Upgraded turbo - Diesel Forum - TheDieselStop.com
6.7L Upgrades and Aftermarket - Engine Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty truck with 6.7L Power Stroke diesel engine. Please confine discussion of topics in this forum to those items that are specific to the 6.7L Power Stroke engine.
 3Likes
  • 1 Post By HeavyAssault
  • 1 Post By clev
  • 1 Post By clev
post #1 of 9 (permalink) Old 02-18-2019, 04:52 PM Thread Starter
clev's Avatar
My Photos: (16)
Upgraded turbo
I'm having 'my' transmission replaced with an ATS Stage 1 trannie and t/convertor package at the local Ford garage. While that's being done, it would be an easy task to replace the turbo. I know that the 2015 F350 will fit and is a bigger, more responsive turbo, but does anyone know if the 2017 will work? I ask about 2017, because that's the year that Ford increased the towing capability from 15k pounds to ~21k, so the 2017's should have a better turbo. If anyone can add input for this, I'd appreciate it.
2012 F-350 SD Crew Cab, SRW, LWB, 4 X 4, FX4 Offroad, Bilsteins and Bilstein Steering Stableizer, AirLift Air Bags with onboard compressor, BedLocker electric bed cover, Hellwig 1 1/4 inch rear anti-sway bar, White Platinum w/Adobe, Navigation, Moon Roof, 5th Wheel Prep, Step Tail Gate, front 2 inch receiver, completely insulated, Pioneer speakers, King Ranch Package
'99 E-350 HiTop Companion Van Conversion, 7.3 SD Diesel, 5-tune DP Tuner, Triple AutoMeter C2 A-pillar gauge pod, dash mount AutoMeter C2 fuel pressure gauge, twin K&N's, 203* mod, Deraler tubed trannie pan, B&M trannie cooler, AirLift air bags, Bilsteins, 4" DiamondEye turbo back exhaust, Air Dog fuel filtration system, Hutch mod, header wrapped and high temperature painted Bellowed Up-Pipes.
clev is offline
post #2 of 9 (permalink) Old 02-18-2019, 05:12 PM
No knowledge of actual fit or not, but the 17-18 turbo is like the 15-16 turbo, not a direct bolt on. It requires some parts besides the turbo to make it work. You would be better off going to some of the sites that sell the upgraded turbos and ask them. I have not seen anyone on here or any of the other forums talking about the 17-18-19 turbo as a replacement/upgrade.
Larry
larrgh is offline
post #3 of 9 (permalink) Old 02-18-2019, 05:20 PM Thread Starter
clev's Avatar
My Photos: (16)
Thank you, larrgh.
clev is offline
post #4 of 9 (permalink) Old 02-19-2019, 05:36 AM
HeavyAssault's Avatar
My Photos: (6)
The '17+ turbos can be used in lew of the '15 model if you so choose. There is a different pedestal which you need anyway to run either the '15-'16 turbo or the '17+ turbos. I recall the oil feed or coolant feed was changed which causes the new pedestal to be used.
larrgh likes this.
2015 F-350 CCLB PSD 4X4 3.55 ELD
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
post #5 of 9 (permalink) Old 02-19-2019, 08:14 AM Thread Starter
clev's Avatar
My Photos: (16)
Thanks, Heavy. Will the pedestal for the 15 drop in place on a 12 without mods? What about up pipes, would the 12’s bolt up or would I need pipes from the 15?
clev is offline
post #6 of 9 (permalink) Old 02-22-2019, 05:28 AM
My Photos: (6)
Sorry, but I'm sure you need new pipes due to the newer compressor housing on the newer turbos. The aftermarket guys do sell OEM kits that give you everything or you could just go to the aftermarket pipes. Not to mention you would need tuning support as well with the '15+ turbos.
post #7 of 9 (permalink) Old 02-22-2019, 08:41 AM Thread Starter
clev's Avatar
My Photos: (16)
Good morning, Heavy. Yes, you are correct on all points. I found a kit at KC Turbos for $2500, and it has everything including up pipes. It will upgrade the 11-14 G32 Turbo to the 15+ G37 Turbo. I’ve been in contact with KEM tunes for programming. If you know anyone that took over for PIP, could you PM me?
HeavyAssault likes this.
clev is offline
post #8 of 9 (permalink) Old 02-22-2019, 05:10 PM
My Photos: (6)
You and me both on PIP. I wish I knew the secret handshake to get in touch with those guys or any of the others that have ghosted. The best thing is there are still good options for tuning support without needing a new device or visit a shop just South of you considering your location. For your local guys you may need to be there physically to ask "the right questions". LOL
post #9 of 9 (permalink) Old 02-22-2019, 05:34 PM Thread Starter
clev's Avatar
My Photos: (16)
Thanks again, Heavy. My appointment for the turbo and trannie is 11 March; looking forward to the upgrade. Hope the dealership has the expertise.
clev is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > 6.7L Upgrades and Aftermarket - Engine
Similar Threads
Does someone know what the upgraded turbo oil supply line look like? bustedknuckles 6.0L Power Stroke Engine and Drivetrain 7 08-22-2011 11:27 PM
ISSPRO EV or AutoMeter Z series locknload223 '99 & up Upgrades and Aftermarket - 7.3L Engine 19 11-21-2009 11:25 PM
Taking the Plunge, first performance modifications DarthSurplus '99 & up Upgrades and Aftermarket - 7.3L Engine 7 07-27-2005 11:05 AM
ATS Ported Housing with stock wheel vs. stock housing with WW DarthSurplus '99 & up Upgrades and Aftermarket - 7.3L Engine 225 03-17-2005 02:43 PM
