Pairing phone with truck - Diesel Forum - TheDieselStop.com
post #1 of 7 (permalink) Old 08-24-2016, 08:50 PM Thread Starter
Had to get a new iPhone. Replacement phone with same SIM card. I tried pairing my phone to the truck and the truck just says connecting and nothing else. Say there for over 5 minutes multiple times. It paired with my old phone quickly. Any tricks or am I dog it wrong?
Make sure I'm on Bluetooth with iPhone and that it is discoverable. I then hit the phone button on my radio in the truck and the radio says connecting. That's it. I have to shut the truck off and open the door to get the radio to do anything after that, otherwise it just says connecting and doesn't respond at all. Thanks for any advice, Nick.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is offline
post #2 of 7 (permalink) Old 08-25-2016, 05:29 AM
Sounds more like a phone problem to me. The SIM card doesn't affect the bluetooth connection. Usually when it goes into connect and circles, it is waiting on input from the phone from my experience. Check your bluetooth paired devices to see if there are any there that need to be deleted.
Larry
larrgh is offline
post #3 of 7 (permalink) Old 08-25-2016, 07:46 AM
glenndibler's Avatar
Had the same issue with my 2011 sync-nav but with a (Motorola (Razr Maxx HD) where the sync-nav just sat showing as connecting even after I removed and put the profile back. My final solution was to do a master reset on the radio and all problems were resolved. Good Luck.
2011 F-350 Lariat 4X4 Crewcab, SRW, LB[/B], Two-Tone Tuxedeo Black Metallic/Pale Adobe Metallic, Adobe Interior, 6.7L, 3.55 elocker, 18" Michelin LTX A/T2 A/T Tires, Lariat Interior Package, Chrome Pkg, Camper Pkg, Snow Plow Prep Pkg, Engine Block Heater, 5th Wheel Prep Prep Pkg, TruXedo TruXport Rollup Tonneau Cover, Rapid Suplemental Cab Heater, Rear Window defroster, Tailgate Step, Universal Garage Door Opener, Upfitter switches, Splash guards, Toughbed bedliner, Navigation Radio
glenndibler is offline
post #4 of 7 (permalink) Old 08-25-2016, 08:35 AM
Also, is Sync up to date? Have you checked to make sure Sync is the latest version.
https://owner.ford.com/tools/account...p-to-date.html
Also, check to see if your phone is compatible
https://owner.ford.com/how-tos/sync-...uch&country=us
Larry
larrgh is offline
post #5 of 7 (permalink) Old 08-25-2016, 02:37 PM
FordIVTteam's Avatar
Hi NickKent,
It sounds like SYNC is trying to connect to the other phone. Did you delete your previous iPhone from SYNC? If not, follow tip #3: https://owner.ford.com/how-tos/sync-...th-myford.html
Shaay
FORD IN-VEHICLE TECHNOLOGY TEAM
p: 800.392.FORD (Prompts 1 then 3)
t:
f:
FordIVTteam is offline
post #6 of 7 (permalink) Old 08-25-2016, 05:24 PM Thread Starter
I got it figured out. Didn't realize I could scroll through settings with the steering wheel controls. Basically I'm an idiot. I deleted my old phone and paired the new one. All set. Many thanks
NickKent is offline
post #7 of 7 (permalink) Old 08-26-2016, 08:52 AM
You're not an idiot, NickKent; just a novice. Glad it's working now. Reach out in the future if you require any SYNC assistance.
Shaay
t:
f:
