grease zerks - Diesel Forum - TheDieselStop.com
 1Likes
  • 1 Post By larrgh
post #1 of 6 (permalink) Old 02-03-2019, 06:39 PM Thread Starter
grease zerks
Any grease zerks on front end,2016 f350 4 wd..
2016 F350 FX4 CC Lariat pkg-diesel 6.7
jwbboat is offline
post #2 of 6 (permalink) Old 02-06-2019, 06:22 AM
Probably
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is online now
post #3 of 6 (permalink) Old 02-06-2019, 08:33 AM
GaryF's Avatar
Will be surprised if you find any. Unless someone had changed out a worn-out steering or suspension component with an aftermarket one with grease zerk.
My 13 has none.
Gary
2013 F350 CC 4x4 DRW 6.7 Lariat Ultimate package.
2013 Heartland Bighorn 3610RE Fiver
*Previously owned *
2004 F350 CC Lariat 6.0 4X4 156 WB
2001 F250 CC XLT 7.3 4X4 156 WB
2006 Heartland Bighorn 3200RL Fiver
GaryF is offline
post #4 of 6 (permalink) Old 02-06-2019, 10:52 AM
ArcticDriver's Avatar
The trend has been sealed bearings with very high quality, long life greases.
I think part of the trend away from grease zerks is so few owners ever used to actually grease them consistently.
SOLD:
ArcticDriver is offline
post #5 of 6 (permalink) Old 02-06-2019, 06:41 PM
the only grease fitting you might have is on a 2 piece driveshaft. Otherwise, there probably are none
jwbboat likes this.
Larry
larrgh is offline
post #6 of 6 (permalink) Old 02-07-2019, 11:38 AM
I have 2015 F350 with Max Tow that gets the wider track front axle. It has grease fittings on some steering pieces and on the u joints at the steering knuckles. I'm not sure if there is that much difference between the 350 std and 350 with the 450 axle housing that the std version does not have these.
I have been drilling, tapping and adding grease fittings to front end parts on my trucks and on my cars for years. I don't replace ball joints on my vehicles. The good grease/sealed better is valid until the boots crack open. With bad boots pumping grease through on every oil change will keep them in good condition. When I get ball joints for many vehicles, most all trucks, the boot is not attached. Rarely is there any real presence of grease in the new part. I'm talking about OE ball joints that have no grease fittings though many OE replacements have the fittings. WHile we are talking about this, GM does give you a full set of grease fittings on their HD trucks. DID YOU HEAR THAT FORD???
2015 F350 Platinum Max Tow What a beast with the 4.30 gears!
2006 F450 CC Hauler bed 4x2 6.0 L 6.0 auto, Lariat, 4.30 r/a, SCT, 4in exh. 103K New heads to repair diesel in coolant, 148K.
2006 F350 Lariat CC Dually 4X2, 6.0 auto 4.10 LS, SCT, airbags, 4 in. exh. 154K Rebuilt engine to repair damage from burned piston. One head to fix fuel in oil problem.
35+5 foot double tandem axle flatbed trailer.
36 foot double tandem axle flatbed trailer
36 foot Platinum 6 horse LQ, side load, full width back tack
2003 EB Expedition 171K (no engine repairs, gas burners are the new longevity leaders)
2004 Volvo V70R AWD-high miler in fleet, 253K (no engine repairs) Hail totaled it but I kept it. Looks like a golf ball now.
Suzuki Carry KEI truck, 660cc 3 cyl DOHC EFI 4X4 5 speed RHD. Sort of a Smart Car sized pickup. Eats Gators and Mules for lunch.
jimmy is offline
Similar Threads
Broken grease zerks on ball joints 2003 4x4 F350 flyingv2003PS 1999-2007 Upgrades and Aftermarket - General 6 08-29-2011 06:35 PM
Grease zerks FordMudder 2008- 2010 General Questions 5 12-02-2009 08:11 PM
Tie rod grease zerks Tony_ONeil '99 & up 7.3L Power Stroke Engine and Drivetrain 1 10-10-2009 05:05 PM
Grease Gun Tip for Front Axle Zerks skroesen 1999-2007 General Questions 8 01-03-2007 09:48 PM
Grease Zerks skroesen 1999-2007 General Questions 7 08-23-2006 06:57 PM
