Power mirrors not working - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 04-16-2014, 05:42 AM Thread Starter
First let me say, I'M BACK!! After being off the forums since 2010, I'm back to see what's going on.
My 2012 side mirrors do not work. Just the mirror adjustment. The power fold and extend work fine.
I replaced the blown fuse and they worked for about two minutes then quit. No blown fuse this time, just won't move. Is the switch bad since they both don't work?
ChaseN is offline
post #2 of 13 (permalink) Old 04-16-2014, 09:19 AM
On my 2011, a few times they just wouldn't work...then would try in few minutes later and would work without doing a thing...
2015 6.2 F350 Wht Platinum/Caribou FX4 4x4 4.30 Lariat Ultimate SCrew 156wb Ordered : 2/25/14 Delivered : 5/29/14
Traded : 2011 6.2 F250 Black FX4 4x4 3.73 XLT SCrew 156wb
Traded : 2004 5.4 F150 Black 4x4 3.55 XLT SCrew 145wb
gvales is offline
post #3 of 13 (permalink) Old 04-16-2014, 03:08 PM
rac1664's Avatar
I have had problems with mine extending. One replaced by warranty, and I am waiting on the second. Seems like they are cheaply built. Not happy with the poor quality. Mine is a 2011
2011 Crew Cab Lariat Long Bed Dually 6.7
2006 Crew Cab Long Bed King Ranch 6.0
2001 Excursion Limited 7.3 PSD
1999 Crew Cab short bed Lariat 7.3 Diesel (2x)
Montana Mountaineer 5th wheel
WVU Let's Go Mountaineers!!!!!
rac1664 is offline
post #4 of 13 (permalink) Old 04-16-2014, 04:57 PM
wingedone's Avatar
Mine caught me off guard once. They wouldn't open. Then I noticed the switch wasn't set to center. Set it to center and they worked. Lesson learned.
2013 F350 SC 6.7 DRW Lariat
2011 Brookstone 354TS
Swivelwheel 58DW
1993 GL1500SE
wingedone is offline
post #5 of 13 (permalink) Old 04-17-2014, 06:56 AM Thread Starter
Thanks for the replies guys. Let me clarify..
Everything works good other than the glass adjustment. Neither mirror glass moves.
2012 F250 6.7L Crew Cab
FX4 Offroad SWB 70k miles
Double Layer Limo Tint
2.5" Leveling Kit
ChaseN is offline
post #6 of 13 (permalink) Old 04-17-2014, 09:53 AM
Dak
Stupid questions, but did you check the connections underneath the control in the door?
That piece just pops out. Maybe part of it worked loose?
2011 F350 SRW 4x4, Lariat, LWB, Diesel, Nav., 5th Wheel and Camper Pkg.
Dak is offline
post #7 of 13 (permalink) Old 04-17-2014, 11:54 AM Thread Starter
yes, i sure did. thanks for the thought tho!
I guess i'll just buy the switch, can't be too much. bummer.
2.5" Leveling Kit
ChaseN is offline
post #8 of 13 (permalink) Old 04-28-2014, 06:44 PM Thread Starter
replaced the switch. still no glass movement. any other ideas?
2.5" Leveling Kit
ChaseN is offline
post #9 of 13 (permalink) Old 04-29-2014, 02:11 AM
Guessing from a 2011 diagram, it depends on what setup you have? Do you have memory? Which fuse did you change?
If you donít have memory, fuse F8 in the BCM is for the glass and fold and not to extend the mirrors. If the mirrors fold then F8 is OK. I assume that the fuse (F8) is still good and it is a new switch, there is a black wire with a white stripe connected to the switch and that is the ground wire for only the glass movement for both mirrors. I'd verify if that wire is grounded with a meter.
MPD56 is offline
post #10 of 13 (permalink) Old 04-29-2014, 03:01 AM Thread Starter
okay so i just tried something, i tried the memory buttons and the glass moves. i checked all wires and they seem to be good. i moved the glass by hand then set the memory and pressed different memory then back and it moved like it should.
just won't work with the switch. ughh!
2.5" Leveling Kit
ChaseN is offline
post #11 of 13 (permalink) Old 04-29-2014, 01:17 PM
Remember, Iím working from a 2011 diagram, my 2013 doesnít have a Set button and could have different modules added, and so can the 2012? You didnít post what fuse you changed. With or without memory changes what controls the power to the mirrorís glass motor? Since you have memory, the black/white wire at the switch could still cause your problem. With memory the door switch sends inputs to the Driverís Seat Module (DSM) and this moduleís outputs to the mirror glass motors. Without memory the switch powers the motors directly.
Iím not and expert, but Iíd confirm the black/white wire with an ohm meter that it is grounded. The only other common denominator I see from the diagram is the DSM. My thoughts are, if you are handy with a digital meter, Iíd check fuses and rule out the black/white wire, since the memory buttons work, the DSM would be my second choice. I donít know what year they added modules, so if you are handy with a digital meter, you will have to test more.
Do your power seats move manually?
Knowing the fuses you changed would give me an ideal if you had a power circuit or control circuit problem.
Iím assuming that you changed the switch by yourself; your truck is out of warranty.
The dealer can scan your truck and tell whatís not working.
MPD56 is offline
post #12 of 13 (permalink) Old 09-29-2018, 10:05 AM
My truck is doing the same thing now! Any updates on how to fix?
Trevor Key is offline
post #13 of 13 (permalink) Old 04-23-2019, 09:06 PM
no glass adjustment on both, folding and extending work fine
I have been chasing the same issue for several days. The mirror adjustment isn't working. Replaced switch, removed and inspected and check all wires in the left door harness (a back ordered item for Ford). The wiring diagram in the manual isn't as-built. The door conductors all go into the cab harness through the door bulkhead connector, none double back the circuits in the door, so suspect there is something in the cab wiring that doesn't play well. Any other solutions found? Thx. Ford 6.7l-F250 2015 Lariat crewcab,shortbox
moss01 is offline
