Roof clearance lights - Diesel Forum - TheDieselStop.com
'11-16 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
 2Likes
post #1 of 20 (permalink) Old 02-01-2018, 10:24 PM Thread Starter
millwrightdude's Avatar
Im wanting to add roof clearance lights on my 2015. Can someone give me the part # for the harness and the lights?
2002 XLT 350 crew cab Long box white
am/fm/cass/cd 4x4 auto
carpet delete 265/75/16 3.73
limited slip 9900lb package
X springs ranchhand bumpers
B&W Gooseneck & Companion hitch
Firestone airbags & compressor
Rancho shocks 278K and all stock
(Thinking about selling to buy a 6.7)
2015 F250 Regular Cab 4x4 6.2 Gas
B&W Gooseneck
Ranchhand bumpers
Firestone airbags and Airlift wireless compressor kit
26K miles
millwrightdude is offline
post #2 of 20 (permalink) Old 02-17-2018, 11:31 AM
Hello,
I'm kind of curious about this also as I just bought a 16.
I did have a 2000 prior to this. I got on Recon Accessories web site and they gave me all the info I needed but this has been 6-8 years ago. I then found on this forum where to tie into the wire running up to the top of cab for the harness.
I'll check back in and see if you get anything tho.
Corey Esson
2000, F350 Lariat, CC, Blue, At 110k miles (Oct 09) TRC Auto Trans, 4x4, Tymar Intake, Banks EGT, Tranny Temp and Boost A pillar gauges. Banks chipped, and exhausted. DIY LED Cab lights. 05 style Headlights. Marinco Mod
"When it's upsidedown and burning, you've gone too fast."
"Customer Service is an ATTITUDE!!...not a department!"
Corey Esson is offline
post #3 of 20 (permalink) Old 02-20-2018, 05:41 PM
NWRVR's Avatar
Here is a link to a thread on the FTE forum that has a step-by-step install for cab clearance lights. https://www.ford-trucks.com/forums/1...ts-thread.html
2016 F350 4x4 Ultimate Lariat crew cab SRW, LWB, 6.7 PSD, 20" wheels, Ingot Silver Metallic, DiamondBack tonneau cover, TrailFX wheel-to-wheel step bars.
NWRVR is offline
post #4 of 20 (permalink) Old 02-21-2018, 11:21 AM
Thank you!
post #5 of 20 (permalink) Old 08-25-2018, 03:53 PM Thread Starter
Ok, I have the lights and harness. Im going to start the install next week. I have a question what type of silicone to use?
B&W Gooseneck
Ranchhand bumpers
26K miles
post #6 of 20 (permalink) Old 08-25-2018, 04:39 PM
For as I know, there is no silicone used by the factory when they install the lights. They should have a gasket included with each lamp.
Larry
larrgh is offline
post #7 of 20 (permalink) Old 08-25-2018, 08:46 PM Thread Starter
I read on here some guys use silicone when they did their's. I did buy all Ford parts.
B&W Gooseneck
Ranchhand bumpers
26K miles
post #8 of 20 (permalink) Old 10-19-2018, 09:47 AM
MrTommy's Avatar
I've never been a fan of marker lights, but when I bought my 2016, it came with them. And, they aren't the amber ones. They are dark gray and actually look pretty cool. Is this a Ford option or did the previous owner upgrade them?
2016 F-350 Crew Cab. Thule AeroTab roof racks supporting Hullavator kayak racks (for lazy old people). Just added a Highway Products Pickup Pac, and their Truck Slide 'coaster'. Banks iDash.
MrTommy is offline
post #9 of 20 (permalink) Old 10-21-2018, 01:11 AM
Likely OEM location and style and a prior owner changed the color of the lenses.
Tom
MrTommy likes this.
