Electrical Question - '2016 F350 SRW - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 10-09-2018, 09:24 AM Thread Starter
I bought the vehicle new and it never seemed to really blow hard from the vents, even with max AC and recirculation selected. This past several months it would often not blow at all or blow based upon the engine RPM. The local dealership is saying that is was due to a bad battery. I am having a hard time following that line of thought because as I understand it once the engine is running the alternator should be handling all of the electrical load. Am I missing something?
#BMFC is offline
post #2 of 4 (permalink) Old 10-09-2018, 10:20 AM
when you dial the temp down as low as it will go for the AC, how forceful does it blow? I know above say 71 or 72, it is reduced blower speeds.
Larry
larrgh is offline
post #3 of 4 (permalink) Old 10-10-2018, 09:38 AM
DKR
DKR's Avatar
I agree it doesn't make sense but I do know this, that modern electronic-computerized systems rely heavily on the batteries. I'm not saying it's the cause of the issue but if they are bad they need to be replaced anyway.
2015 Ford Platinum F350 CC SRW LB 4X4
2016 Cedar Creek 36CKTS (My Last FR Product)
20,000 LB Reese GooseBox Hitch
DKR is offline
post #4 of 4 (permalink) Old 10-10-2018, 05:59 PM
HeavyAssault's Avatar
My Photos: (6)
Don't pay for any work that dealership does until it fixes your issue. If their work doesn't fix it, make them keep trying. Unless they can show you a battery test that shows a bad battery.
2015 F-350 CCLB PSD 4X4 3.55 ELD
Some stock stuff, some modded stuff, some deleted stuff.....
HeavyAssault is offline
