SEIC (High Idle) MOD PICTURES - Diesel Forum - TheDieselStop.com
6.7L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty truck with 6.7L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.7L Power Stroke engine.
post #1 of 124 (permalink) Old 10-28-2010, 11:42 PM Thread Starter
IFlyEm's Avatar
Thumbs up SEIC (High Idle) MOD PICTURES
STEADY PRESET RPM:
Here are the resistor options. FWIW my local Ford Diesel Tech recommends 1200 RPM under no load. So that would be a 20K resistor. I used a .5 Watt Resistor in my testing.
VARIABLE RPM CONTROL:
This is the potentiometer I used:
Hope this helps someone and can save some hassle!!
IFlyEm is offline
post #2 of 124 (permalink) Old 10-29-2010, 07:46 AM
Thanks a lot IFlyEm. Great work. I'll do this on mine soon. Have you considered posting this over on FTE also? Bunch of guys over there that would appreciate this also.
CURRENT: 17 F350 Platinum Ultimate
FORMER: 11 SD 6.7L CC SWB White Platinum Lariat Ultimate
2" Auto Spring leveling kit (required caster correction)
315/60/20 Toyo MT's
Line-X Bedliner/Door Seal Mod
DDM Tuning HI/Low HID's (H13, 55W, Color 5,000K)
Titan 50 gallon tank
EpicCowlick is offline
post #3 of 124 (permalink) Old 10-29-2010, 09:03 AM
Rutcutter's Avatar
Man im gonna wire mine up this afternoon! Thanks
16' SD CC F350 6.7L FX4
White Platinum Tri-coat
Lariat Ultimate Pkg
5th wheel prep
Leveled front
35/12.50/20 Toyo MT's
11' SD CC 6.7L 4x4 (Sold)
08' SD CC 6.4L 4x4 (Sold)
06' SD CC 6.0L 4x4 (traded)
12' CanAm 1000 XT in Camo
12' Cat 430E 4x4 Backhoe Loader/Cab&Air
Rutcutter is offline
post #4 of 124 (permalink) Old 10-29-2010, 10:05 AM
MX727's Avatar
I posted this in the other thread, but:
For those that go the potentiometer route, you need to add a resistor inline on the white/brown wire.
Add a 680 Ohm resistor inline to make sure the range remains within the range of 680-51K.
1K might be easier to get at the Shack though: 1K resistor in line, you will get 1K-51K, or approximately 900-2800 RPM
They list a 680 Ohm resistor, but it seems to be online only.
Lots of options for combining the size of the pot and resistor to get the range you want.
2000 F350 Lariat, Black with Tan Interior
2004 F350 Lariat, White with Gray Interior
2007 F350 Lariat, Red with Black Interior
2014 F450 DRW Lariat, Ruby Red with Black Interior
2017 F350 DRW Lariat, Graphite with Black Interior
2019 F450 DRW Lariat, Graphite with Black Interior
MX727 is offline
post #5 of 124 (permalink) Old 10-29-2010, 12:33 PM
So this only turns off by the switch? So effectively it could be used a poor mans cruise control and will hold whatever RPM you set it at it will hold? Nothing wired into the brake to turn it off?
maximusj is offline
post #6 of 124 (permalink) Old 10-29-2010, 12:40 PM
Dak
Idle only... Not a poor man's cruise control. There are certain conditions that have to be met, one of which is the vehilce is in Park.
BTW - I like the write up and photos. It makes it much easier to understand. I think I will go the potentiometer route....
2011 F350 SRW 4x4, Lariat, LWB, Diesel, Nav., 5th Wheel and Camper Pkg.
Dak is offline
post #7 of 124 (permalink) Old 10-29-2010, 05:29 PM Thread Starter
IFlyEm's Avatar
Ok got it all soldered and shrink wrapped. I haven't permanently mounted the pot yet but it's fine where it is for now. Works like a champ!!
