Looking for best Heavy duty shocks - Diesel Forum - TheDieselStop.com
'11-16 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
 4Likes
LinkBack Thread Tools
Old 12-09-2017, 03:27 PM Thread Starter
Got a 2011 single cab long bed F-250 and just put a fuel tank in it along with my toolbox and other concrete hand tools. Looking for the best heavy duty shocks as I am not wanting to get air bags put on. I also tow a bobcat at times. Anyone have sugggestions on best shocks for my situation?
2005 crewcab short bed f-350 6.0 harley davidson edition bone stock (for now)
conv73mustang is offline
Old 12-09-2017, 06:51 PM
Mongus's Avatar
Fox !
Mongus rigs;
1992 F-Superduty Dump truck 7.3 - Luk SMF 5spd 5:13 rears-Ricksons 19.5 wheels & tires-Banks get kits.
This is my work hoarse !
2000 F550 - Crew cab -Custom Hood
Harley Flamed Fenders & Doors.
4x4-7.3 - South Bend 6spd 4:88 rears. Loaded ! Volant intake
Hog Performance 4" SS exhaust
Banks wheel, turbine, exhaust brake-Ceramic coated
AFE Blade Runner Spyder
Strickley Diesel Return Fuel & Banjo Bolts
IH up pipes - ceramic coated
Powder coated everything.
Brake Performance-slotted & dimpled rotors with performance pads
DP Tuner 80 Tow
Coolant filter system
Evens Coolant
203 thermostat
Bullet Liner coated Dana 60 front end
2008 F-350 Harley Davidson Crew cab - long bed - 6.4 - Banks-Six gun-Air intake-IQ-Dual Exhaust
2004 Pace American 28' x 9' x 8' enclosed work trailer. 18k GVW. Tri axle - loaded
Custom Built Roll -Off dump trailer. 17yard box. Double dual axles. 20k GVW.
Fully decked 2003 Anni Fat Boy.
Rare "Reaper Tins"
Mongus is offline
Old 12-10-2017, 07:33 AM
HeavyAssault's Avatar
My Photos: (6)
I would suggest buying a resi style shock that meets your budget.
2015 F-350 CCLB PSD 4X4 3.55 ELD
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
Old 12-10-2017, 08:49 AM
edjunior's Avatar
Originally Posted by Mongus View Post
Fox !
Okay, I'll bite. What is Fox!?
Ed...KF5INW
2011 6.7L PSD XLT - Dead and gone
2019 6.7L PSD XLT - Still too new!
2010 Wildcat 28RKBS 5er
edjunior is offline
Old 12-10-2017, 08:50 AM
edjunior's Avatar
Care to elaborate on what "a resi style" shock is?
Ed...KF5INW
edjunior is offline
Old 12-10-2017, 11:32 AM
79jasper's Avatar
Fox is a brand. All you have to do is Google it.
"Resi" is a external reservoir.
Sent from my SM-G892A using Tapatalk
HeavyAssault likes this.
79jasper is offline
Old 12-10-2017, 12:16 PM
For a daily driver I have had good luck with Bilstein shocks. I think most any higher end shock would do the job.
DENNY
nipperdog likes this.
DENNY is offline
Old 12-10-2017, 01:06 PM
bugman's Avatar
My Photos: (12)
Just so that you know, air bags help the springs and not the shocks. The shocks keep the truck from bouncing up and down when you hit a bump.
The first thing that I would do is to remove all the tools that you carry every day and then measure the distance from the spring/axle to the frame. Then reload everything back into the truck and measure it again and see what you really need. If it is because the springs can't carry the load then air bags would be nice to have. If it bounces down the road then get shocks.
QcPwrStroke likes this.
bugman is offline
Old 12-19-2017, 07:40 AM
wpetko's Avatar
My Photos: (17)
I agree. Shocks are not a weight bearing component.
2013 F-350 Lariat 6.7 L PSD Crew Cab Dually, FX4, white platinum metalic tri-coat with black interior, N-Fab step bars, factory spray-in bedliner and 5th wheel hitch, trailer tow package, integrated brake controller, upfitter switches, Sync with My Ford Touch, memory group, remote start, reverse sensing with rear view camera, nav, satillite radio, Weather Tech floor mats, limited slip diff, moon roof, climate controlled seats, engine block heater and tailgate step.
2014 Lifestyle (formerly Carriage) 5th wheel 38' long with 3 slides & all the goodies.
SOLD: 2005 F-350 Lariat, 6.0 PSD, Torqueshift auto trans, crew cab, SRW, short box, FX4, ESOF, limited slip dif., tow command, upfitter switches, 6 CD changer, Lariat Lux. package, camper package, engine block heater, triple A-pillar gauge set (Autometer) with pyrometer, trans temp & voltmeter, MBRP 4" cat back exhaust w/5" dual wall chrome tip, dark shadow gray/ med. flint interior.
wpetko is offline
Old 12-19-2017, 03:08 PM
divenride's Avatar
I pull a 42' toy-hauler using Bilstein 5100's. I had airbags on a previous truck but I went with Roadmaster Active Suspension on this truck and I have no regrets.
2015 Larait, F350, CC, 4x4, SRW, AmsOil Bypass filter, BD3 Trail Saver 5th Wheel Hitch, Bilstein 5100's, DieselSite fuel filter/with water separator,
divenride is offline
Old 10-26-2018, 01:41 PM
CRAAB's Avatar
FYI. Not impressed with FOX. More likely the problem was the Carli Suspension that I have problems with since day one. Long story short, the “custom valved” Fox shocks designed specifically for my Carli suspension lasted less then 30k miles before the seals failed with freeway driving. Fox has a one year warranty which is is the worst warranty in the industry. Don’t waste your money.
I ran bilstein 5100s on my 10klb ‘99 super duty for over 200k miles with no issues at a fraction of the price. They also come with a lifetime warranty.
2015 F350 CC LB 4X4 Lariat Ultimate, Tri Coat White Metallic, Husky Xact Contour, Carli 2.5" Commuter w/Fox shocks and full Deaver rear spring pack
CRAAB is offline
Old 10-26-2018, 02:00 PM
CRAAB's Avatar
For load managing, i used tree wedges preloading the lower overload and fabbed a spacer on my upper overloads. Fairly simple if you have any skills and cost about $50 for both. Works awesome hauling my 5k lb slide in camper
Or you could buy Torklift Stableloads which do the same thing for about $600. The wedge is probably all you need.
CRAAB is offline
Old 11-01-2018, 06:10 AM
wpetko's Avatar
My Photos: (17)
DENNY
I agree. I just got a set of Bilstein 5100s for my dually & they are great! I had them on my last truck as well. I would get them again when the time comes. Many here have used the 5100s and will agree with me.
By the way, you are describing a pretty heavy load & it seems as if you are asking about which shocks will handle the load the best. Shocks ARE NOT a load bearing component of the suspension. They dampen movement in the suspension in order to improve ride, handling & retard wear of the tires & other components. PERIOD! If you need to level your truck due to the load then air bags are the way to go. I use the Firestone Ride Rite system & Iím very satisfied with it. Iím sure that others will jump in here with great advice as well.
Good luck & let us know what you decide & what works for you.
wpetko is offline
Old 11-01-2018, 12:19 PM
I agree with WPETKO shocks are meant to dampen not carry the load.
DENNY
DENNY is offline
Old 11-18-2018, 01:31 PM
5100's and steering stabilizer on my 11 supercab 4x4 with duratracs. Way better then the sock rancho's that came on it.l
2011 F350 4x4 sc sb
2010 Cyclone
DougW is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Upgrades and Aftermarket
