911 Assist fail - Diesel Forum - TheDieselStop.com
 3Likes
  • 2 Post By Calico5
  • 1 Post By ACAMS
post #1 of 12 (permalink) Old 01-23-2019, 02:32 PM Thread Starter
911 Assist fail
I get an error 911 Assist fail contact dealer for assistance ..... anybody ever have this problem?
My dealer doesn't even have any parts changers that can spell "assistance"
They had my truck for over 4 months and replaced the PCM, BCM and all the ?CM's and modules trying to get it to run, now I just have this problem and a couple more.
The truck is in another shop right now getting deleted and runs fine finally. (other than limited to 50 MPH)
I think it is in the SYNC unit, but I don't know what to do and neither does my dealer.
ACAMS is offline
post #2 of 12 (permalink) Old 01-24-2019, 11:02 PM
Calico5's Avatar
Gawd...how I love my "simple" old 7.3!
bugman and RT like this.
Al in SoCal
AFE Intake; Garrett 38R; DieselSite Turbine Jacket
HPS Hi-Temp CAC Boots; Banks Big IC, Banks Engine Brake
External Oil cooler & Remote filter; Stealth 4-line Twin HPOP, Melling LPOP
Swamp's: 160cc/30% Injectors & HVHF IDM; DP-Tuner F5; Fluidamper Balancer
Custom Full Reg.-return Fuel System, Pre-& Post-pump filtration
Mishimoto Radiator & Exp. Tank; T444 Water Pump w/Filtration
Bellowed S/S Up-pipes; 4" Turbo-back Custom Exhaust into Twin Stacks
SouthBend D-D Clutch; ZF 6-spd w/CoreShifters Short-throw Stick
GearVendors O/U Drive
Calico5 is offline
post #3 of 12 (permalink) Old 01-25-2019, 10:16 AM
bugman's Avatar
My Photos: (12)
If you are seeing it on the touch screen it might have something do do with the sync unit that has to be mated with a cell phone.
bugman is online now
post #4 of 12 (permalink) Old 01-25-2019, 12:22 PM Thread Starter
I mated it with my phone, but it still have the popup and it stays on the screen until I click OK.
ACAMS is offline
post #5 of 12 (permalink) Old 01-25-2019, 02:22 PM
RT
RT's Avatar
Amen. My neighbor asked to use my truck. A few minutes later he was back holding the keys asking, “Where’s the remote? How do you unlock the doors?” Um- put the key in the lock and turn...
RT is offline
post #6 of 12 (permalink) Old 01-25-2019, 03:17 PM
bugman's Avatar
My Photos: (12)
There is a Sync help phone number in your owners manual that you might try calling.
1-800-392-3673
You might also have to reboot the system.
post #7 of 12 (permalink) Old 01-25-2019, 04:47 PM Thread Starter
THANKS ..... that is by far the most help I have had ..... including from my dealer!
EDIT: Well I googled how to reboot, and I have already done that, I guess I will have to call ....... THANKS!
ACAMS is offline
post #8 of 12 (permalink) Old 01-25-2019, 08:48 PM
Kraig1957's Avatar
I had that as an intermittent problem on my ford mustang with SYNC3. It has only happened twice in the car in two and a half years, and I have 911 assist set to off. The service manager at the dealership said they can't fix it unless it is broken when I take it to them.
I also have 911 assist set to off in my pickup with mytouch. After the latest updated it asks me every time if I want it on.
I feel if I need 911 I'll make the call.
2016 F350 DRW FX4 Lariat King Ranch Crew Cab 6.7 V8
2011 F350 SRW 4X4 Lariat Crew Cab 6.7 V8 (Sold)
2006 F450 DRW 2X4 XLT Stake Bed Crew Cab 6.0 V8 (Sold)
2016 Mustang GT Premium 5.0 V8
2003 Crown Victoria LX 4.6 V8
1967 F100 Pickup 352ci V8, C6 automatic
1972 Pontiac Lemans 400ci V8, Turbo-Hydromatic 400
1964 Pontiac Catalina 389ci V8, Roto-Hydromatic 375 (Slim-Jim)
Kraig1957 is offline
post #9 of 12 (permalink) Old 01-26-2019, 01:27 PM Thread Starter
Yes, I have it off, but the popup saying it is broke still pops up, AND like you sometimes it asks me if I want to turn it on.
ACAMS is offline
post #10 of 12 (permalink) Old 02-10-2019, 09:38 AM Thread Starter
FIXED!!!!
I signed up on the Ford owners site and there was a SYNC update download for my truck and that fixed it!
ACAMS is offline
post #11 of 12 (permalink) Old 02-10-2019, 11:40 AM
FIXED!!!!
were you able to upload the file that showed Ford Owner you upgraded Sync? Mine will not upload due to an error on the website.
Larry
larrgh is offline
post #12 of 12 (permalink) Old 02-11-2019, 12:32 PM Thread Starter
I didn't try ... Once it was fixed, I was done with them .
larrgh likes this.
ACAMS is offline
