Trailer wiring extension into bed acting funny! - Diesel Forum - TheDieselStop.com
'11-16 Upgrades and Aftermarket Upgrading or adding OEM or aftermarket equipment to your 2011-Up Super Duty.
post #1 of 12 (permalink) Old 07-17-2017, 03:12 PM Thread Starter
I apologize now as this is second hand information on my BIL's truck, a 2016 6.7l.
He has just installed a trailer wiring extension into the bed of his truck. From what I understand, he's pulled the connector off behind the bumper, put in this new extension, and plugged it back into the factory bumper connector. Then ran the new wiring to the bed to use with his gooseneck.
So, from what I gather, if you plug the trailer directly into the new wiring location, nothing works and there are faults on the instrument cluster. However, if you plug it into the bumper location, the faults go away and everything works. If you again, move the plug to the bed location everything STILL works for a while.
I am not sure what causes the bed plug to stop working (turn truck off or unplug trailer??) and I can get that information, but it sounds like it happens often enough that he can't just keep moving the plug to get it all to work.
He's tested all the wiring with a meter to make sure all the wires or connected properly between the factory and the new extension. Seems like a computer issue of some sort not wanting to recognize the new location?? Any ideas? Thanks!
2017 F-350 CCSB 6.7L
[old]2002 7.3L PSD, 6spd, 4x4 Off-Road, Super Cab, Short Bed, ARE Topper, SCMT Autometer gauges, Tymar, 4" SS aero-turbine exhaust, & WW.
'73 Bronco 351 SEFI, 35's & Locked!
Jesus_man is offline
post #2 of 12 (permalink) Old 07-17-2017, 06:30 PM
He needs to very carefully inspect for any of the wires having touched inside taped or covered harness with the top side plug not connected. Then try again once that plug is in place. The issue may be in the top side plug. The computer knows only continuity to a trailer or a short in the wires. There is no recognition of wiring to be done or detected. I have installed several of those Curt harnesses and had no issues. I have had the end plug where trailer plug inserts have bent pins. He needs to look in the back of that new plug to see if there is anything wrong there. If he used a plug up top where he cut and stripped and then set screw secured wires into a plug the same thing goes as far as the end plug having issues that can make the lighting and electric brake circuit monitoring go nuts.
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
post #3 of 12 (permalink) Old 07-19-2017, 07:43 AM
HeavyAssault's Avatar
My Photos: (6)
Isn't there any aftermarket harness that uses the OEM connections found on the underside of the receiver hitch?
2015 F-350 CCLB PSD 4X4 3.55 ELD
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
post #4 of 12 (permalink) Old 07-19-2017, 08:14 AM Thread Starter
Yeah, I think that is what he used, as it was a plug-n-play operation. However, that is an assumption on my part as I don't actually know that. But from the conversation I had, it T's off that connection.
post #5 of 12 (permalink) Old 07-19-2017, 09:02 AM
gearhead1011's Avatar
My Photos: (10)
There is a factory harness that uses a connector that breaks out of the harness somewhere under the bed. For some reason not all of the superdutys have that connector so you have to use the aftermarket harness that tee's off of the back of the connector by the hitch. My truck is one that does not have the factory connector for the in-bed receptacle so I used the aftermarket one and have never had a problem with it.
2012 F250 XLT
6.7 CCSB 4X4 Sterling Grey, B&W Turnover Goosenech Hitch, Air Lift LoadLifter 5000, 50 gallon Transfer Flow replacement tank, Weather Tech mats
gearhead1011 is offline
post #6 of 12 (permalink) Old 07-19-2017, 08:44 PM
All wide frame trucks came with the two connectors by the driver's side rear wheel/tire. The in-bed 7 pin connector was installed if one ordered the goose neck prep kit from the factory. The wide frame trucks came with the connectors even if bed delete was optioned.
Bed 7 pin harness - BC3Z-13A576-A
The narrow frame (no bed fleet/commercial/ambulance/etc) trucks did not have the two connectors by the driver's side rear wheel/tire.
Larry
larrgh is offline
post #7 of 12 (permalink) Old 07-20-2017, 11:39 PM
My Photos: (10)
Nope, not all of them. I went over mine several times before I bought the tee harness. There were a couple of other posts on here from others that did not have it also. http://www.thedieselstop.com/forums/...86/index2.html http://www.thedieselstop.com/forums/...gtails-287811/
2012 F250 XLT
post #8 of 12 (permalink) Old 10-16-2017, 10:45 PM
big_blue's Avatar
mine has given me trouble a couple of times. it's aftermarket. first time it wouldn't work and i realized it had come unplugged so reached up and plugged it in, then everything was screwy for a while and realized that the pigtail was clocked wrong at that same in-bed plug at the rear. you would think that you couldn't plug it in except for correctly, but i found a different way! every since then all has been well.
'99 F250 PSD 4wd CC LWB, 400+K Hard Miles!!! Sold
Never been in the shop in it's life!!!
this truck was the WINNER of the 2013 Tough Truck Challenge by Ford Commercial Vehicles Division! that's how we got the '14!
'14 F350 LWB SRW Crew Cab Lariat
'00 Excursion 7.3 2wd
big_blue is offline
post #9 of 12 (permalink) Old 02-01-2018, 08:07 PM
Quick question, does anyone have the factory gooseneck plug in location in the bed. I am adding the in bed plug and have an idea where I want it but would like to use OEM location. I have googled for pics but couldn't find any. Thanks
cjohnsonseed is offline
post #10 of 12 (permalink) Old 02-01-2018, 10:10 PM
Here are some photos of the 7-pin plug in the bed. There are factory installed with goose neck prep kit
http://lh3.ggpht.com/_xwec34prd2E/S4...ease%20044.JPG
http://www.thedieselstop.com/forums/...6/#post2240483
Larry
larrgh is offline
post #11 of 12 (permalink) Old 02-02-2018, 04:45 AM
Thanks again
post #12 of 12 (permalink) Old 02-02-2018, 12:16 PM
My Photos: (10)
Some pics and details of mine when I installed it.
http://www.thedieselstop.com/forums/...l-plug-309286/
A post with dimensions of the location that I used for locating mine.
http://www.thedieselstop.com/forums/...trucks-260895/
2012 F250 XLT
  Diesel Forum - TheDieselStop.com > 2011 - 2016 Ford Super Duties > '11-16 Upgrades and Aftermarket