02 CC XLT Dually 4x2, PSD w/6 spd, White w/Med Flint 40/20/40, TTT Mirrors, 4.10 L/S, PCM=AEB4, Receiver, Cab Steps, Homelink X Visor, Husky F&R Mud Flaps, AIS Ford Filter, WD Pyro & Boost in A-pillar, Line-X, Hutch Tank Mod, Pre-Pump Racor 645R30, 4" Banks Monster Exhaust, Mag-Hytec Diff Cover, Amsoil in Tranny & Diff.
Bye-bye 99 diesel-sucking automatic!!!
tomshep is offline
post #10 of 20 (permalink) Old 11-27-2018, 07:46 AM
MrTommy's Avatar
This is an incredile step-by-step instruction of how to do this. And it shows me why I won't be doing it. Way too much patience required, of which I have little. Ha.
This would probably be a $500 job at a truck shop.
MrTommy is offline
post #11 of 20 (permalink) Old 11-27-2018, 07:58 AM
MrTommy's Avatar
Well, as it turns out, these lights are Recon aftermarket units on my truck. And now I see that one of them flikers when I turn on the lights or open the door. Once it flickers, it either stays on - or goes off. And I'm not sure how long it stays on because I don't get out to look.
I found out that I can't simply get a new set of LED's for the one that flickers either. No no, I have to get the whole set of lights - and replace them all. That's not happening!
Even if they ALL burn out, the smoked lenses look cool during the day. And I don't care about once it gets dark and they don't work. I'm retired now and don't go anywhere once the sun goes down if I can help it.
MrTommy is offline
post #12 of 20 (permalink) Old 11-27-2018, 08:45 AM
I used 3M Marine 5200 sealant when I installed cab lights on my 2001.
Good luck on the job, that first hole is a major step.
2001 Lariat, F250, 7.3, 6-speed, 3:73, Ford AIS, MBRP 4" turbo back, ATS ported housing, 205 t-stat, Infinity DX w/DP Tuner 80hp tow, coolant filter, Hutched & Harpooned, EGT & Boost gauge. Fuel Mavericks with 285/18, 86k miles(Jan-2017) Bought brand new April 2001.
aclasshog is online now
post #13 of 20 (permalink) Old 02-11-2019, 11:17 AM
Bosstruck's Avatar
Cab Lights installed
Had cab lights installed on my 2012 this year. $325 out the door. Same place that did my window tint. they are oem with Led lights. Thought they look cool and should help for visibility when towing 5th wheel. Always thought they should have come with the truck. I have the integrated 5thwh/goose neck pkg from the factory. Safety factor is what I am looking at. Plus took the money from my side job to cover them. Read all the info on installing them but they do this for a living. Plus, they caulked them in and said covered for as long as I own the truck. Bing. happy. done. Sorry about pic. I did notice if you click on it pic is upright. Don't get it.
2012 Ford F350 XL, 4x4, SC,6.2 Gas, FX4(StickrsRemoved), LongBed, Oxford White, Xl PremPkg, Oem Fogs, 4-UpFitters, Remote Entry, Hill Assist/Descent, Pos Rear, ShiftOnFly, TracCntrl, SwayCntrl, InTegratBrakeCntrl, 4.30 Axle, Cloth,Am/FmCd,Mp3,SecurityPkg, Integrat 5th/GoosePrepPkg, Gvwr-10700, ReplaceRancho's w/4600 Bilsteins, 5100 SteerStabilizer, PlowPkg,BFG A/T Tires. Tow 2014 Sabre Silhouette 5th wheel rv, 37' rear living, 3-slides.
Bosstruck is offline
post #14 of 20 (permalink) Old 02-11-2019, 02:27 PM
It's only a $55 option LOL
Stroking it is offline
post #15 of 20 (permalink) Old 02-11-2019, 03:18 PM
Only if you or the dealer order them to be installed on the SRW truck when built, duh!
Most dealers do not order them for SRW trucks for their stock.
Larry
larrgh is offline
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Upgrades and Aftermarket
