Fifth wheel turn over hitch ball - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 08-16-2016, 09:32 AM Thread Starter
clev's Avatar
My Photos: (16)
My 2012 long bed KR came with the 5th wheel hitch option. I've never had a fiver, always had trailers, and know little or nothing about fifth wheel hitches. I DO KNOW that I do not want to fool with, nor have the big hitch in the bed of the truck. Can someone advise me on what I need for a turnover ball that will fit the hardware that came with the truck?
2012 F-350 SD Crew Cab, SRW, LWB, 4 X 4, FX4 Offroad, Bilsteins and Bilstein Steering Stableizer, AirLift Air Bags with onboard compressor, BedLocker electric bed cover, Hellwig 1 1/4 inch rear anti-sway bar, 2017 G37 Turbo, ATS Stage I towing transmission kit, White Platinum w/Adobe, Navigation, Moon Roof, 5th Wheel Prep, Step Tail Gate, front 2 inch receiver, completely insulated, Pioneer speakers, King Ranch Package
'99 E-350 HiTop Companion Van Conversion, 7.3 SD Diesel, 5-tune DP Tuner, Triple AutoMeter C2 A-pillar gauge pod, dash mount AutoMeter C2 fuel pressure gauge, twin K&N's, 203* mod, Deraler tubed trannie pan, B&M trannie cooler, AirLift air bags, Bilsteins, 4" DiamondEye turbo back exhaust, Air Dog fuel filtration system, Hutch mod, header wrapped and high temperature painted Bellowed Up-Pipes.
clev is offline
post #2 of 14 (permalink) Old 08-16-2016, 10:52 AM
If this is the Ford/Reese factory hitch system, there is no "turn over ball". There were plugs that came with the truck to cover the 5 holes.
If it is a turn over ball hitch with a release lever in the fenderwell area, then you will need to determine what hitch system you and and what balls work with it.
Is there 5 holes in the bed or just the one for the gooseneck ball?
Larry
larrgh is offline
post #3 of 14 (permalink) Old 08-16-2016, 03:23 PM Thread Starter
clev's Avatar
My Photos: (16)
Hi larrgh; as I posted, I know little or nothing about fifth wheels or hitches. I was referring to basically any type of ball mount for a goose neck and my truck does have the 5 holes. I did find the Curt ball kit made for ford trucks with the 5th option; number 60609. It appears to be exactly what I'm looking for.
clev is offline
post #4 of 14 (permalink) Old 08-16-2016, 03:58 PM
Reese and Ford also has the balls.
Reese - Elite Series Gooseneck
https://accessories.ford.com/gooseneck-kit.html
Larry
larrgh is offline
post #5 of 14 (permalink) Old 08-18-2016, 02:31 PM
Clev-
Just to be clear the 60609 Ball you said you are looking for is a gooseneck ball and not a fifth wheel hitch.
A fifth wheel hitch, 16039 will mount in your factory system as well and is removable.
Just depending on what you are hauling, the gooseneck ball may or may not be adequate for your application.
My travel trailer requires 16039, it would void warranty and not be as safe if I hauled with a gooseneck adapter kit to fit the 60609 ball mount, and my flatbed gooseneck trailer requires 60609.
My 19k lb 5ver pulls better than my 10k trailer fully loaded with skid steer and tractor that weighs about the same as the 5ver, and I can only equate it to the different hitch styles.
Dont want to sound like I know it all, but safety is my only concern when I go down the road.
Hope this has helped.
MRH2008
2016 F350 King Ranch 6.7 PS-4x4
MRH2008 is offline
post #6 of 14 (permalink) Old 08-19-2016, 12:23 AM
dirtytires's Avatar
Just my 2 cents, but a fifth wheel is easier hook up and, as stated, seems to provide a better ride. The big hitch is easily removable when not in use.
Also, a gooseneck ball/kit should come with 3 pieces. The ball goes in the big center hole and 2 "eye bolts" that fit in two of the outer holes for the safety chains.
Just a guy with a truck and a wrench.
dirtytires is offline
post #7 of 14 (permalink) Old 08-21-2016, 11:03 AM
DKR
DKR's Avatar
Clev,
I have a 2015 F350 CCLB SRW with the factory hitch and I tow a 15000 lb 5th wheel trailer. When traveling I need access to the bed and like you really didn't want a large hitch taking up most of the bed.
