Random hot air through vents. - Diesel Forum - TheDieselStop.com
post #1 of 4 (permalink) Old 03-27-2019, 12:03 AM Thread Starter
I have a 2014 6.7 power stroke. Absolutely love my truck. One thing is bothering me though. As I live in CA, I usually drive with the climate control off and the windows down a bit. Every once in a while, with the climate control off, I will feel hot air coming out of the vents. Hot as if I have the heat turned all the way off. The way I get it to stop is by briefly turning the climate control on and then off. The hot air then stops coming out of the vents. I have mentioned it to the dealer and they said they haven't heard anything about it and to pay attention to what the truck is doing when it happens. There are no lights or anything abnormal about the truck when it happens other than the hot air. Anyone have suggestions on what I should check? Any help would be appreciated. It bothers me a lot when things aren't working they way they should.
EJA1276 is offline
post #2 of 4 (permalink) Old 03-27-2019, 05:27 AM
Iíd just leave the climate control on with the temp turned down or adjusted so it is the same as outside temp. Just remember anytime you turn on the defrost by default it engages the ac as well. So, floor or vent setting is probably what you want
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
NickKent is offline
post #3 of 4 (permalink) Old 03-28-2019, 12:35 AM Thread Starter
I usually have the temp in the cold position. The problem is that regardless of where the temp was left at, the air that comes out is hot no matter what.
EJA1276 is offline
post #4 of 4 (permalink) Old 03-28-2019, 04:56 AM
This is with the system off? So turn it on. If the cold setting isnít cold enough put it on defrost/floor. That will turn the ac compressor on a bit.
NickKent is offline
Similar Threads
No Air Flow on Feet bgiebels 6.0L Power Stroke Engine and Drivetrain 2 12-31-2017 09:23 AM
Air conditioner only comes out of defrost vents when very hot PASledneck '99 & up 7.3L Power Stroke Engine and Drivetrain 2 07-17-2006 02:29 PM
