Sun Visor - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 07-18-2019, 09:24 AM Thread Starter
demoes4x's Avatar
Sun Visor
Hello all,
I'll be upgrading the sun visors on my Early 99' and was wondering if someone could please be so kind to go out and measure their 2011-15' sun visor rod from the (center) pivot point where it mounts with two screws to the center of the lock in clip on the opposite end I've attached a picture for your reference please also note your year model truck. Thank you, Demoe
Name:	2011-15 Sun Visor.PNG
EARLY 99' F350 7.3 CC 4X4 LB. DRW. FABTECH 3.5" FRONT LEVELING KIT - AUTOMETER BOOST, PYRO, TRANS, WATER, OIL TEMP, FUEL & AIR PRESSURE - WW2 - AIS INTAKE - 4" SS MBRP COOL DUALS TURBO BACK - JOHN WOOD TRANS - RIFFRAFF BOOTS - 6.0 TRANS COOLER - CCV MOD - PROVENT 200 - DP TUNER NO START, STOCK, 40T, 80E, 120 RACE - 35" TOYO MT'S - 22" AMERICAN FORCE EVOS - FOX 2.0 RESEVOIR SHOCKS - UPGRADED POST 99' 10MM HUB ASSY'S - SLOTTED BRAKE ROTORS - MAG-HYTEC TRANS PAN & DIFFERENTIAL COVERS - ITP SS HP-X - ITP REGULATED RETURN - HEATER BYPASS VALVE - AIRDOG - DIESELSITE COOLANT FILTER - DIESELSITE 203* TS WITH BILLET HOUSING - DC PERF 190 AMP ALTERNATOR - ON-BOARD AIR - HORN BLASTERS - 13' LARIAT INTERIOR.
demoes4x is offline
post #2 of 5 (permalink) Old 07-19-2019, 10:07 PM Thread Starter
demoes4x's Avatar
Well, so far I'm 0 for 42 (0 replies for 42 views) anyone? Thanks.
demoes4x is offline
post #3 of 5 (permalink) Old 07-20-2019, 07:33 AM
BigDogOil's Avatar
2012 F350
15 inches center of pivot rod to center of lock in clip.
2012 F 350 Lariat 4X4 Crew Cab SRW
EGR, DPF Delete
4" Straight Pipe
2004 F 350 XLT 4X4 Crew Cab SRW (SOLD)
BigDogOil is offline
post #4 of 5 (permalink) Old 07-20-2019, 08:32 AM Thread Starter
demoes4x's Avatar
Thank you for taking the time Sir.
demoes4x is offline
post #5 of 5 (permalink) Old 08-02-2019, 01:25 AM
Don't have those measurements but on my old 2002 I swapped in Excursion visors with lit mirrors and homelink. It was a great improvement and they bolted right in. I did have to run power for each side.
Tom
02 CC XLT Dually 4x2, PSD w/6 spd, White w/Med Flint 40/20/40, TTT Mirrors, 4.10 L/S, PCM=AEB4, Receiver, Cab Steps, Homelink X Visor, Husky F&R Mud Flaps, AIS Ford Filter, WD Pyro & Boost in A-pillar, Line-X, Hutch Tank Mod, Pre-Pump Racor 645R30, 4" Banks Monster Exhaust, Mag-Hytec Diff Cover, Amsoil in Tranny & Diff.
Bye-bye 99 diesel-sucking automatic!!!
tomshep is offline
