Ideas about additives - Diesel Forum - TheDieselStop.com
 2Likes
  • 1 Post By larrgh
  • 1 Post By wpetko
post #1 of 9 (permalink) Old 03-04-2019, 06:47 AM Thread Starter
AzScott59's Avatar
My 2011 F350 6.7 superduty dually rolling over 100,000 mile mark and just wondering any thoughts about additives to engine oil..etc
AzScott59 is offline
post #2 of 9 (permalink) Old 03-04-2019, 08:33 AM
I wouldn't add anything to the oil Most of that stuff is snake oil anyway. I only use synthetic oil. I have had excellent results with that. Sure it's more expensive but for me it's worth the extra cost. I only use Motor craft oil even thought you could find cheaper but that's just me. I have 5 fords and I run synthetic in them all.
Stroking it is offline
post #3 of 9 (permalink) Old 03-04-2019, 02:52 PM
ArcticDriver's Avatar
Modern engine oils are the cats meow right out of the bottle with excellent additive packages already mixed in.
Diesel fuel additive is a different story. It may not be needed in all circumstances but it can help in many.
SOLD:
ArcticDriver is offline
post #4 of 9 (permalink) Old 03-05-2019, 12:21 AM Thread Starter
AzScott59's Avatar
Thanks for the input. Even tho I work on diesels this is MY first diesel . I also use Motorcraft products on my truck. I've found in all my other trucks (gas) that by changing the oil every 3k my engines lasted forever with no problems. I put 200,000 miles on a 94 Ford with a 351 Cleveland with no drips and it ran perfect . I also do little or no major modifications to the engines. Thanks again. I'm glad I joined this group. I've learned alot.
post #5 of 9 (permalink) Old 03-05-2019, 08:19 AM
Changing the oil in your diesel every 3,000 miles will get expensive fast. I just wait till the truck tells me to change my oil. In my cars that don't tell me I go around 5,000 miles. if I have to add oil than I just go ahead and change it.
Only additive I use in my fuel is cetane. I get it at my ford dealer. That is the only place I get it from.
post #6 of 9 (permalink) Old 03-05-2019, 08:22 AM
Wal Mart oil is good oil. Like Motorcraft oil, some one makes it and bottles it for both.
badbart likes this.
Larry
larrgh is offline
post #7 of 9 (permalink) Old 03-15-2019, 08:14 AM
wpetko's Avatar
My Photos: (17)
This is true. I retired from the ExxonMobil refinery in Beaumont, Texas &, while I never worked at the Blending & Packaging Plant, I have seen it & knew guys that worked there. They put the same oil in different bottles or jugs for different customers. As long as the oil meets specs (& it does) it’s fine.
The same thing is true for gasoline & diesel fuel. They all meet the minimum octane & cetane requirements & NO MORE. These companies do not believe in “product giveaway”. Often these companies will buy fuels from each other to save on shipping & other expenses. For example, Chevron will by fuel from Valero because the Valero refinery & distribution center may be closer to several of their Chevron stations. They all do this & there is no problem because the fuel will be EXACTLY the same at the time of delivery. Obviously, there may be concerns about age of the fuel or water in the tanks, but these problems occur on a case by case basis at various individual stations & have nothing to do with brands.
larrgh likes this.
2013 F-350 Lariat 6.7 L PSD Crew Cab Dually, FX4, white platinum metalic tri-coat with black interior, N-Fab step bars, factory spray-in bedliner and 5th wheel hitch, trailer tow package, integrated brake controller, upfitter switches, Sync with My Ford Touch, memory group, remote start, reverse sensing with rear view camera, nav, satillite radio, Weather Tech floor mats, limited slip diff, moon roof, climate controlled seats, engine block heater and tailgate step.
2014 Lifestyle (formerly Carriage) 5th wheel 38' long with 3 slides & all the goodies.
SOLD: 2005 F-350 Lariat, 6.0 PSD, Torqueshift auto trans, crew cab, SRW, short box, FX4, ESOF, limited slip dif., tow command, upfitter switches, 6 CD changer, Lariat Lux. package, camper package, engine block heater, triple A-pillar gauge set (Autometer) with pyrometer, trans temp & voltmeter, MBRP 4" cat back exhaust w/5" dual wall chrome tip, dark shadow gray/ med. flint interior.
wpetko is offline
post #8 of 9 (permalink) Old 03-15-2019, 11:38 PM
@Petko.
Trying to figure out how to get further details without sounding argumentative.
Since motor oil is a combination of base stock and additives, is it possible that even though the Base stock was reported to you as the same in all brands that your co-workers forgot to consider that the additives were of different quality/quantity depending on what that particular customer wanted? Or did they say the oils were identical even with the additives?
Your Beaumont XOM refinery produces some very high quality oil under the Mobil label and a history of VOAs has shown many times it is superior to many other products so there seems to be a disconnect somewhere.
Here is a quick example of two well known 15w40 HDEOs: Delvac 1300 vs Rotella T-4. The two oils performed quite differently under identical test conditions.
https://rotella.shell.com/en_us/medi...on-ssht-lr.pdf
SOLD:
post #9 of 9 (permalink) Old Yesterday, 04:11 AM
@Petko,
This has sure been something to follow in the news:
https://www.chron.com/news/houston-t...m_medium=email
SOLD:
Similar Threads
Additives needed for ULSD fuel? UnclKracker 1999-2007 General Questions 8 09-25-2011 01:55 PM
Question about fuel and coolant additives? nbkr341 7.3L IDI Diesels (Not Power Strokes) 20 07-23-2011 07:21 AM
oil additives mmterrill Upgrades and Aftermarket - 6.0L Engine 13 03-19-2010 12:26 AM
Motor oil in diesel fuel? amko22 Bio-Diesel and Alternative Fuels 16 04-26-2008 11:34 PM
Diesel Additives - Power Service Products wheeze General Diesel 1 06-17-2006 11:48 PM
