Hellwig Big Wig Sway bar - Page 2 - Diesel Forum - TheDieselStop.com
'11-16 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
 1Likes
post #16 of 23 (permalink) Old 07-16-2015, 12:35 PM
Peter3540's Avatar
Originally Posted by Elkhounds View Post
Stock height for the front I was told 24-186018 and for the rear stock height is 24-186025. Don't have them yet but that is what I have ordered.
2015 F-350 SRW, Short Box, 3.55 locking rear end and all the other goodies except moonroof.
Peter3540 is offline
post #17 of 23 (permalink) Old 07-16-2015, 09:18 PM
Sportscraft's Avatar
So out of curiosity why not with a fifth wheel? Just not necessary or not recommended?
Sent from AutoGuide.com Free App
2017 F450 Lariat Ultimate
Sportscraft is offline
post #18 of 23 (permalink) Old 07-21-2015, 06:38 PM
jdanielm1's Avatar
Send a message via Yahoo to jdanielm1
I am curious about this as well. Why no sway bar when pulling a fifth wheel?
2011 F350 SRW FX4 King Ranch 6.7L Powerstroke.
"The DING DONG DADDY!!!"
jdanielm1 is offline
post #19 of 23 (permalink) Old 07-21-2015, 09:29 PM
Feedback Score: 2 reviews
Was told Ford engineering recommends not to because having a stiffer truck sends more energy through to the 5th wheel (bumps in the road) so the trailer absorbs more impact if you will.
15 6.7 F350 CCSB 4x4 3.55s Platinum Bronze Fire
Husky mats, all LED interior, Nushield for MFT, Bakflip F1 with Bakbox 2.
blwnsmoke is offline
post #20 of 23 (permalink) Old 07-26-2015, 06:25 PM
Ive had sway bars on every Dually I've owned in the last 13 yrs,it's been many.I tow a 43 ft gooseneck trailer,I dont have any issues.The sway bar only keeps truck from swaying either right or left.It has No effect on up and down movement of truck.
4613 is offline
post #21 of 23 (permalink) Old 10-20-2015, 01:26 PM
jfletcher72's Avatar
I put in the 7271 Hellwig bar yesterday. I have not driven it yet because when installing I pinched a tube in the U-bolt. I removed the U-bolt and fixed it but I don't want to run the truck until I figure out what I pinched. I have an arrow pointing at it in this picture. Anyone have an idea what it is and if I am ok to use? It is on the back side of the axle.
I did the EXACT same thing . Got an alert light on the dash when i started it... Corrected the install. Tube was smashed but intact. light on dash hasn't returned .
jfletcher72 is offline
post #22 of 23 (permalink) Old 10-20-2015, 01:57 PM
My 2015 DRW came with a sway bar installed from factory.
Larry
larrgh is offline
post #23 of 23 (permalink) Old 10-27-2015, 07:18 PM
HeavyAssault's Avatar
My Photos: (6)
Installed the BigWig today. Short test ride gave good results with no issues. Tomorrow will be a good test with HWY on/off ramp turns. I need a set of calipers to know the front OEM sway bar size to compare to the front Hellwig dimensions.
@larrgh: You need to see a Hellwig beside the OEM for yourself.
2015 F-350 CCLB PSD 4X4 3.55 ELD
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Upgrades and Aftermarket
