Mods/adds for lower maintenance - Diesel Forum - TheDieselStop.com
6.7L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty truck with 6.7L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.7L Power Stroke engine.
 1Likes
  • 1 Post By badbart
post #1 of 5 (permalink) Old 06-04-2018, 01:58 PM Thread Starter
Years ago, 99 F350 Dually 7.3 I had a coolant filter, water separator, and extended interval remote filter system.
Apparently the coolant filter is no longer needed as the coolant doesn't break down like it did, but also reading that the 6.7 s very susceptible to water. So in that regard, is it recommended to add a water separator after the OEM system?
Also, is anyone doing extended oil changes with a remote filtration system?
I'm just going over possible adds if and when I get an F350 6.7.
DD 2018 F150 Platinum 3.5 EB
Tow Baby, 2012 F350 King Ranch SRW SB. Rolling Thunder III
Sold due to neglect
U.S.N. Paradise BB91904 '99 F350 CC LWB DRW
Mods, SuperHyper Improbability drive stage II.
Hypermax 5" turbo back system, triple pillar guages, Heater core shutoff. AEM Brute Force intake. 3.73 gearing. DP PCM with 80HP Installed!
ACD2 is offline
post #2 of 5 (permalink) Old 06-06-2018, 06:57 AM
HeavyAssault's Avatar
My Photos: (6)
I would highly recommend the water seperator on the fuel side. Extra insurance never hurts on the fuel side.
If you want extended oil intervals you can try a by-pass. I didn't mention in your other post, I know a guy if you want other choices in oils to help with extended intervals. He is NOT an Amzoil guy.
2015 F-350 CCLB PSD 4X4 3.55 ELD
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
post #3 of 5 (permalink) Old 06-06-2018, 07:21 AM
badbart's Avatar
http://www.dieselsite.com/fuelsystems-cpr.aspx
This is what I run on mine.
HeavyAssault likes this.
2011 F350 4x4 XL Crew Cab Dually
2010 Keystone Fuzion 405 Toyhauler
badbart is offline
post #4 of 5 (permalink) Old 06-06-2018, 09:08 AM Thread Starter
Sounds good, thanks for the link. I thought that site sounded familiar, so checked coolant filters, sure enough, that is where I got mine from.
http://www.dieselsite.com/1999-2003f...ionsystem.aspx
Been a while, glad to see it is still there.
Sold due to neglect
ACD2 is offline
post #5 of 5 (permalink) Old 06-06-2018, 11:11 AM
divenride's Avatar
I run the Amsoil by-pass system and 5w-40 full synthetic oil. I go 10,000 miles between oil changes. I was running the water filter from www.dieselsite.com because I had one on my 2002 7.3. I removed about 15,000 miles ago. I also run the fuel pre-filter from Dieselsite, I drain it every oil change and replace the filter once a year. I've been waiting for Bob at Dieselsite to release the external automatic transmission. I pull a heavy toy hauler so I change my transmission oil at 60,000 mile intervals.
2015 Larait, F350, CC, 4x4, SRW, AmsOil Bypass filter, BD3 Trail Saver 5th Wheel Hitch, Bilstein 5100's, DieselSite fuel filter/with water separator,
divenride is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Upgrades and Aftermarket - Engine
