Those with Dual Alternators - Page 5 - Diesel Forum - TheDieselStop.com
6.7L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty truck with 6.7L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.7L Power Stroke engine.
post #61 of 65 (permalink) Old 02-20-2019, 10:45 AM
1SapperAirborne's Avatar
Dual alternator setup, not operator...😂
1SapperAirborne is offline
post #62 of 65 (permalink) Old 02-20-2019, 12:09 PM
RT
RT's Avatar
Originally Posted by Nickelplated5s View Post
I would say do the high idle mod at the same time if that's the route you want to go.
That's a great idea. Not much juice generated at idle.
Originally Posted by 1SapperAirborne View Post
Is my battery light coming on because one alternator is faulty and when the other kicks in it picks up the slack? Or is this a normal design operation for the dual operator setup.
I think you are on the right track thinking your primary alternator has quit functioning correctly. Definitely not designed to have the light on with an alternator code. Easy to pop it off and run it down to be tested.
RT is online now
post #63 of 65 (permalink) Old 02-20-2019, 04:18 PM
From my impression he is only concerned a this time with charging thee batteries while in transit.
Larry
larrgh is online now
post #64 of 65 (permalink) Old 02-21-2019, 09:53 AM
Yes, but if he wants to turn his truck into a generator go all in. That mod is fairly cheap and would add flexibility.
Nickelplated5s is offline
post #65 of 65 (permalink) Old 02-23-2019, 07:54 AM
clev's Avatar
My Photos: (16)
I did the high idle mod quite a few years ago. Thanks for the recommendation.
2012 F-350 SD Crew Cab, SRW, LWB, 4 X 4, FX4 Offroad, Bilsteins and Bilstein Steering Stableizer, AirLift Air Bags with onboard compressor, BedLocker electric bed cover, Hellwig 1 1/4 inch rear anti-sway bar, 2017 G37 Turbo, ATS Stage I towing transmission kit, White Platinum w/Adobe, Navigation, Moon Roof, 5th Wheel Prep, Step Tail Gate, front 2 inch receiver, completely insulated, Pioneer speakers, King Ranch Package
'99 E-350 HiTop Companion Van Conversion, 7.3 SD Diesel, 5-tune DP Tuner, Triple AutoMeter C2 A-pillar gauge pod, dash mount AutoMeter C2 fuel pressure gauge, twin K&N's, 203* mod, Deraler tubed trannie pan, B&M trannie cooler, AirLift air bags, Bilsteins, 4" DiamondEye turbo back exhaust, Air Dog fuel filtration system, Hutch mod, header wrapped and high temperature painted Bellowed Up-Pipes.
clev is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Upgrades and Aftermarket - Engine
