Diesel Forum - TheDieselStop.com
Diesel Forum - TheDieselStop.com (https://www.thedieselstop.com/forums/)
-   '11-16 General Questions (https://www.thedieselstop.com/forums/f152/)
-   -   Unknown bolt/grease zerk (https://www.thedieselstop.com/forums/f152/unknown-bolt-grease-zerk-623858/)
jwbboat 08-06-2017 10:23 AM
3 Attachment(s)
This was found where i park my trk,only other thing that has been parked there is an f150 ...any idea's where this goes?...
diesel2121 08-07-2017 01:22 AM
Muffler bearing!
Sent from my SAMSUNG-SM-G890A using Tapatalk
ArcticDriver 08-07-2017 02:36 AM
Trailer Axle Bolt?
Relentless007 08-07-2017 08:41 AM
reminds me of the bolt on top of lawnmower deck that holds the blade and belt wheel.
jwbboat 08-07-2017 08:55 AM
Originally Posted by ArcticDriver (Post 4459802)
Trailer Axle Bolt?
thanks,..i hadn't thought of that,..i had my 2 boats in there(trk barn)..doing some things to them months ago..will ck that..thanks for the reminder
jwbboat 08-07-2017 08:57 AM
thanks for the response,..this was in an area that I cant take my mower...good thought tho
jwbboat 08-07-2017 01:31 PM
Nope,not off my boat trailers
ArcticDriver 08-07-2017 05:54 PM
A neighbor tossing it on your drive because he knew it would bug ya? ;-)
ford_doctor 08-07-2017 06:20 PM
Looks like a bolt head with a hood prop/liftgate prop mount (the ball) or a mount for a ride height sensor rod. A little large to be a Zerk... the pictures are small so I can't zoom in to see much detail.
bugman 08-07-2017 06:33 PM
Just throw it away and within 2 days you will find where it is suppose to go.
jwbboat 08-08-2017 08:07 AM
the bolt is hollow,for greasing..zerk on one end,hole on the other...after more research,..this appears to be what is called a 'wet-bolt'...used on axles..it was nt buried in the dirt,..it was on top of the ground...pretty puzzling
larrgh 08-08-2017 12:36 PM
That maybe a "wet bolt" but it is not big enough for spring hangers. Also too many threads on the bolt that would weaken it. Wet bolts have an actual zerk in the end, it is not made into the spring hanger bolt.
I am more inclined to agree with Ford Doctor. It is for some type of gas charged shock mount that holds the hood or trunk lid open.
Powered by vBulletin® Copyright ©2000 - 2019, Jelsoft Enterprises Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
