Torque Pro Powerstroke pid's - Diesel Forum - TheDieselStop.com
post #1 of 9 (permalink) Old 08-14-2019, 06:13 AM Thread Starter
My Samsung tablet died due to heat and I am trying to set up a new tablet to run Torque. I can't find the extended 6.7 power stroke pid's to download. Any idea where I can go to get these?
2016 F250 Diesel Ruby Red Metallic Platinum FX4
LITECATCH is offline
post #2 of 9 (permalink) Old 08-14-2019, 07:35 AM
check this link
https://www.ford-trucks.com/forums/1...l#post18613559
Larry
larrgh is online now
post #3 of 9 (permalink) Old 08-14-2019, 08:11 AM Thread Starter
Thanks Larry!
post #4 of 9 (permalink) Old 08-14-2019, 08:12 AM Thread Starter
I'm at work and dropbox is blocked.
post #5 of 9 (permalink) Old 08-14-2019, 09:08 AM Thread Starter
Does anyone have the equation and header information for the GPS speed? That's the last one I need.
post #6 of 9 (permalink) Old 08-14-2019, 07:10 PM
Its in the list when you add a display... SpeedGps
The PIDs are alphabetically listed so speed obd and speed gps are next to each other. The are not 6.7specific. You may need to add just the Ford Pids to get them. Can't remember for sure but I think thats how I got them.
RoadrunnerII
Sent from my Moto G Play using Tapatalk
Roadrunner II is offline
post #7 of 9 (permalink) Old 08-15-2019, 06:57 AM Thread Starter
I have the one on the list. The gps one on the generic list doesn't work. The regular speed does but it is not accurate.
post #8 of 9 (permalink) Old 08-15-2019, 07:16 AM Thread Starter
I forgot, the gps pid on the list is in KPH not MPH.
post #9 of 9 (permalink) Old 08-15-2019, 07:24 AM
If you go into the gear icon....... setting.... units.... set for miles instead of kms
You should likely review all the units to ensure your setup correctly.
Also once you add the dials you can edit the text in the dial...long press on dial... Display configuration. Can set decimal places min /max setting etc.
It takes some time messing with it to tune it to your liking
RoadrunnerII