IFlyEm is offline
post #8 of 124 (permalink) Old 10-29-2010, 05:32 PM Thread Starter
IFlyEm's Avatar
I tried to add a 1K resistor with the 50K pot which still should have kept me in the range but couldn't get it to work reliably with the resistor in any position. Maybe it needs two 500 ohms? I don't know. But this works for and is simple so I just went this route.
IFlyEm is offline
post #9 of 124 (permalink) Old 10-29-2010, 08:05 PM
Ketoth's Avatar
Looks like switch 4 brown wire should be connected to SEIC yellow/green. Resistor is wired between PTO_REF white/brown and PTO_RPM green. That looks like it would change the idle speed depending on the value of the resistor. I'll have to try it when I get some time.
This is what I gave you last night and you said it didn't work.
What did you change to make it work on a fixed RPM?
I know you used a pot to make it adjustable but the fixed RPM version should have worked.
Nice looking job by the way.
2015 F450, 6.7L, Lariat, Crew Cab, LB, DRW, 4X4, Lariat Pkg, Navigation Pkg, 5th Wheel Pkg, all options except Moon Roof , Platinum White/Carabou, Adobe Interior, FormulaOne Pinnacle Series Window Tint, Truckcovers USA bed cover, DuraFlap mudflaps, Ranchhand Grille Guard
Ketoth is offline
post #10 of 124 (permalink) Old 10-29-2010, 10:10 PM Thread Starter
IFlyEm's Avatar
Ketoth,
You were correct. I was using the wrong brown wire. I was using BROWN W/ WHITE STRIPE. Once I switched to WHITE W/ BROWN STRIPE worked like a charm!!
Once I figured that out I moved on to the potentiometer.
Thanks for the help!
IFlyEm is offline
post #11 of 124 (permalink) Old 10-31-2010, 02:06 PM
Rutcutter's Avatar
Hooked mine up Friday afternoon and it works like a charm.. Thanks IFlyEm!
Lariat Ultimate Pkg
5th wheel prep
Leveled front
post #12 of 124 (permalink) Old 10-31-2010, 06:31 PM
haystax's Avatar
If the PTO provision is ordered, is there a factory control box to adjust engine RPM? What are you guys doing with this mod? My '99 and '02 will go into a high idle at warm up, doesn't this happpen in the new truck or is it for high amp load aux demands?
Current Fleet -
2011 F350 CC,SWB,SRW,6.7 Lariat on 20s
2006 F350 CC,LWB,SRW,6.0 Lariat ~130K
2002 F250 SC,LWB,SRW,7.3 Lariat ~175K
1996 F350 7.3 300K and still going strong
1984 F250 6.9 - pretty much dead
1978 F250 400 - oldie but a goodie
1978 F150 400
1962 F100 292
haystax is offline
post #13 of 124 (permalink) Old 10-31-2010, 07:26 PM
Rutcutter's Avatar
We are using the potentiometer to control the idle rpm,very slick setup.
Lariat Ultimate Pkg
5th wheel prep
Leveled front
post #14 of 124 (permalink) Old 10-31-2010, 07:48 PM
haystax's Avatar
Yeah, I get that and understand the mechanics. Are you using it when you winch? Or just because you can?
Current Fleet -
1978 F150 400
1962 F100 292
haystax is offline
post #15 of 124 (permalink) Old 11-21-2010, 06:21 PM
GrmReaper's Avatar
I just wired it up, with a 20k resistor works great. thanks for the pics. They helped alot
i personally am using cause of my 800watt power inverter, sucker draws alot of juice, and from time to time, i light 12v catalyst heaters, not sure how much they draw but i know they used to cause my old chevy work truck to idle up to carry the load
2011 F350, CC, LB, Lariat, 4x4, FX4, Tuxedo Black, 6.7L
2.5" Leveling kit
HID 6k headlights and fog lights
18x9 Fuel Hostage Black and Brushed
35x12.5 Dunlop Rover M/T Maxx Traction
H&S Tuned
GrmReaper is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Upgrades and Aftermarket - Engine
