'15 F350 info screen - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 12-16-2018, 04:03 PM Thread Starter
Bw3
Recently bought a ‘15 xlt. Info screen between tach and Speedo stuck on mileage screen. Buttons on steering wheel do nothing. Help!
Bw3 is offline
post #2 of 6 (permalink) Old 12-16-2018, 10:03 PM
does it have an orange bar in the middle of the screen?......if so, the screen is paused, you need to press the "OK" button on the left side of the steering wheel.
Larry
larrgh is offline
post #3 of 6 (permalink) Old 12-16-2018, 10:45 PM Thread Starter
Bw3
No orange bar. Ok button does nothing. Arrows do nothing. It will tell me if a door is open, etc. but cannot click ok to clear it. Once door closed.. back to mileage screen.
Bw3 is offline
post #4 of 6 (permalink) Old 12-17-2018, 07:33 AM
ford_doctor's Avatar
Could be the switches or the steering column control (SCCM) module has failed. Do the right side switches and the horn function? If not then the sliding contact is suspect. I have also seen network faults cause the steering wheel functions fail... regardless, for your own sake I would have the vehicle scanned for codes IN ALL MODULES before poking around, disconnecting things or randomly throwing parts at it. Doing so will ultimately save time and money overall.
2016 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #5 of 6 (permalink) Old 12-18-2018, 10:32 AM Thread Starter
Bw3
Thank you. It is headed back to the dealer tomorrow to see what they can figure out.
Bw3 is offline
post #6 of 6 (permalink) Old 01-11-2019, 09:25 AM
I hope your dealer is better at that than my local dealer!
ACAMS is offline