There were 2 options we looked at very hard, one was the Andersen Ultimate Hitch we chose not to go through this route because I didn't want to install this every time we hooked/unhooked the trailer. Below is a link.
Aluminum Ultimate 5th Wheel Connection 2
The second choice was the Reese Goose Box which is an approved kingpin replacement of the frame manufacturer.
We ultimately went with this for a couple of reasons the first being it has a built in suspension system and the second the simplicity of hooking up.
All we have to do is put the GN ball in the truck and back up and hook up, when we get where we're going the only thing in the bed is the ball and it comes out in a few seconds easily. We've had no issues with it except replacing a faulty valve core and will highly recommend the product. Here is a link.
Reese - Goose Box
DKR is offline
post #8 of 14 (permalink) Old 08-22-2016, 08:59 AM
johndeerefarmer's Avatar
Originally Posted by DKR View Post
Clev,
Reese - Goose Box
How long is your truck bed?
What kind of turning angle can you get?
How many inches of clearance do you have from the bed rails to your fiver? The instructions for the Goosebox say to install it one hole lower than your old pin box. If you did this do you have any holes left? (I am wondering about height since the 17 SD has 1" taller bed walls)
I am trying to decide if I want a Goosebox or not. Thanks
johndeerefarmer is offline
post #9 of 14 (permalink) Old 08-22-2016, 01:35 PM
Reese sells a gooseneck ball that is 1" taller than the standard ball. This should help alleviate the problem with the 2017 bed height being 1" taller.
High-Rise Pop-In Ball for Reese Elite Series Underbed Gooseneck Hitch - 1" Rise - 2-5/16" Reese Balls RP19315
Larry
larrgh is offline
post #10 of 14 (permalink) Old 08-23-2016, 02:03 AM
dirtytires's Avatar
I did similar research and looked seriously at the Reese goose box. At the time, Reese (who I contacted directly) was not willing to tell me that my trailer frame would hold up as well as the original pin box. It was concluded that 5th wheels and goose necks are designed differently and the stresses on the trailer frame are different. I feel changing one to another is just not a good idea.
post #11 of 14 (permalink) Old 08-23-2016, 08:11 AM
DKR
DKR's Avatar
We're in Northern New Mexico on vacation right now and somewhat internet challenged but we hooking up later this morning and I'll take some measurements and upload some pics if I have a good connection tonight if not I know I'll have a good connection Wednesday
The truck is a stock 2015 F350 4x4 CC SRW LB.
DKR is offline
post #12 of 14 (permalink) Old 08-23-2016, 06:11 PM
DKR
DKR's Avatar
Ok I'll give this a whirl. Like I said it's an 8' bed and when I hooked up this morning the space between the bed and the trailer was about 7 3/4".
Here is what my truck usually looks like.
Here it is with the 5th wheel this morning. Camper weighs about 15k all together loaded for a 2 week trip, with 12k on the axles and 3k on the hitch per the scale.
I took these pics for the folks that built my stainless big dog box so they could build me a small box for the 5th wheel. (Note the hitch was moved down one bolt setting.
These plastic boxes are 24" tall and the trailer is about 5 1/2 above them. This was at about 90 degrees with the eyeballometer.
DKR is offline
post #13 of 14 (permalink) Old 08-23-2016, 06:23 PM
DKR
DKR's Avatar
We have had no issues hooking this up, the ride from the Goose Box is an air ride and in my opinion wonderful. I have a ball that weighs a few pounds compared to a 5th wheel hitch which is over 100lbs.
Our kit did come with 3 pieces however the laws for gooseneck trailers and 5th wheel trailers differ GN are required to have safety chains 5W are not. (That said I keep a set of chains in my tool box in case I run into Barney Fife who doesn't actually know the law.)
I also spoke to Lippert (the Frame Manufacturer) and the Reese GooseBox is an approved product and will not void the warranty.
DKR is offline
post #14 of 14 (permalink) Old 08-23-2016, 09:50 PM
dirtytires's Avatar
It was 3 years ago when I looked at them and they were fairly new to the market. Nobody (Reese or lippert) would back it and my trailer manufacturer had sold out a few years earlier. I very much wanted to use the goose box could not get an expert anywhere to say yes tho I found many to say no.
I am glad to hear that it is working for you and hope you keep us updated. in the meantime, I would watch for stress cracks at the top of the trailer frame as this was cited as the biggest risk area.
I'm also jealous....I would love to take a 2 week vacation!
