31 (permalink) Old 07-30-2017, 01:18 PM
I see that DexCool approved coolants also have the Ford spec listed but I have personally delat with several dexcool GM vehicles with the Dexcool sludge disorder.
I'd love for a chemical engineer with automotive coolant experience to explain this. I LOVE Shell ELC as it fixes 6.0 oil cooler plugging. 6.0 oil coolers I have replaced and used ELC red coolant in have gone twice the oil cooler plug milage with no coolant change and no issues and ECT-EOT spread staying at 8-10 degrees. I had to replace the radiator on one the other day as I saw the seam had a small leak that I know would turn into a tank blowout. That red coolant had been in there since 2009 and the truck had gone 127K miles. There was nothing in the rad and I pulled block plugs and nothing there either. The only thing I see is the rad was white inside tanks as I pulled tanks off so the rad would bring more $ in my scrap run. That white crust is there to some degree on any I ever pull tanks on for that reason so I would not judge that one to be any worse than any gaoline engine pickup rad I have changed with 200K miles and 10+ years of use.
I'm not promoting that the coolant stays in that long but this truck had not had it flushed as I recommended since I did the cooler on it.
Oh BTW, there are certainly mods that no question have positive effects. But many of us here would take the care needed to assure no issues that make some of these mods unnecessary. I see a coolant filter system as catching silicate drop-out as good coolant maintenance keeps anything else out of system. Use f coolants that do not pose that risk would make a coolant filter unneeded. Class 8 trucks don't have coolant filters since long-life diesel coolants with silicate and cavitation issues addressed started being the fill for cooling systems on those. The filters were the best way for those trucks to have a slow dissolve disc of the cavitation suppressing additive in the system.
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
post #13 of 31 (permalink) Old 08-01-2017, 08:34 PM Thread Starter
clev's Avatar
My Photos: (16)
Well, when i read ideas, a lot of times I post here for suggestions. I always get good replies and I appreciate that. So, based on those replies, I don't need a coolant filter.
clev is offline
post #14 of 31 (permalink) Old 08-01-2017, 08:58 PM
Clev....not mentioned....the 6.7 has TWO SEPARATE cooling systems.....did any of the filtration setups filter both cooling systems?
Larry
larrgh is offline
post #15 of 31 (permalink) Old 08-01-2017, 09:00 PM Thread Starter
clev's Avatar
My Photos: (16)
Yes, it did refer to two systems, and the coolant filtration was for the 'engine side', I think. I would have to find and re-read the article to be sure.
clev is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Upgrades and Aftermarket - Engine
