Basic Question Fuel filters - Diesel Forum - TheDieselStop.com
 2Likes
  • 1 Post By ford_doctor
  • 1 Post By RGVAL
post #1 of 9 (permalink) Old 08-30-2019, 08:06 PM Thread Starter
Question Basic Question Fuel filters
2015 250 6.7l diesel 76,000 approx miles. Do not know history, How do I know when to change the two fuel filters ,will the display tell when ?
Thanks RGVal
RG. 2015 Ford 250 6.7l First diesel Towing 22" Travel Trailer 2-3mos per year
RGVAL is offline
post #2 of 9 (permalink) Old 08-30-2019, 09:16 PM
If the previous owner or the tech reset the filter monitor, it will tell you. Most seem to change the fuel filter ever second oil change (15k) instead of waiting till 22.5K miles.
Do you know who serviced the truck for oil changes, etc? If a Ford dealer or Quick Change, then it will show up on an Oasis report or the Ford app FordPass.
A filter, frame and engine, cost about $65. If unsure, you can go ahead and change them.
When changing the frame filter, loosen the cup 3 turns to break the siphoning effect before opening the yellow drain valve.
When installing the new frame filer, lube the large o-ring with clean engine oil prior to installing the filter cup.
Larry
larrgh is offline
post #3 of 9 (permalink) Old 08-31-2019, 05:27 AM
ford_doctor's Avatar
Larry, CUSTOMER PAY service items DO NOT SHOW ON OASIS which will only provide the warranty history.
RGVal, the answer is simple. If you do not have a documented history you have no idea when the filters were changed and the truck will not know or tell you. If you want piece of mind go ahead and change them and begin your own service documentation. You could remove the primary filter cap and inspect the element however you would need a new o-ring for the cap and reusing them is not recommended.
larrgh likes this.
2019 Ford Fusion ENERGI Titanium Plug-in Hybrid
Diesel Technician Society
Diesel Mentor Directory
ford_doctor is offline
post #4 of 9 (permalink) Old 08-31-2019, 05:39 AM
Keith. Thank you. I did not know that. I thought if you had the truck serviced, oil change, filters, etc, at the dealer or Quicklane it would show. Will add to my tidbits of useful but not always needed knowledge bank in the old brain.
Larry
larrgh is offline
post #5 of 9 (permalink) Unread 09-01-2019, 10:35 AM Thread Starter
as always this forum does not fail. Thank you,
FYI the cheapest price I found was at 1Aauto parts @ $95.00 ,NAPA was $130.ish did not check with dealer.
RGVAL is offline
post #6 of 9 (permalink) Unread 09-01-2019, 11:57 AM
There is a listing on eBay for 5 filters for $240.
https://www.ebay.com/itm/5-MOTORCRAF...53.m1438.l2649
You can also check here
https://www.dieselfiltersonline.com/...2-filters.html
Approx $50 not sure about shipping.
Larry
larrgh is offline
post #7 of 9 (permalink) Unread 09-01-2019, 12:26 PM
Fuel filters aren't cheap. I only get mine at the dealer but my parts guy is a friend so I get a deal. Maybe not much as Ebay but cheaper than Joe Blow LOL
Stroking it is offline
post #8 of 9 (permalink) Unread 09-03-2019, 04:19 AM
HeavyAssault's Avatar
My Photos: (6)
I love the complaints about fuel filter prices.
2015 F-350 CCLB PSD 4X4 3.55 ELD
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
post #9 of 9 (permalink) Unread Yesterday, 08:06 PM Thread Starter
Thanks to all that responded to my call for help I did find OEM filters from Ford on Amazon for $67. and change with free shipping.
Thanks again
larrgh likes this.
RGVAL is offline
Currently Active Users Viewing This Thread: 2 (1 members and 1 guests)
PSDStu
