Mudflaps for front - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 01-18-2019, 09:49 AM Thread Starter
Mudflaps for front
I have 2015 f-350 Dually 6.7, four inch lift with the large fender flares can't find a mudflap that fits in front any ideas?
manaya1127 is offline
post #2 of 3 (permalink) Old 01-18-2019, 04:15 PM
Have you tried DuraFlaps? I think they might be the only one that has anything that might work.
https://duraflap.com/truck-model/ford/duallys-ford/
Larry
larrgh is offline
post #3 of 3 (permalink) Old 01-18-2019, 10:44 PM
https://www.rpmoutlet.com/2011-2015-...-mud-flaps.htm
These may fit.
2001 F350 XLT 4X4 crew cab, dual rear wheels, long bed, black, 7.3l turbo diesel, automatic transmission, 4.10, shift on the fly, running boards, sliding rear window, 38 gal fuel tank, Odyssey extreme 65-PC1750T batteries, Michelin LTX-MS2 rear tires, Sumitomo Encounter front tires, Shell Rotella Ultra elc, 11,500 gvwr, 20,000 gcwr, 7500 gvw, completely stock, 114,000 miles when purchased, now has 240,000 miles, repairs so far: two starters, batteries, cps, brakes, tires, alternator, ball joints, locking hub, wheel hub, AC compressor, serpentine belt, power steering pump, driver's side window, ignition switch, o-ring, Spectra premium radiator, water pump, fan clutch, fan blades, thermostat, thermostat housing, tensioner. Stolen twice so far, but recovered both times with major damage.
DonWarkentin is offline
