Back Seat High Road Clothes Bar - Diesel Forum - TheDieselStop.com
'11-16 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
 1Likes
  • 1 Post By gearhead1011
post #1 of 14 (permalink) Old 03-19-2012, 04:17 PM Thread Starter
owrstrich's Avatar
Back Seat High Road Clothes Bar Installation
my 12 sd cc showed up with no back seat grab handles... my job is continious travel and i need to hang clothes... my clothes bar from the 03 hung from the grab handles...
i pulled back the head liner and loosened up the air bag mount screw and zip tied the clothes bar to the air bag mount... tightened it up and all is good... other than the wire mount being crooked it dosent look too bad either...
clothes bar link... Walmart Mobile
j o
owrstrich is offline
post #2 of 14 (permalink) Old 03-19-2012, 04:28 PM
Cowcop's Avatar
Smile
Thanks! Just looking at that problem yesterday and wondering why FORD would change something like that after all these years.
99.5 F-350 S/C 4X4 - gone
2012 F 350 S/C 4X4 Lariat - Armaguard liner, OEM rear wheel tubs, adobe powder coated cab guard & fifth wheel gate, Beamer HID's, Rigid 20" light with adobe bar, Kenwood stereo with Nav & back up camera, flush mount led b/u lights, Fuel "Pump" rims w/ Toyo Extreme AT2's
Cowcop is offline
post #3 of 14 (permalink) Old 03-19-2012, 06:41 PM
lincster's Avatar
My Photos: (29)
They changed it because of the side air bags. The handle got moved to the B pillar. My 12 came with it. There are hangers along the rear of the cab, 2 of them. Not the best location, but they are there.
2019 F350 4X4 Dually, FX4, Crew Cab, Ultimate Lariat Package, Agate Black, Black Leather towing a 2006 LE3905 Weekend Warrior
2002 F250 CC, 4X4 - Sold
2004 F350 CC, FX4, loaded - Sold
2006 F350 CC, DRW, FX4 - Sold
2012 F350 CC, DRW, FX4 - Sold
lincster is offline
post #4 of 14 (permalink) Old 03-19-2012, 06:47 PM
Cowcop's Avatar
Smile
Well at least that reason seems good...... Unfourtunately, the two hang points are not good for multiple pieces of work clothing that some....many??...of us need with us during our 'travels'.
Adapt..overcome.....
Cowcop is offline
post #5 of 14 (permalink) Old 03-19-2012, 07:12 PM
lincster's Avatar
My Photos: (29)
I agree, not good hanging points at all. Not good locations for grab bars either IMO.
lincster is offline
post #6 of 14 (permalink) Old 01-26-2013, 03:35 PM
broome101's Avatar
how did you get the head liner back to get to the bolts, I would like to do this as well
2013 KR, F350,6.2L,4x4,CC, LB
broome101 is offline
post #7 of 14 (permalink) Old 01-26-2013, 04:44 PM
+1 to this, and IMO the lame ass little hooks at the back of the cab are worthless the way they come stock.
I tried to hang a heavy coat on a plastic hanger, wouldn't stay hooked.
Ended up putting one of them cheap key chain carabiners to hang the stuff off of, down side that adds another 3 inches so the coats are mostly sitting on the seat in the SC....
~Wolf
'12 F550 Tux Black Lariat Supercab 186" WB , 4x4 6.7, 19.5GVW
13k lb hooklift, Cramaro auto tarp, Insta-chain automatic tire chains, Boss 9' SD plow, Atomic led cab marker/strobe
Custom~ fabbed rear bumper, tarp gantry, rear warning led setup, SEIC & rear strobe control panel (in the drivers side powerpoint trim)
And more to come
'99 F350 XLT CC LB 4x4 dually 7.3, Dents build character
408,000ish miles on the clock (2nd motor)
'93 Exploder Sport, 5.0 swap, 4r70w+Baumann TCS, Atlas 2 T-case 3.8:1 twin stick, Narrowed D44 '79 f150 solid axle swap, bunch o other junk...
'69 Ford rust bucket, err Bronco, "resto"/mods in the planning stages
Wolf451 is offline
post #8 of 14 (permalink) Old 01-27-2013, 08:32 PM
broome101's Avatar
well i tackled it today, pull the weather strippping back and it will come lose enought to get you hands in and 8mm socket on 1/4" drive rachet and lossen the bolt. Got it hung ok but really dont like the look that good, it will work but rally not to my liken. I am going to take one of them loose again, then take coat hook off from the back, I think i can get long bolt and go throught the head liner with sapcer behind it and mount the coat hook against the liner into the air bag bracketand work fine. Will let you know.
post #9 of 14 (permalink) Old 01-28-2013, 09:38 AM
gearhead1011's Avatar
My Photos: (10)
I would worry about part of the hanger becoming a projectile of the airbag was set off. Sounds like an important piece of safety equipment is being compromised. That's probably why Ford moved the grab handles.
wpetko likes this.
2012 F250 XLT
6.7 CCSB 4X4 Sterling Grey, B&W Turnover Goosenech Hitch, Air Lift LoadLifter 5000, 50 gallon Transfer Flow replacement tank, Weather Tech mats
gearhead1011 is offline
post #10 of 14 (permalink) Old 01-28-2013, 10:50 AM
broome101's Avatar
posibly could be but if hit from side hard enough to make it go off lot more projectiles are also involved.
post #11 of 14 (permalink) Old 11-03-2019, 07:50 AM
Mr
Hi guys, It would be nice if someone could document the installation either with a video or pictures.
BigD234 is offline
post #12 of 14 (permalink) Old 11-03-2019, 10:10 PM
edjunior's Avatar
Welcome BigD234. I just wanted to make sure you are aware that you are posting to a thread that is almost 7 years old since the last post. Not a problem necessarily, just want you to be aware of it.
Ed...KF5INW
2019 6.7L PSD XLT - Hatin' the payments, but lovin' the truck!
2010 Wildcat 28RKBS 5er
edjunior is offline
post #13 of 14 (permalink) Old 11-04-2019, 04:32 AM
THANK YOU ED. I DID NOT NOTICE THE DATES. DID THEY EVER FIGURE OUT A FIX FOR THE ISSUE?
BigD234 is offline
post #14 of 14 (permalink) Old 11-05-2019, 03:34 PM
j o
Link doesn't seem to be any good anymore. Not surprising, since it is 7 years old.
DonWarkentin is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Upgrades and Aftermarket
