Building a F350 dually into a double dually - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By bobofthenorth
post #1 of 15 (permalink) Old 02-11-2019, 04:34 PM Thread Starter
AzScott59's Avatar
What do I need to build a double dually. For those that don't know. Its adding duallys to the front axle. I've heard all the pros and cons but never a straight answer
AzScott59 is offline
post #2 of 15 (permalink) Old 02-11-2019, 05:21 PM
I have never seen one nor heard of one. Have you ever seen one in person?
I can think of a few problems off hand.
Even with steel wheels, are the studs long enough to properly secure the two wheels to the front hub.
What kind of fender clearances will be needed to properly turn sharp, left or right. You could take your front wheels, turn the 180* and mount them. Then try turning the steering wheel lock to lock.
Will the hub bearings be of adequate load bearing ability to properly handle the dual wheels at highway speeds and turns.
During rain or snow, how will you adequately prevent visibility degradation.
If you have any photos or links, post them.
Larry
larrgh is offline
post #3 of 15 (permalink) Old 02-11-2019, 05:36 PM
Did find this discussion with a google searh
https://www.powerstroke.org/forum/du...nt-wheels.html
Larry
larrgh is offline
post #4 of 15 (permalink) Old 02-11-2019, 10:42 PM
I think it would be a simple bolt on with steel rims (lug length issue). I am pretty sure the hubs would fail quickly so up grade to Danatrack units. https://turtleexpedition.com/tech-st...bearing-thing/. I will be taking my studded tires of in a few April, they are on steel rims I can see if they will bolt up. Lay a straightedge on the outside of the tire turn lock to lock and see if it clears the fender. Might have to upgrade steering box and pump or just make sure you are moving when you want to turn. If you did upgrade to bigger rim and went with super single that might be better.
DENNY
1999 F350 AUTO 4x4 CC LB DRW 4.10
DENNY is offline
post #5 of 15 (permalink) Old 02-12-2019, 08:26 AM
bobofthenorth's Avatar
Why???
Randy 4614 likes this.
2006 F250 6.0 4x4
bobofthenorth is offline
post #6 of 15 (permalink) Old 02-13-2019, 02:41 PM Thread Starter
AzScott59's Avatar
Thanks for the input and ideas. I've always had off the wall ideas. I'll probably charge onto it. And if I dont like it put it back. I have it lifted 6 inches. I'll send pics when I get it done.
post #7 of 15 (permalink) Old 02-13-2019, 09:26 PM
Just be aware that you won't be able to turn. Hopefully you won't ever take it onto the street.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, Odyssey extreme 65-PC1750T batteries, Michelin LTX-MS2 rear tires, Sumitomo Encounter front tires, Shell Rotella Ultra elc, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: two starters, batteries, cps, brakes, tires, alternator, ball joints, locking hub, wheel hub, AC compressor, serpentine belt, power steering pump, driver's side window, ignition switch, o-ring, Spectra premium radiator, water pump, fan clutch, fan blades, thermostat, thermostat housing, tensioner. Stolen twice so far, but recovered both times with major damage.
DonWarkentin is offline
post #8 of 15 (permalink) Old 02-14-2019, 01:35 AM Thread Starter
AzScott59's Avatar
Slow and wide
post #9 of 15 (permalink) Old 02-14-2019, 02:10 AM
I think it should work fine if the fender clears. Not quite like stock but it would be fun to have one. If you do a google search you can find a pic of a 95 or so with duel front wheels at a gas station and military trucks with them. Should not be that bad on soft stuff. Hardball would most likely be a bit of work turning. If that hub holds it should be a great truck in soft sand or mud. Post some pictures when you get er done!
DENNY
DENNY is offline
post #10 of 15 (permalink) Old 02-14-2019, 11:56 AM
Turns out there is a company that sells the adaptors that will convert the front from single to dual wheels.
https://www.southwestwheel.com/c-104...l-adapter.aspx
Still, I don't understand why you couldn't just exchange the studs for longer one. I would turn the front wheels around and check the clearance turning lock to lock. With the six inch lift, you may be OK, or you may need to modify the fenders if there is not enough clearance. I would definitely put in the Danatrack units.
The steering components will not be able to turn the wheels very well, especially on pavement. It will be an off-road only vehicle. Do not take it onto the road.
post #11 of 15 (permalink) Old Yesterday, 03:40 AM Thread Starter
AzScott59's Avatar
Thanks all. All your inputs are appreciated.
post #12 of 15 (permalink) Old Yesterday, 11:26 AM
tbeck's Avatar
Look for some pictures of Bob Chandler's original BIGFOOT 4x4x4. It's been a long while but I seem to recall that was the setup, duals on front and rear.
'94 1/2 F250 4x4, SuperCab XLT, 5 spd, SMF w/ Valaeo clutch, 4.10 (syn. lube), Cenex Maxtron 5W40 Syn, manual hubs, B&W Gooseneck hitch, Cooper ST Maxx tires in 235/85R16, authentic TYMAR intake, 4" AFE exhaust, FRP mod., SD starter, Isspro boost/pyro,digital thermometer, homebuilt exhaust brake, 194K Fresh factory injectors at 186K, TS-6 chip. Dana 60 conversion! "Its only a pickup. Trucks have a button on the shifter!"
tbeck is offline
post #13 of 15 (permalink) Old Yesterday, 11:01 PM
History of BIGFOOT Bigfoot 44, Inc. ? Monster Truck Racing Team
Yes, here it is. Obviously not a street machine. But if you are looking to crush cars, it might work well.
post #14 of 15 (permalink) Old Yesterday, 11:08 PM
http://bigfoot4x4.com/blog/wp-conten...4/02/bf1-9.jpg
Is this sort of what you have in mind for your truck?
post #15 of 15 (permalink) Old Today, 06:00 AM Thread Starter
AzScott59's Avatar
The bigfoot trucks are pretty cool . Thanks for the pics. Mine wont be that extreme.
Similar Threads
Rear Alloy Wheel for 1999 F350 4x4 dually bea_rolf@fidibusteam.com Wheels, Tires, Brakes, and Suspension 6 01-09-2013 10:43 AM
2011 6.7 F350 Dually 2500 mile report snowhawk2 '11-16 General Questions 10 03-10-2011 07:18 AM
Anyone have a F350 Factory 4x4 dually (cab and chassis?) KentuckyDiesel Power Strokes 1994-1997 General 13 02-14-2007 10:17 AM
Big Ford Fuel-Related Part Numbers Post DaveBey Power Strokes 1994-1997 General 4 12-07-2005 02:06 PM
