Rear Window Electric Slide Stopped Working - Diesel Forum - TheDieselStop.com
post #1 of 3 (permalink) Old 10-20-2015, 04:14 PM Thread Starter
2011 F350. Approximately 70,000 miles. I'm told that the motor appears to have failed and that this is not an inexpensive repair. Sounds like over $600, with exact labor to be determined. I'm surprised to have this problem so relatively soon. Is this something that others are experiencing? I used my rear window slide maybe once every 2-3 months. So it was used, but certainly not worn out.
Cajun Martini is offline
post #2 of 3 (permalink) Old 10-21-2015, 08:56 AM
I had a problem on my 2004 F-150 just like that. Water had gotten in an caused an issue. I found on a different forum that you could drop the seat forward and if you tapped the motor with a rubber mallet it would free it up. Might be worth a try to see if you can find it on yours and do the same. After that I just made a point of running it back and forth every time I used the truck. Didn't have any issues after that.
2015 F-350 Platinum Bronze Fire 6.7 PSD loaded from Scott Pratt at Fowlerville Ford
2011 Rockwood 2704 Travel Trailer
Elkhounds is offline
post #3 of 3 (permalink) Old 10-22-2015, 02:52 PM
FordService's Avatar
Originally Posted by Cajun Martini View Post
2011 F350. Approximately 70,000 miles. I'm told that the motor appears to have failed and that this is not an inexpensive repair. Sounds like over $600, with exact labor to be determined...
Hi Cajun Martini,
Did you receive this estimate from your local Ford Dealership? If so, I'll be able to do some research and see what options are available to help.
Crystal
FORD SERVICE
p: 800.392.FORD
t:
f:
FordService is offline
