Power/folding mirrors - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 04-18-2019, 01:51 PM Thread Starter
Hello I have read all the previous post about these mirrors but little help. If I understand (from what I read) There is NO maintenance for the power/folding extension mirrors on my 2015 6.7L 250 super duty. Also the gears are plastic. Is the any product that can be sprayed on to the gears without taking the whole unit apart? I should have said my mirrors do work BUT make noise as they open extend and close.
Thanks again
RGVAL is offline
post #2 of 9 (permalink) Old 04-18-2019, 04:15 PM
Not aware of any product nor how to spray anything on the gears. Check this link, you might see something that will help.
http://www.powerstroke.org/forum/6-4...d-fix-5-a.html
Larry
larrgh is online now
post #3 of 9 (permalink) Old 04-18-2019, 05:39 PM
There is someone that makes
Brass gears as a replacement. He did the research and made them up. I donít currently have his link, but thinking you do some searching youíll come across it.
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is online now
post #4 of 9 (permalink) Old 04-18-2019, 08:10 PM
https://www.gruvenparts.com/shop-by-car/ford
Larry
post #5 of 9 (permalink) Old 04-19-2019, 05:04 AM
There you go. Thanks
post #6 of 9 (permalink) Old 04-21-2019, 10:12 AM Thread Starter
As always you guys come thru. I will just keep fingers crossed and use the mirrors minimally.
RG. 2015 Ford 250 6.7l First diesel Towing 22" Travel Trailer 2-3mos per year
RGVAL is offline
post #7 of 9 (permalink) Old 04-21-2019, 12:27 PM
Mine have been fine so far. The driver side does run a little slower than the passenger. I will kind of help it out some times if I remember to open my window. But I definitely donít put any stress on it. I am planning on buying the gears just to have on stand by when they do break. I also think that running them when they are iced up in the winter probably is a good way to strip out the gears.
post #8 of 9 (permalink) Old 06-26-2019, 11:30 AM
Having problems with driver side.
In other post seen pics if replacing gears in gearbox. But what caught my eye was a wavy 3 piece spring like part, and has curved end. I suspect the curve end some kind of detent, to hold mirror in open position.
And I an suspecting the harsh opening or closing may be due to friction, like spring surface rubbing.
So I took spray can, with those plastic tube nozzle and worked it in the seams of the pivot point, sprayed lot of lube, top n bottom of both top and bottom pivot joints. LOTS!
Now the mirror opens n closes with no clicks, clunks, and as it should. I can only suspect the lube prob hit the spring surfaces, allows reduced friction.
I am monitoring how this works for next few days. Hope it does.
CajunMick is offline
post #9 of 9 (permalink) Old 06-29-2019, 03:14 PM
Well, may be back to square one.
Mirrors open closed great for few days. But after couple days inactivity and a recent heavy down pour, next day driver sid Open, but pax did not. WTH!
So manually moved it, got them going again. But a hit or miss affair.
When got back home, trying couple times, they hanging up. So his time I got another type lube, not WD-40, whichnis not so magical stuff, this one silicon based anticorrosive fluid, sprayed into the seams, a lot. Mirrors still acting up. So left them open overnight. Next morning, attempted to close. They both closed ok. So left it at that for now. Will try them in next few days, see what happens.
But I say this - not gonna spend $500-1500 for mirrors. Either gonna leave them open, out, do them manually. I have to close if at bank ATM or fast food drive ups. Or send DW in her SUV to get money and/or food. LoL
Similar Threads
Replacing tow mirrors on 2001 with 2008 and up mirrors jjlrrw 1999-2007 Upgrades and Aftermarket - General 13 09-19-2017 09:49 AM
About aftermarket tow mirrors? dieseldogtom E-Series Vans 13 01-12-2016 08:12 AM
08 tow mirrors replacement for 04 Dboy11 1999-2007 Upgrades and Aftermarket - General 24 09-16-2010 10:11 AM
How To Install 09 550 Tow Mirrors on a E350 2000 Van van_350sd E-Series Vans 24 05-06-2010 05:23 PM
Paddle Mirrors to TT Mirrors JasonRandolph Power Stroke Excursions 3 09-05-2006 09:27 PM
