2011 tire pressure monitoring system - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 09-09-2019, 04:10 PM Thread Starter
My 2011 F250 truck has placard with tire pressure recommendations of 65 psi front, 80 psi rear tires. I can understand rear tires at 80 psi when hauling my RV. But for untethered driving I would like to try 65 at the rear.
So my concern is the TPMS may flag on the dash if I set rear tires to, say, ~65, as the front are.
Question - will I have to have the truck computer reprogrammed for lower monitoring pressure, set like the front tires (@65 psi). Can it be reprogrammed, or will I run into flack with dealer? If not able to reset like front tires, what is lowest it could be programmed?
I wouldn’t want to lower rears to 65, drive with tire warning display looking at me all times.
Appreciate if anyone did this, offer experiences. Or if a Ford tech here could advise.
TIA.
CajunMick is offline
post #2 of 3 (permalink) Old 09-09-2019, 05:40 PM
If you have FORScan, or a buddy has FORScan, on a laptop and an OBDII interface such as a bluetooth, WIFI or USB ELM327, you can reset the pressures, else you will have to convince a tech with Ford's IDS to reset them.
you can search this link for TPMS
http://www.ford-trucks.com/forums/14...uilt-data.html
Larry
larrgh is online now
post #3 of 3 (permalink) Old 09-10-2019, 10:52 PM
My low pressure sensors don’t activate until I’m down to 50psi. Don’t think I’d change that
Buffalohead1 is offline
